Hello, I working on an Engine with DirectX. Inside the engine I display Video card information, like name, ram type, Temp, usage and etc. Unfortunately because the engine use AMD, NVIDIA and Intel, I’m forced to use dynamic way to avoid dll missing popup message from static version. The conversion work really fine, actually I made in one day.
Because NvAPI_GPU_GetMemoryInfo was deprecated I must use NvAPI_GPU_GetMemoryInfoEx. Habitually, to convert in dynamic way, we use GetProcAddress and dumpbin on the DLL.
NvAPI_QueryInterface = (NvAPI_QueryInterface_t)GetProcAddress(hDLL, "nvapi_QueryInterface");
But for this API we use a magic offset that you send to QueryInterface
NvAPI_GPU_GetMemoryInfo = (NvAPI_GPU_GetMemoryInfo_t)(*NvAPI_QueryInterface)(0x774AA982);
Now I need to know 2 thing.
- How get QueryInterface magic number from DLL or LIB?
- What is the offset of NvAPI_GPU_GetMemoryInfoEX?
Static-Way (Working with API SDK)
#include <stdio.h>
#include <nvapi.h>
#pragma comment(lib, "nvapi64.lib")
int main()
if (NvAPI_Initialize() == NVAPI_OK)
unsigned long gpuCount = 0;
NvPhysicalGpuHandle gpuHandles[NVAPI_MAX_PHYSICAL_GPUS] = { NULL };
NvAPI_EnumPhysicalGPUs(gpuHandles, &gpuCount);
char nvNameAnsiString[1024] = "";
NvAPI_GPU_GetFullName(gpuHandles[0], nvNameAnsiString);
printf("Video Card : %s\n", nvNameAnsiString);
NV_GPU_MEMORY_INFO_EX MemoryInfo = { NV_GPU_MEMORY_INFO_EX_VER };
NvAPI_GPU_GetMemoryInfoEx(gpuHandles[0], &MemoryInfo);
printf("Ram : %lld\n", MemoryInfo.availableDedicatedVideoMemory);
//Only work if 4996 was disable
#pragma warning(disable : 4996)
NV_DISPLAY_DRIVER_MEMORY_INFO MemoryInfoV3 = { NV_DISPLAY_DRIVER_MEMORY_INFO_VER };
NvAPI_GPU_GetMemoryInfo(gpuHandles[0], &MemoryInfoV3);
printf("Ram (old): %lld\n", MemoryInfo.availableDedicatedVideoMemory);
return 0;
Dynamic-Way (Dont need API SDK, only a NVIDIA video card installed on your PC “DLL will be there”)
//*** Macro definition ******************************************************
#ifndef _RELENTLESS_NVIDIA_VIDEO_H__
#define _RELENTLESS_NVIDIA_VIDEO_H__
#pragma once
//*** Include ***************************************************************
#include <RDPCStatus.h>
//*** NVIDIA ADL DLL Module ****************************************************
#define MAKE_NVAPI_VERSION(typeName,ver) (unsigned long)(sizeof(typeName) | ((ver) << 16))
#define NVAPI_MAX_THERMAL_SENSORS_PER_GPU 3
typedef enum
NVAPI_THERMAL_TARGET_NONE = 0,
NVAPI_THERMAL_TARGET_GPU = 1, //!< GPU core temperature requires NvPhysicalGpuHandle
NVAPI_THERMAL_TARGET_MEMORY = 2, //!< GPU memory temperature requires NvPhysicalGpuHandle
NVAPI_THERMAL_TARGET_POWER_SUPPLY = 4, //!< GPU power supply temperature requires NvPhysicalGpuHandle
NVAPI_THERMAL_TARGET_BOARD = 8, //!< GPU board ambient temperature requires NvPhysicalGpuHandle
NVAPI_THERMAL_TARGET_VCD_BOARD = 9, //!< Visual Computing Device Board temperature requires NvVisualComputingDeviceHandle
NVAPI_THERMAL_TARGET_VCD_INLET = 10, //!< Visual Computing Device Inlet temperature requires NvVisualComputingDeviceHandle
NVAPI_THERMAL_TARGET_VCD_OUTLET = 11, //!< Visual Computing Device Outlet temperature requires NvVisualComputingDeviceHandle
NVAPI_THERMAL_TARGET_ALL = 15,
NVAPI_THERMAL_TARGET_UNKNOWN = -1,
} NV_THERMAL_TARGET;
typedef struct
int version; //!< structure version
int count; //!< number of associated thermal sensors
struct
int controller; //!< internal, ADM1032, MAX6649...
int defaultMinTemp; //!< The min default temperature value of the thermal sensor in degree Celsius
int defaultMaxTemp; //!< The max default temperature value of the thermal sensor in degree Celsius
int currentTemp; //!< The current temperature value of the thermal sensor in degree Celsius
NV_THERMAL_TARGET target; //!< Thermal sensor targeted @ GPU, memory, chipset, powersupply, Visual Computing Device, etc.
} sensor[NVAPI_MAX_THERMAL_SENSORS_PER_GPU];
} NV_GPU_THERMAL_SETTINGS;
#define NV_GPU_THERMAL_SETTINGS_VER MAKE_NVAPI_VERSION(NV_GPU_THERMAL_SETTINGS,1)
// magic numbers, do not change them
#define NVAPI_MAX_PHYSICAL_GPUS 64
#define NVAPI_MAX_USAGES_PER_GPU 33 //34
typedef enum _NV_RAM_TYPE
NV_RAM_TYPE_NONE,
NV_RAM_TYPE_SDRAM,
NV_RAM_TYPE_DDR1,
NV_RAM_TYPE_DDR2,
NV_RAM_TYPE_GDDR2,
NV_RAM_TYPE_GDDR3,
NV_RAM_TYPE_GDDR4,
NV_RAM_TYPE_DDR3,
NV_RAM_TYPE_GDDR5,
NV_RAM_TYPE_LPDDR2
} NV_RAM_TYPE;
const char* RAMTYPESTR[] = { "None", "SDRAM", "DDR1", "DDR2", "GDDR2", "GDDR3", "GDDR4", "DDR3", "GDDR5", "LPDDR2" };
typedef struct
unsigned long version; //!< Structure version
unsigned long usages[NVAPI_MAX_USAGES_PER_GPU];
} NV_USAGES_INFO;
#define NV_USAGES_INFO_VER MAKE_NVAPI_VERSION(NV_USAGES_INFO, 1)
typedef enum _NV_COOLER_TYPE
NVAPI_COOLER_TYPE_NONE = 0,
NVAPI_COOLER_TYPE_FAN,
NVAPI_COOLER_TYPE_WATER,
NVAPI_COOLER_TYPE_LIQUID_NO2,
} NV_COOLER_TYPE;
// rev
typedef enum _NV_COOLER_CONTROLLER
NVAPI_COOLER_CONTROLLER_NONE = 0,
NVAPI_COOLER_CONTROLLER_ADI,
NVAPI_COOLER_CONTROLLER_INTERNAL,
} NV_COOLER_CONTROLLER;
// rev
typedef enum _NV_COOLER_POLICY
NVAPI_COOLER_POLICY_NONE = 0,
NVAPI_COOLER_POLICY_MANUAL, // Manual adjustment of cooler level. Gets applied right away independent of temperature or performance level.
NVAPI_COOLER_POLICY_PERF, // GPU performance controls the cooler level.
NVAPI_COOLER_POLICY_TEMPERATURE_DISCRETE = 4, // Discrete thermal levels control the cooler level.
NVAPI_COOLER_POLICY_TEMPERATURE_CONTINUOUS = 8, // Cooler level adjusted at continuous thermal levels.
NVAPI_COOLER_POLICY_HYBRID, // Hybrid of performance and temperature levels.
} NV_COOLER_POLICY;
typedef enum _NV_COOLER_TARGET
NVAPI_COOLER_TARGET_NONE = 0,
NVAPI_COOLER_TARGET_GPU,
NVAPI_COOLER_TARGET_MEMORY,
NVAPI_COOLER_TARGET_POWER_SUPPLY = 4,
NVAPI_COOLER_TARGET_ALL = 7 // This cooler cools all of the components related to its target gpu.
} NV_COOLER_TARGET;
// rev
NVAPI_COOLER_CONTROL_NONE = 0,
NVAPI_COOLER_CONTROL_TOGGLE, // ON/OFF
NVAPI_COOLER_CONTROL_VARIABLE, // Suppports variable control.
} NV_COOLER_CONTROL;
// rev
typedef enum _NV_COOLER_ACTIVITY_LEVEL
NVAPI_INACTIVE = 0, // inactive or unsupported
NVAPI_ACTIVE = 1, // active and spinning in case of fan
} NV_COOLER_ACTIVITY_LEVEL;
#define NVAPI_MAX_COOLERS_PER_GPU 3
typedef struct _NV_GPU_COOLER_SETTINGS
unsigned long version; // structure version
unsigned long count; // number of associated coolers with the selected GPU
struct
NV_COOLER_TYPE type; // type of cooler - FAN, WATER, LIQUID_NO2...
NV_COOLER_CONTROLLER controller; // internal, ADI...
unsigned long defaultMinLevel; // the min default value % of the cooler
unsigned long defaultMaxLevel; // the max default value % of the cooler
unsigned long currentMinLevel; // the current allowed min value % of the cooler
unsigned long currentMaxLevel; // the current allowed max value % of the cooler
unsigned long currentLevel; // the current value % of the cooler
NV_COOLER_POLICY defaultPolicy; // cooler control policy - auto-perf, auto-thermal, manual, hybrid...
NV_COOLER_POLICY currentPolicy; // cooler control policy - auto-perf, auto-thermal, manual, hybrid...
NV_COOLER_TARGET target; // cooling target - GPU, memory, chipset, powersupply, canoas...
NV_COOLER_CONTROL controlType; // toggle or variable
NV_COOLER_ACTIVITY_LEVEL active; // is the cooler active - fan spinning...
} cooler[NVAPI_MAX_COOLERS_PER_GPU];
} NV_GPU_COOLER_SETTINGS, * PNV_GPU_COOLER_SETTINGS;
#define NV_GPU_COOLER_SETTINGS_VER MAKE_NVAPI_VERSION(NV_GPU_COOLER_SETTINGS, 1)
typedef struct
unsigned long long dedicatedVideoMemory; //!< Size(in bytes) of the physical framebuffer.
unsigned long long availableDedicatedVideoMemory; //!< Size(in bytes) of the available physical framebuffer for allocating video memory surfaces.
unsigned long long systemVideoMemory; //!< Size(in bytes) of system memory the driver allocates at load time.
unsigned long long sharedSystemMemory; //!< Size(in bytes) of shared system memory that driver is allowed to commit for surfaces across all allocations.
unsigned long long curAvailableDedicatedVideoMemory; //!< Size(in bytes) of the current available physical framebuffer for allocating video memory surfaces.
unsigned long long dedicatedVideoMemoryEvictionsSize; //!< Size(in bytes) of the total size of memory released as a result of the evictions.
unsigned long long dedicatedVideoMemoryEvictionCount; //!< Indicates the number of eviction events that caused an allocation to be removed from dedicated video memory to free GPU //!< video memory to make room for other allocations.
unsigned long long dedicatedVideoMemoryPromotionsSize; //!< Size(in bytes) of the total size of memory allocated as a result of the promotions.
unsigned long long dedicatedVideoMemoryPromotionCount; //!< Indicates the number of promotion events that caused an allocation to be promoted to dedicated video memory
} NV_GPU_MEMORY_INFO_EX;
#define NV_GPU_MEMORY_INFO_EX_VER MAKE_NVAPI_VERSION(NV_GPU_MEMORY_INFO_EX, 1)
typedef struct
unsigned long version; //!< Version info
unsigned long dedicatedVideoMemory; //!< Size(in kb) of the physical framebuffer.
unsigned long availableDedicatedVideoMemory; //!< Size(in kb) of the available physical framebuffer for allocating video memory surfaces.
unsigned long systemVideoMemory; //!< Size(in kb) of system memory the driver allocates at load time.
unsigned long sharedSystemMemory; //!< Size(in kb) of shared system memory that driver is allowed to commit for surfaces across all allocations.
} NV_DISPLAY_DRIVER_MEMORY_INFO_V1;
//! \ingroup driverapi
//! Used in NvAPI_GPU_GetMemoryInfo().
typedef struct
unsigned long curAvailableDedicatedVideoMemory; //!< Size(in kb) of the current available physical framebuffer for allocating video memory surfaces.
} NV_DISPLAY_DRIVER_MEMORY_INFO_V2;
typedef struct
unsigned long dedicatedVideoMemoryEvictionsSize; //!< Size(in kb) of the total size of memory released as a result of the evictions.
unsigned long dedicatedVideoMemoryEvictionCount; //!< Indicates the number of eviction events that caused an allocation to be removed from dedicated video memory to free GPU
} NV_DISPLAY_DRIVER_MEMORY_INFO_V3;
typedef NV_DISPLAY_DRIVER_MEMORY_INFO_V3 NV_DISPLAY_DRIVER_MEMORY_INFO;
#define NV_DISPLAY_DRIVER_MEMORY_INFO_VER_1 MAKE_NVAPI_VERSION(NV_DISPLAY_DRIVER_MEMORY_INFO_V1,1)
#define NV_DISPLAY_DRIVER_MEMORY_INFO_VER_2 MAKE_NVAPI_VERSION(NV_DISPLAY_DRIVER_MEMORY_INFO_V2,2)
#define NV_DISPLAY_DRIVER_MEMORY_INFO_VER_3 MAKE_NVAPI_VERSION(NV_DISPLAY_DRIVER_MEMORY_INFO_V3,3)
#define NV_DISPLAY_DRIVER_MEMORY_INFO_VER NV_DISPLAY_DRIVER_MEMORY_INFO_VER_3
typedef int* (*NvAPI_QueryInterface_t)(unsigned int offset);
typedef int (*NvAPI_Initialize_t)();
typedef int (*NvAPI_EnumPhysicalGPUs_t)(int** handles, int* count);
typedef int (*NvAPI_GPU_GetUsages_t)(int* handle, NV_USAGES_INFO* pusages);
typedef int (*NvAPI_GPU_GetCoolerSettings_t)(int* handle, unsigned long coolerIndex, NV_GPU_COOLER_SETTINGS* pCoolerInfo);
typedef int (*NvAPI_GPU_GetThermalSettings_t)(int* handle, int sensorIndex, NV_GPU_THERMAL_SETTINGS* temp);
typedef int (*NvAPI_GPU_GetTachReading_t)(int* handle, long* speed);
typedef int (*NvAPI_GPU_getFullName_t)(int* handle, char* name);
typedef int (*NvAPI_GPU_GetRamType_t)(int* handle, NV_RAM_TYPE* pRamType);
typedef int (*NvAPI_GPU_GetMemoryInfo_t)(int* handle, NV_DISPLAY_DRIVER_MEMORY_INFO* pMemoryInfo);
//*** Class definition ******************************************************
class CRDNVidiaVideo
public:
CRDNVidiaVideo(CRCArray<VideoCard*>* VideoCardList);
~CRDNVidiaVideo();
void Update(CRCArray<VideoCard*>* VideoCardList);
private:
NvAPI_QueryInterface_t NvAPI_QueryInterface;
NvAPI_Initialize_t NvAPI_Initialize;
NvAPI_EnumPhysicalGPUs_t NvAPI_EnumPhysicalGPUs;
NvAPI_GPU_GetUsages_t NvAPI_GPU_GetUsages;
NvAPI_GPU_GetThermalSettings_t NvAPI_GPU_GetThermalSettings;
NvAPI_GPU_GetTachReading_t NvAPI_GPU_GetTachReading;
NvAPI_GPU_getFullName_t NvAPI_GPU_getFullName;
NvAPI_GPU_GetRamType_t NvAPI_GPU_GetRamType;
NvAPI_GPU_GetMemoryInfo_t NvAPI_GPU_GetMemoryInfo;
NvAPI_GPU_GetCoolerSettings_t NvAPI_GPU_GetCoolerSettings;
HINSTANCE hDLL;
//*** End macro definition **************************************************
#endif
#ifndef _RELENTLESS_NVIDIA_VIDEO_CPP__
#define _RELENTLESS_NVIDIA_VIDEO_CPP__
//#include "RDNVidiaVideo.h"
// Output :
// Class name : CRDAmdVideo
// Function name : CRDAmdVideo
// Description : Constructor
// Input :
CRDNVidiaVideo::CRDNVidiaVideo(CRCArray<VideoCard*>* VideoCardList)
hDLL = LoadLibrary(L"nvapi64.dll");
if (hDLL != NULL)
// some useful internal functions that aren't exported by nvapi.dll
NvAPI_Initialize = (NvAPI_Initialize_t)(*NvAPI_QueryInterface)(0x0150E828);
NvAPI_EnumPhysicalGPUs = (NvAPI_EnumPhysicalGPUs_t)(*NvAPI_QueryInterface)(0xE5AC921F);
NvAPI_GPU_GetUsages = (NvAPI_GPU_GetUsages_t)(*NvAPI_QueryInterface)(0x189A1FDF);
NvAPI_GPU_GetThermalSettings = (NvAPI_GPU_GetThermalSettings_t)(*NvAPI_QueryInterface)(0xE3640A56);
NvAPI_GPU_GetTachReading = (NvAPI_GPU_GetTachReading_t)(*NvAPI_QueryInterface)(0x5F608315UL);
NvAPI_GPU_getFullName = (NvAPI_GPU_getFullName_t)(*NvAPI_QueryInterface)(0xCEEE8e9FUL);
NvAPI_GPU_GetRamType = (NvAPI_GPU_GetRamType_t)(*NvAPI_QueryInterface)(0x57F7CAACUL);
//NvAPI_GPU_GetRamBusWidth = (NvAPI_GPU_GetRamBusWidth_t)(*NvAPI_QueryInterface)(0x7975C581);
//NvAPI_GPU_GetRamBankCount = (NvAPI_GPU_GetRamBankCount_t)(*NvAPI_QueryInterface)(0x17073A3CUL);
NvAPI_GPU_GetCoolerSettings = (NvAPI_GPU_GetCoolerSettings_t)(*NvAPI_QueryInterface)(0xDA141340UL);
if (NvAPI_Initialize != NULL && NvAPI_EnumPhysicalGPUs != NULL && NvAPI_EnumPhysicalGPUs != NULL && NvAPI_GPU_GetUsages != NULL)
(*NvAPI_Initialize)();
int gpuCount = 0;
int* gpuHandles[NVAPI_MAX_PHYSICAL_GPUS] = { NULL };
(*NvAPI_EnumPhysicalGPUs)(gpuHandles, &gpuCount);
for (int GPUIndex = 0; GPUIndex < gpuCount; GPUIndex++)
VideoCard* AddElem = new VideoCard();
AddElem->pAdapterIndex = gpuHandles[GPUIndex];
(*NvAPI_GPU_getFullName)(AddElem->pAdapterIndex, nvNameAnsiString);
NV_RAM_TYPE RamType;
(*NvAPI_GPU_GetRamType)(AddElem->pAdapterIndex, &RamType);
//NV_GPU_MEMORY_INFO_EX memoryInfo = { sizeof(NV_GPU_MEMORY_INFO_EX) | (1 << 16) };
NV_DISPLAY_DRIVER_MEMORY_INFO memoryInfo = { NV_DISPLAY_DRIVER_MEMORY_INFO_VER };
(*NvAPI_GPU_GetMemoryInfo)(AddElem->pAdapterIndex, &memoryInfo);
//unsigned long BusWidth;
//(*NvAPI_GPU_GetRamBusWidth)(AddElem->pAdapterIndex, &BusWidth);
//unsigned long BankCount;
//(*NvAPI_GPU_GetRamBankCount)(AddElem->pAdapterIndex, &BankCount);
strcpy_s(AddElem->AdapterName, nvNameAnsiString);
strcpy_s(AddElem->MemoryType, RAMTYPESTR[RamType]);
AddElem->MemorySize = memoryInfo.availableDedicatedVideoMemory;
VideoCardList->Add(AddElem, 0, 0);
// Output :
// Input :
CRDNVidiaVideo::~CRDNVidiaVideo()
// Output :
// Input :
void CRDNVidiaVideo::Update(CRCArray<VideoCard*>* VideoCardList)
long NbElem = VideoCardList->GetNbElem();
for (long i = 0; i < NbElem; i++)
VideoCard* CurrentData = VideoCardList->GetData(i);
NV_GPU_THERMAL_SETTINGS nvgts;
nvgts.version = NV_GPU_THERMAL_SETTINGS_VER;
nvgts.count = 0;
nvgts.sensor[0].controller = -1;
nvgts.sensor[0].target = NVAPI_THERMAL_TARGET_GPU;
(*NvAPI_GPU_GetThermalSettings)(CurrentData->pAdapterIndex, 0, &nvgts);
NV_USAGES_INFO gpuUsages = { NV_USAGES_INFO_VER };
(*NvAPI_GPU_GetUsages)(CurrentData->pAdapterIndex, &gpuUsages);
long RPMSpeed = 0;
(*NvAPI_GPU_GetTachReading)(CurrentData->pAdapterIndex, &RPMSpeed);
NV_GPU_COOLER_SETTINGS coolerInfo = { NV_GPU_COOLER_SETTINGS_VER };
(*NvAPI_GPU_GetCoolerSettings)(CurrentData->pAdapterIndex, NVAPI_COOLER_TARGET_ALL, &coolerInfo);
CurrentData->Temperature = (float)nvgts.sensor[0].currentTemp;
CurrentData->ActivityPercent = gpuUsages.usages[2];
CurrentData->FanRPM = RPMSpeed;
CurrentData->FanPercent = coolerInfo.cooler[0].currentLevel;
#endif
