How to call NVML APIs?
I am trying to write a program that calls NVML APIs to monitor temperature and power of the GPU.
Here is the code:
#include “nvml.h”
void *sampling_func(void *arg)
nvmlReturn_t rc;
unsigned int *temp;
nvmlReturn_t DECLDIR nvmlInit();
nvmlUnit_t *arg2 = (nvmlUnit_t *) 0;
while(!testComplete)
rc= nvmlReturn_t DECLDIR nvmlUnitGetTemperature(*arg2, 2, temp);
if(rc!= NVML_SUCCESS)
printf(“NVML has some problems!\n”);
nvmlReturn_t DECLDIR nvmlShutdown();
return NULL;
However, when I compile it, it gives me error:
Power_Recording.cu(121): error: a value of type “nvmlUnit_t” cannot be used to initialize an entity of type “nvmlReturn_t”
I couldn’t find any information about how to initiate nvmlUnit_t in any of the nvml APIs. Can someone help me with it? How should I actually call nvmlReturn_t DECLDIR nvmlUnitGetTemperature ( nvmlUnit_t unit,
unsigned int type,
unsigned int * temp
From the posted code it is impossible to see which line of your program is line 121, but the following looks suspicious:
It looks like you may have inadvertently cut & paste the entire function prototype, when what you really wanted was to call the function like so:
rc = nvmlUnitGetTemperature (*arg2, 2, temp);
If you try to call rc = nvmlUnitGetTemperature (*arg2, 2, temp); like this , the compiler will tell you that "nvmlUnitGetTemperature " is not defined. When you add "nvmlReturn_t DECLDIR " in front of that function, then it wont report that mistake. line 121 is: rc= nvmlReturn_t DECLDIR nvmlUnitGetTemperature(*arg2, 2, temp);
But says instead that the line is not valid c; You need to leave that line as
And either find the right include file to include or at the start of your code define the prototype on it’s own line. I’m guessing that it should be
nvmlReturn_t DECLDIR nvmlUnitGetTemperature(nvmlUnit_t, int, unsigned int *);
By the way, you will probably get a segmentation fault as you should probably declare temp as
unsigned int temp;
and then pass a pointer to it (pass &temp rather than temp)
You can try out this sample code as a reference for writing an application that calls the NVML API.
Also if you are more comfortable working in Perl or Python, we have bindings available:
Python bindings
Perl bindings
Sample code for these are in their docs. All of the functionality of NVML is exposed in the bindings.
example.c:
|*      Copyright 2010-2011 NVIDIA Corporation.  All rights reserved.        *|
|*   NOTICE TO USER:                                                         *|
|*   This source code is subject to NVIDIA ownership rights under U.S.       *|
|*   and international Copyright laws.  Users and possessors of this         *|
|*   source code are hereby granted a nonexclusive, royalty-free             *|
|*   license to use this code in individual and commercial software.         *|
|*   NVIDIA MAKES NO REPRESENTATION ABOUT THE SUITABILITY OF THIS SOURCE     *|
|*   CODE FOR ANY PURPOSE. IT IS PROVIDED "AS IS" WITHOUT EXPRESS OR         *|
|*   IMPLIED WARRANTY OF ANY KIND. NVIDIA DISCLAIMS ALL WARRANTIES WITH      *|
|*   REGARD TO THIS SOURCE CODE, INCLUDING ALL IMPLIED WARRANTIES OF         *|
|*   MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR          *|
|*   PURPOSE. IN NO EVENT SHALL NVIDIA BE LIABLE FOR ANY SPECIAL,            *|
|*   INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, OR ANY DAMAGES          *|
|*   WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN      *|
|*   AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING     *|
|*   OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOURCE      *|
|*   CODE.        *|
|*   U.S. Government End Users. This source code is a "commercial item"      *|
|*   as that term is defined at 48 C.F.R. 2.101 (OCT 1995), consisting       *|
|*   of "commercial computer  software" and "commercial computer software    *|
|*   documentation" as such terms are used in 48 C.F.R. 12.212 (SEPT 1995)   *|
|*   and is provided to the U.S. Government only as a commercial end item.   *|
|*   Consistent with 48 C.F.R.12.212 and 48 C.F.R. 227.7202-1 through        *|
|*   227.7202-4 (JUNE 1995), all U.S. Government End Users acquire the       *|
|*   source code with only those rights set forth herein.                    *|
|*   Any use of this source code in individual and commercial software must  *|
|*   include, in the user documentation and internal comments to the code,   *|
|*   the above Disclaimer and U.S. Government End Users Notice.              *|
#include <stdio.h>
#include <nvml.h>
const char * convertToComputeModeString(nvmlComputeMode_t mode)
    switch (mode)
        case NVML_COMPUTEMODE_DEFAULT:
            return "Default";
        case NVML_COMPUTEMODE_EXCLUSIVE_THREAD:
            return "Exclusive_Thread";
        case NVML_COMPUTEMODE_PROHIBITED:
            return "Prohibited";
        case NVML_COMPUTEMODE_EXCLUSIVE_PROCESS:
            return "Exclusive Process";
        default:
            return "Unknown";
int main()
    nvmlReturn_t result;
    unsigned int device_count, i;
// First initialize NVML library
    result = nvmlInit();
    if (NVML_SUCCESS != result)
        printf("Failed to initialize NVML: %s\n", nvmlErrorString(result));
printf("Press ENTER to continue...\n");
        getchar();
        return 1;
result = nvmlDeviceGetCount(&device_count);
        printf("Failed to query device count: %s\n", nvmlErrorString(result));
        goto Error;
    printf("Found %d device%s\n\n", device_count, device_count != 1 ? "s" : "");
printf("Listing devices:\n");
    for (i = 0; i < device_count; i++)
        nvmlDevice_t device;
        char name[64];
        nvmlPciInfo_t pci;
        nvmlComputeMode_t compute_mode;
// Query for device handle to perform operations on a device
        // You can also query device handle by other features like:
        // nvmlDeviceGetHandleBySerial
        // nvmlDeviceGetHandleByPciBusId
        result = nvmlDeviceGetHandleByIndex(i, &device);
            printf("Failed to get handle for device %i: %s\n", i, nvmlErrorString(result));
            goto Error;
result = nvmlDeviceGetName(device, name, sizeof(name)/sizeof(name[0]));
            printf("Failed to get name of device %i: %s\n", i, nvmlErrorString(result));
            goto Error;
// pci.busId is very useful to know which device physically you're talking to
        // Using PCI identifier you can also match nvmlDevice handle to CUDA device.
        result = nvmlDeviceGetPciInfo(device, &pci);
            printf("Failed to get pci info for device %i: %s\n", i, nvmlErrorString(result));
            goto Error;
printf("%d. %s [%s]\n", i, name, pci.busId);
// This is a simple example on how you can modify GPU's state
        result = nvmlDeviceGetComputeMode(device, &compute_mode);
        if (NVML_ERROR_NOT_SUPPORTED == result)
            printf("\t This is not CUDA capable device\n");
        else if (NVML_SUCCESS != result)
            printf("Failed to get compute mode for device %i: %s\n", i, nvmlErrorString(result));
            goto Error;
        else
            // try to change compute mode
            printf("\t Changing device's compute mode from '%s' to '%s'\n",
                    convertToComputeModeString(compute_mode),
                    convertToComputeModeString(NVML_COMPUTEMODE_PROHIBITED));
result = nvmlDeviceSetComputeMode(device, NVML_COMPUTEMODE_PROHIBITED);
            if (NVML_ERROR_NO_PERMISSION == result)
                printf("\t\t Need root privileges to do that: %s\n", nvmlErrorString(result));
            else if (NVML_ERROR_NOT_SUPPORTED == result)
                printf("\t\t Compute mode prohibited not supported. You might be running on\n"
                       "\t\t windows in WDDM driver model or on non-CUDA capable GPU.\n");
                printf("\t\t Failed to set compute mode for device %i: %s\n", i, nvmlErrorString(result));
                goto Error;
            else
                printf("\t Restoring device's compute mode back to '%s'\n",
                        convertToComputeModeString(compute_mode));
                result = nvmlDeviceSetComputeMode(device, compute_mode);
                    printf("\t\t Failed to restore compute mode for device %i: %s\n", i, nvmlErrorString(result));
                    goto Error;
result = nvmlShutdown();
        printf("Failed to shutdown NVML: %s\n", nvmlErrorString(result));
printf("All done.\n");
    getchar();
    return 0;
Error:
    getchar();
    return 1;
Makefile:
ARCH   := $(shell getconf LONG_BIT)
ifeq (${ARCH},32)
  NVML_LIB := ../lib/
else ifeq (${ARCH},64)
  NVML_LIB := ../lib64/
else
 $(error Unknown architecture!)
endif
CFLAGS  := -I ../inc
LDFLAGS := -lnvidia-ml -L $(NVML_LIB)
example: example.o
	$(CC) $(LDFLAGS) $< -o $@
clean:
	-@rm -f example.o
	-@rm -f example
To build:
$ make
-Robert
Thanks a lot Robert. I will be trying it and report the results.
