Example codes are really sparse for the nvml API.
nvmlReturn_t nvmlUnitGetHandleByIndex (unsigned int
index, nvmlUnit_t *unit)
Parameters
index
The index of the target unit, >= 0 and < unitCount
unit
Reference in which to return the unit handle
Returns
‣ NVML_SUCCESS if unit has been set
‣ NVML_ERROR_UNINITIALIZED if the library has not been successfully initialized
‣ NVML_ERROR_INVALID_ARGUMENT if index is invalid or unit is NULL
‣ NVML_ERROR_UNKNOWN on any unexpected error
Code snippet:
#include <nvml.h>
nvmlReturn_t result;
unsigned int temp;
nvmlDevice_t device;
result = nvmlInit();
nvmlUnit_t unit;
unsigned int myint;
result = nvmlUnitGetHandleByIndex(0, &unit);
Is kicking NVML_ERROR_INVALID_ARGUMENT…
I found that I had to set CMAKE with:
target_link_libraries(04_nvml_testing “/usr/lib/x86_64-linux-gnu/libnvidia-ml.so”)
Before it could even do any nvml calls at all…
The reason is I am looking to make a manager set of C functions that will slow the GPU clock down as some of the algorithims I am running will burn out the PCI bus, so I am looking for some GPU speed auto adjusters, and logging management.
