Overclocking on Maxwell using NVML has been broken since Nvidia eventually fixed the overclocking functions. Currently overclocking only works on Pascal or newer GPUs. Since 580 will be the last driver branch to support Maxwell, it should really be fixed.
My guess is that the third party application is using these two APIs:
nvmlDeviceSetGpcClkVfOffset and nvmlDeviceSetMemClkVfOffset
From the nvml api docs:
Global nvmlDeviceSetGpcClkVfOffset
Will be deprecated in a future release. Use nvmlDeviceSetClockOffsets instead. It works on Maxwell onwards GPU architectures.
Global nvmlDeviceSetMemClkVfOffset
It looks like the application will need to be updated to use nvmlDeviceSetClockOffsets
(Actually, it looks like maybe you own ‘Envious FX’ so hopefully you can easily update to the newer API)
The image clearly shows both overclocking functions. The first section(“Overclocking”) clearly shows the first two you mention, while the second(“Performance State 0 Overclocking”) clearly shows the one that is supposedly supported on Maxwell.
Here is me setting a value on my 4060 using nvidia-settings:
And here is the 960(after an app restart because nvidia-settings doesn’t notify in GUI that it failed):
An “internal driver error” is even shown for the 960 when none is shown for the 4060:
sudo nvidia-settings
pci id for fd 34: 10de:1401, driver (null)
pci id for fd 35: 10de:1401, driver (null)
pci id for fd 34: 10de:2882, driver (null)
pci id for fd 35: 10de:2882, driver (null)
error: XDG_RUNTIME_DIR is invalid or not set in the environment.
(nvidia-settings:3443): GLib-GObject-CRITICAL **: 20:08:23.420: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
libEGL warning: pci id for fd 63: 10de:2882, driver (null)
pci id for fd 64: 10de:2882, driver (null)
pci id for fd 65: 10de:2882, driver (null)
libEGL warning: egl: failed to create dri2 screen
ERROR: An internal driver error occurred
Please, just send a PM to the NVAPI team and ask them to help the NVML team on this. Just send a link to this thread and tell them to look at NvAPI_GPU_GetPstates20 and the set counterpart. They should know what to do. I hope, anyway.
Would someone PLEASE just send a PM to someone who knows how to fix this.
So it’s now over 10 days since I revived this thread and almost 3 months since I originally posted this thread. It’s safe to say that no new 580 driver will be released with a fix. Not a single employee at Nvidia presumably sent a PM to the requested team to get this fixed. Can’t say i’m surprised.
For people who are just tuning in or reading this in the future, allow me to go in-depth into this… fiasco.
3 years ago with the 515.43.04 drivers, Nvidia introduced nvmlDeviceGetGpcClkVfOffset and nvmlDeviceSetGpcClkVfOffset with the RTX 4090 drivers. Upon release, there was zero documentation as to what was actually supported by this function. Given it was released with the 4090, it could be assumed it was for Ada only. In actuality, it worked on Pascal(not at first but does now?) and newer with Maxwell GPUs throwing an error. There was absolutely no way to get valid min and max clock values, making setting a value a complete shot in the dark. Does the function fill the pointer/accept a mhz value or a khz value? Couldn’t tell you!
Later in 520.56.06 Nvidia introduced nvmlDeviceGetMemClkVfOffset and nvmlDeviceSetMemClkVfOffset with the same exact issues except now it gets even better: these values secretly use the 2x DDR clock speeds that everyone just loved from NV-X-Control on both Windows AND Linux.
For people who don’t get why that’s an issue: on Windows, overclocking utilities use the 1x multiplier value. Someone could attempt for example to apply a 1000mhz OC that they would normally apply under Linux in Windows and crash the GPU.
But there’s more! It turns out that if you applied a negative memory overclock value, nvmlDeviceGetMemClkVfOffset would underflow:
(Notice a complete lack of a response by anyone at Nvidia on that bug report.)
in 535.43.02, Nvidia finally added a way to get the graphics/memory clock offset min/max values, a year after the initial functions were added. Better late than never, right?
Except, the min memory clock offset value had the same bug, making it absolutely useless. I remember just hardcoding my HAL to return a 0mhz min offset value at the time just to get it to work in GUI and even then it didn’t work because my app sets the slider and text box values to the current attribute value on launch, so if you have a negative value, it’s going to be broken anyway!
So now Nvidia added this new API and it’s a train wreck. Nothing works like it should and it doesn’t even support Maxwell GPUs. What’s the solution? Deprecate and start new with something that will work for all currently supported GPU architectures.
555.42.02 is released, a year ago and the subject of this thread, officially marking everything that has been added up until now as deprecated and claiming that the new functions nvmlDeviceGetClockOffsets andnvmlDeviceSetClockOffsets supported Maxwell GPUs.
As you can see from this thread, they do not, in fact, support Maxwell GPUs. It’s a lie.
But, that isn’t the only issue. Not only does this new API not work on Maxwell, it uses the same struct type for getting and setting(dangling fields) AND it has zero indication as to what performance states are overclockable.
Want to get which performance states are overclockable? Hope you like parsing strings, because that information can only be found in nvmlDeviceGetPerformanceModes, which takes in a struct point who’s second field is a string.
But, if you can believe it, it gets even better! The string that it returns reports wrong information:
perf=0, nvclock=210, nvclockmin=210,
nvclockmax=405, nvclockeditable=1, memclock=405, memclockmin=405,
memclockmax=405, memclockeditable=1, memTransferRate=810,
memTransferRatemin=810, memTransferRatemax=810, memTransferRateeditable=1 ;
perf=1, nvclock=210, nvclockmin=210, nvclockmax=3105, nvclockeditable=1,
memclock=810, memclockmin=810, memclockmax=810, memclockeditable=1,
memTransferRate=1620, memTransferRatemin=1620, memTransferRatemax=1620,
memTransferRateeditable=1 ; perf=2, nvclock=210, nvclockmin=210,
nvclockmax=3105, nvclockeditable=1, memclock=5001, memclockmin=5001,
memclockmax=5001, memclockeditable=1, memTransferRate=10002,
memTransferRatemin=10002, memTransferRatemax=10002, memTransferRateeditable=1
; perf=3, nvclock=210, nvclockmin=210, nvclockmax=3105, nvclockeditable=1,
memclock=8251, memclockmin=8251, memclockmax=8251, memclockeditable=1,
memTransferRate=16502, memTransferRatemin=16502, memTransferRatemax=16502,
memTransferRateeditable=1 ; perf=4, nvclock=210, nvclockmin=210,
nvclockmax=3105, nvclockeditable=1, memclock=8501, memclockmin=8501,
memclockmax=8501, memclockeditable=1, memTransferRate=17002,
memTransferRatemin=17002, memTransferRatemax=17002, memTransferRateeditable=1
Every nvclockeditable, memclockeditable, and memTransferRateeditable is always set to 1, which is WRONG.
Edit: forgot to mention, most of the information is duplicated. Yes, Nvidia already had all of this information or could have inferred it except what performance state were overclockable, something that could have been added as a field to nvmlClockOffset_v1_t. Why? What is the point of this existing?
To be clear, I don’t really care about this. I know of far better and reliable ways to overclock Maxwell and newer GPUs than these broken functions. What I’m upset by is this consistent and prolific lack of care and implementing things half baked and broken in NVML. If you think overclocking APIs are the only things I’m talking about, you are wrong in more ways than you could possibly imagine.
Performance limiters will report “Unknown Error” apparently if one of them is invalid for a given GPU.
There is no retrievable reset value for “Acoustic Threshold”(AKA, temperature limit).
There is no way to get graphics/memory clock locked values.
Nvidia added the ability to adjust fan speeds without the ability the reset the fan mode to Auto. But it gets better: the documentation for nvmlDeviceSetFanSpeed_v2 says to use nvmlDeviceSetDefaultFanSpeed_v2 to reset the fan mode except that’s not what it does. What it does do is set to either 16 or 30 depending on the GPU, as the target fan speed would be shown by default on a fresh boot. Yes, by following Nvidia’s own advice on how not to “burn” your GPU, you can “burn” your GPU. Wonderful.
NVML has major API consistency issues, with some structs having a version field(and padding fields, what?) and some not, defining int constants instead of using already established enum values, things that could be and should be enums are instead int constants(like fan modes), deprecating long existing functions for a more generic magic number approach, marking some functions as deprecated for new GPU archs, and way more which make third party developer’s lives an absolute nightmare trying to support everything.
I could go on, really.
It’s baffling that any developer of any company would release APIs and libraries in the state that Nvidia does.
It’s humorous that Nvidia’s employee denies third party developers access to their atleast functional APIs because “we don’t want to support you” but then refuse to do the absolute minimum for APIs that are public and are supposedly being supported.
It’s insanity that anyone would use NVML. It’s an absolute disaster of an API and at this point, needs to be thrown in the trash bin. Unfortunately, there is no other option.
We’ve read your feedback on NVML and wanted to let you know we take developer experience seriously at NVIDIA. The points you raised about APIs and documentation have been passed on to the team. We’re always looking for ways to improve, so your comments are on our radar.
Nvidia’s employees have ignored this report. Nvidia’s employees have ignored my bug report on Github(yes, it’s fixed but was still ignored). Nvidia’s employees have ignored multiple bug reports on this forum from me and others. Nvidia’s employees have both publicly and privately claimed to contact internal teams to get answers on various questions on NVML and other APIs only for no answer to ever be given.
I have a really hard time believing that this statement is anything more than a false reassurance while nothing gets done. If you actually take this seriously then do something tangible. Talk is cheap, actions are not.
I can’t make a new post in the NVML section for some reason(read only?) but nvmlDeviceGetEncoderSessions and the other generic video encoder stat functions look to be broken on newer drivers too.
In case anyone was under any illusion that this was going to get fixed, no, it has not with the newest 580/581 drivers. This would have taken barely any time to fix or better yet, Nvidia release a new 580 NVAPI developer release with the overclocking APIs included. Absolutely nothing was done.
590 is here and of course this was never fixed. That isn’t surprising. What kind of is is that Nvidia either locked the NVML forum so that no new posts could be made or i’ve been banned from it specifically. Either way, shows how much Nvidia cares about developer experience.
But I’m not here just to resurrect this dead horse.
I decided to get myself a 5060 TI while I still had the chance before the RAM apocalypse happened and they were below MSRP. Curious as to how many of the new Blackwell NVML APIs are supported on desktop Blackwell GPU, I probed nvidia-smi just as a quick test.
Turns out desktop Blackwell supports Graphics Performance Metrics(GPM) and PRM registers. What are PRM registers? Couldn’t tell you. From what I gather online, it’s some Blackwell networking API for connecting GPUs together. Why is it supported on desktop? How does it work? Couldn’t tell you.
But PRM registers isn’t why i’m making this. I’m sure it’s broken in all kinds of fun and interesting ways, but my issue is with GPM.
Lets start with documentation.
If you read the documentation in the NVML header here:
and here:
It’s heavily suggested that this is a server GPU only feature and isn’t even supposed to be available for desktop GPUs. It also says “fully supported devices”. What does that even mean? The NVML header says:
So according to your own documentation, GPM shouldn’t even be available for desktop. Why is it? If this was a case of documentation that hasn’t been updated then fine, but there are probably around a 100 lines in the 590 headers of just random edits and changes that didn’t need to be done. Why is Nvidia not improving documentation where it actually matters?
In the enum values for GPM, a description is given as to what each value represents, but only for the original hopper values. None of the Blackwell values have any descriptions:
But hey, that’s just documentation. Atleast the API is well thought out and designed, right?
No. It is not.
If you read the header, you’ll notice this little tidbit:
This isn’t unusual. Nvidia does versioned structs all the time. What’s the big deal?
#define NVML_GPM_METRICS_GET_VERSION 1
It isn’t even setup correctly! Every other versioned struct in NVML that i’m aware of uses the NVML_STRUCT_VERSION macro like this:
But hey, maybe Nvidia decided that the old way of versioning structs was bad and decided to change it.
Except, no, that isn’t the case:
So the whole API versioning part of it is just broken.
(nvmlGpmSupport_t is also broken in this way, because why not.)
But there’s more!
If you read that same enum value you’ll notice something. It skips values:
Why is that important? Well, if you wanted to poll every single valid metric in a single time frame, you’re going to need to either manually insert every single enum value or use a for loop to set the field specifying what you want to get.
That field, for whatever reason, is an unsigned int:
So not only is the enum values not ordinal scale(or, atleast, in sequential order), but the field you set isn’t safe.
This API would have worked if:
A). The enums were in sequence.
and
B). The type was nvmlGpmMetricId_t.
Since you can typecast ints to enums but only if the enum has that backing value otherwise it’s undefined behaviour. If you really wanted to keep the unsigned int path open, a union could have been used, but no, that wasn’t done. It would have been better to provide a function that returns an array of all the valid values ahead of time, but even without it, this could have been done SO much better.
While i’m on the subject of API, I might as well point out that the function names do not align with existing NVML naming conventions. Is it the end of the world? No. Is it weird? Yes.
But hey, that’s just API design. Atleast the API works and reports valid information that makes sense when you invoke it, right?
No. It does not.
Here is my working code in Java:
public static void main(String[] args)
System.out.println(nvml_h.INSTANCE.nvmlInit_v2(0));
NativePointer<nvmlDevice_t> gpuPointer = new NativePointer<>(nvmlDevice_t.METADATA);
System.out.println(nvml_h.INSTANCE.nvmlDeviceGetHandleByIndex_v2(0, gpuPointer));
NativeEnum32<nvmlEnableState_t> enabledPointer = new NativeEnum32<>(nvmlEnableState_t.DISABLED);
System.out.println(nvml_h.INSTANCE.nvmlGpmQueryIfStreamingEnabled(gpuPointer.get(), enabledPointer));
System.out.println("GPM Streaming State: " + enabledPointer.get());
nvmlGpmMetricsGet_t metricsGet = new nvmlGpmMetricsGet_t();
NativeInt32 versionField = metricsGet.getField(0);
versionField.set(1);
NativeInt32 numMetricsField = metricsGet.getField(1);
numMetricsField.set(nvmlGpmMetricId_t.values().length);
NativePointer<nvmlGpmSample_t> firstSample = metricsGet.getField(2);
NativePointer<nvmlGpmSample_t> secondSample = metricsGet.getField(3);
NativeStructArray<nvmlGpmMetric_t> metrics = metricsGet.getField(4);
System.out.println(nvml_h.INSTANCE.nvmlGpmSampleAlloc(firstSample));
System.out.println(nvml_h.INSTANCE.nvmlGpmSampleAlloc(secondSample));
System.out.println(nvml_h.INSTANCE.nvmlGpmSampleGet(gpuPointer.get(), firstSample.get()));
Thread.sleep(100);
System.out.println(nvml_h.INSTANCE.nvmlGpmSampleGet(gpuPointer.get(), secondSample.get()));
for(int i = 0; i < nvmlGpmMetricId_t.values().length; i++)
nvmlGpmMetric_t metric = metrics.get(i);
NativeEnum32<nvmlGpmMetricId_t> idField = metric.getField(0);
idField.set(nvmlGpmMetricId_t.values()[i]);
System.out.println(nvml_h.INSTANCE.nvmlGpmMetricsGet(metricsGet));
System.out.println("ID: " + idField.get());
NativeEnum32<nvmlReturn_t> returnValueField = metric.getField(1);
System.out.println("\tReturn Value: " + returnValueField.get());
NativeFloat64 valueField = metric.getField(2);
System.out.println("\tValue: " + valueField.get());
I’m not going to print everything it outputs, but I will show this:
NVML_SUCCESS
NVML_SUCCESS
NVML_SUCCESS
GPM Streaming State: DISABLED
NVML_SUCCESS
NVML_SUCCESS
NVML_SUCCESS
NVML_SUCCESS
NVML_SUCCESS
Return Value: NVML_SUCCESS
Value: 2.5145760119342317
Value: 0.021445383604039768
Value: 0.0021317195775625328
Value: 8.739369845639831E-7
Value: 0.0
Return Value: NVML_ERROR_INVALID_ARGUMENT
Value: 0.0
First off, GPM works even if GPM streaming is disabled. Unless it’s referring to something else, that makes zero sense.
Secondly, the API reports NVML_SUCCESS for hardware that does not exist. A 5060 TI does not have a 7th video decoder! It doesn’t (AFAIK) support NVLink either. Every single metric returns NVML_SUCCESS except for if you include the MAX attribute by accident, but clearly that’s a hard coded check because like half of the metrics should be returning an error too as far as I can tell.
It’s absolutely insane that something as broken and poorly thought out like this is released by a multi trillion dollar company. It’s even more insane that no effort has went into fixing it for 3 years:
https://github.com/NVIDIA/nvidia-settings/blame/main/src/nvml.h#L13010
yet, once again, time can be spent making small insignificant changes like in recent driver releases. Between the broken, buggy driver releases(see the Linux graphics forum) and this, what is Nvidia even doing?
Apparently the roller coaster never ends.
On Blackwell, performance limiters are just broken. Even if a GPU is being throttled due to hitting power limits, nothing is reported by any NVML based application:
(normally it’d be running at around 2950mhz)
And yes, that includes nvidia-smi.
Hilariously, if the GPU is “idle”, then the performance limiters report “power”. Blackwell has been a thing for the desktop for almost a year now and no one at Nvidia has noticed and fixed it. Incredible, really.
But hey, maybe Nvidia has a new API for getting this information and no one(including Nvidia themselves), has updated to it yet. Lets check the NVML header!
Oh, the old function that almost every single application is using is deprecated. Surely Nvidia replaced it with something meaningful to warrant such a deprecation, right?
nvmlReturn_t DECLDIR nvmlDeviceGetSupportedClocksEventReasons(nvmlDevice_t device, unsigned long long *supportedClocksEventReasons);
It’s literally a name change. Nothing is different between the two. This could have been an implementation modification. What is even the point of this?
And it turns out that there is zero functional difference between the two. It’s still entirely broken in the same way the throttle variant was.
What is even the point of deprecating the old version? Is Nvidia letting an intern using ChatGPT make design decisions without a sign off from someone higher up?
You won’t give third party developers access to your better low level APIs but you’ll waste everyone’s time, including your own, creating nonsensical poorly documented public APIs that do not work and make it impossible for third party developers to support everything. Like what even is this:
You deprecated this in CUDA 13 and have it marked for removal in 14. Why?
And then you have other nonsense like this:
What is the point of any of this? You have enums for GPU archs. Is whatever terrible AI you’re using not trained on code that uses switch-case statements?
Bit of an update to this:
Apparently all GPM functions return a success value on both Ada and Windows. Every single value returned is 0. Any application that depends on function return code values to determine what should be shown would be broken because of this. And no, you probably can’t “just” do an architecture check because NVML’s function support is so schizophrenic that there are probably desktop Blackwell GPUs out there that don’t support GPM either.
Besides that, while i’m hear, let me detail yet another issue that was surfaced:
TL;DR: Nvidia decided to change slowdown/shutdown temperatures as an offset to the max temp you can set as a temp limit. Some GPUs, including desktop ones, don’t even support this, so the only way to get the value to do the offset calculation is by adding the current temp with the margin temp, an API that didn’t even exist until recently and a flawed way of doing it to begin with. No one at Nvidia could tell anyone about this until recently or document it.
By the way, all the bugs and issues listed so far isn’t even the complete list of how absolutely broken NVML is.
