nvapi gpu thermal info
Hi everyone,
I wrote a code, using the library nvapi, in order to monitor the temperature of my graphics card (tesla k40m) when executing a kernel.
NvPhysicalGpuHandle phys[NVAPI_MAX_PHYSICAL_GPUS*2];
    ret = NvAPI_EnumTCCPhysicalGPUs(phys, &cnt);
    if (ret != NVAPI_OK){
        NvAPI_ShortString string;
        NvAPI_GetErrorMessage(ret, string);
    NvAPI_ShortString name;
    NV_GPU_THERMAL_SETTINGS thermal;
    ret = NvAPI_GPU_GetFullName(*phys, name);
        //printf("NVAPI NvAPI_GPU_GetFullName: %s\n", string);
    //printf("Name: %s\n", name);
    thermal.version = NV_GPU_THERMAL_SETTINGS_VER;
    ret = NvAPI_GPU_GetThermalSettings(*phys,0, &thermal);
        //printf("NVAPI NvAPI_GPU_GetThermalSettings: %s\n", string);
    return thermal.sensor[0].currentTemp;
My problem is that I get output values that are very different from those of other test software found online (like gpu-z).
What am I doing wrong?
Thanks in advance
Domenico
I use version 2 and this code works for the core temperature
NvAPI_Status nvapiStatus;
NV_GPU_THERMAL_SETTINGS result;
result.version = NV_GPU_THERMAL_SETTINGS_VER_2;
result.sensor[0].target = NVAPI_THERMAL_TARGET_GPU;
result.sensor[0].controller = NVAPI_THERMAL_CONTROLLER_GPU_INTERNAL;
nvapiStatus = NvAPI_GPU_GetThermalSettings (<your handle>, NVAPI_THERMAL_TARGET_NONE, &result);
if (nvapiStatus != NVAPI_OK) return 0;
return result.sensor[0].currentTemp;
