Hi NV_Team,
We have 12 GMSL cameras on AGX Orin with MAX96712, v4l2 open camera success, but nvarguscamerasrc can not open camera with some errors.
nvidia@ubuntu:~$ v4l2-ctl -V --set-fmt-video width=1936,height=1096,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video0
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'RG12' (12-bit Bayer RGRG/GBGB)
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
nvidia@ubuntu:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12' ! nvvidconv flip-method=0 ! 'video/x-raw,width=1920, height=1080' ! nvvidconv ! nvegltransform ! nveglglessink -e
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 0.000000, max 30.000000; Exposure Range min 59000, max 33333000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:734 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:245 (propagating)
Redistribute latency...
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Pipeline construction is invalid, please add queues.
Additional debug info:
../libs/gst/base/gstbasesink.c(1249): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
Not enough buffering available for the processing deadline of 0:00:00.015000000, add enough queues to buffer 0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:04.022689860
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
Freeing pipeline ...
tegra-camera-platform {
status = "okay";
compatible = "nvidia, tegra-camera-platform";
/* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <16>;
max_lane_speed = <15000000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
status = "okay";
module0 {
status = "okay";
badge = "imx390_bottomleft_liimx390";
position = "bottomleft";
orientation = "1";
drivernode0 {
status = "okay";
pcl_id = "v4l2_sensor";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@0/imx390_2a@2a";
module1 {
status = "okay";
badge = "imx390_centerleft_liimx390";
position = "centerleft";
orientation = "1";
drivernode0 {
status = "okay";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@0/imx390_2b@2b";
module2 {
status = "okay";
badge = "imx390_centerright_liimx390";
position = "centerright";
orientation = "1";
drivernode0 {
status = "okay";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@0/imx390_2c@2c";
module3 {
status = "okay";
badge = "imx390_topleft_liimx390";
position = "topleft";
orientation = "1";
drivernode0 {
status = "okay";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@0/imx390_2d@2d";
module4 {
status = "okay";
badge = "imx390_bottomright_liimx390";
position = "bottomright";
orientation = "1";
drivernode0 {
status = "okay";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@1/imx390_2a@2a";
module5 {
status = "okay";
badge = "imx390_topright_liimx390";
position = "topright";
orientation = "1";
drivernode0 {
status = "okay";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@1/imx390_2b@2b";
module6 {
status = "okay";
badge = "imx390_bottomcenter_liimx390";
position = "bottomcenter";
orientation = "1";
drivernode0 {
status = "okay";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@1/imx390_2c@2c";
module7 {
status = "okay";
badge = "imx390_topcenter_liimx390";
position = "topcenter";
orientation = "1";
drivernode0 {
status = "okay";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@1/imx390_2d@2d";
module8 {
status = "okay";
badge = "imx390_frontcenter_liimx390";
position = "frontcenter";
orientation = "1";
drivernode0 {
status = "okay";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@2/imx390_2a@2a";
module9 {
status = "okay";
badge = "imx390_rearcenter_liimx390";
position = "rearcenter";
orientation = "1";
drivernode0 {
status = "okay";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@2/imx390_2b@2b";
nvargus-daemon logs errors
(Argus) Error BadParameter: Unidentified sensor placement (in src/common/ScfTranslate.cpp, function fromScfSensorPlacement(), line 661)
Full logs here:
nvidia@ubuntu:~$ sudo service nvargus-daemon stop
nvidia@ubuntu:~$ sudo enableCamPclLogs=5 nvargus-daemon
=== gst-launch-1.0[2887]: Connection established (FFFF9E1BB840)NvPclSetHotplugCallback: ++++++++++++++++++++++
---- Imager: Calibration blob file handling supported in this build ----
NvPclHwGetModuleList: OFParserListModules Succeeded
NvPclModuleListInitialize: numBuiltinModules 10 +++
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module6
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module7
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module8
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module9
NvPclHwGetModuleCalib: Couldn't found calibration, Part name didn't match: "liimx390"
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
NvPclHwPrintModuleDefinition -- Name: imx390_bottomleft_liimx390
NvPclHwPrintModuleDefinition -- Position: 0
NvPclHwPrintModuleDefinition -- CalibrationData Found: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].Name: v4l2_sensor
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 9-002a
NvPclHwPrintModuleDefinition -- Name: imx390_centerleft_liimx390
NvPclHwPrintModuleDefinition -- Position: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 9-002b
NvPclHwPrintModuleDefinition -- Name: imx390_centerright_liimx390
NvPclHwPrintModuleDefinition -- Position: 2
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 9-002c
NvPclHwPrintModuleDefinition -- Name: imx390_topleft_liimx390
NvPclHwPrintModuleDefinition -- Position: 3
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 9-002d
NvPclHwPrintModuleDefinition -- Name: imx390_bottomright_liimx390
NvPclHwPrintModuleDefinition -- Position: 4
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 10-002a
NvPclHwPrintModuleDefinition -- Name: imx390_topright_liimx390
NvPclHwPrintModuleDefinition -- Position: 5
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 10-002b
NvPclHwPrintModuleDefinition -- Name: imx390_bottomcenter_liimx390
NvPclHwPrintModuleDefinition -- Position: 6
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 10-002c
NvPclHwPrintModuleDefinition -- Name: imx390_topcenter_liimx390
NvPclHwPrintModuleDefinition -- Position: 7
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 10-002d
NvPclHwPrintModuleDefinition -- Name: imx390_frontcenter_liimx390
NvPclHwPrintModuleDefinition -- Position: 8
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 11-002a
NvPclHwPrintModuleDefinition -- Name: imx390_rearcenter_liimx390
NvPclHwPrintModuleDefinition -- Position: 9
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: imx390 11-002b
NvPclModuleListInitialize: numBuiltinModules 10 ---
NvPclModuleListInitialize: NvPclModule list[0]: imx390_bottomleft_liimx390 position 0 numBuiltinModules 10
NvPclModuleListInitialize: NvPclModule list[1]: imx390_centerleft_liimx390 position 1 numBuiltinModules 10
NvPclModuleListInitialize: NvPclModule list[2]: imx390_centerright_liimx390 position 2 numBuiltinModules 10
NvPclModuleListInitialize: NvPclModule list[3]: imx390_topleft_liimx390 position 3 numBuiltinModules 10
NvPclModuleListInitialize: NvPclModule list[4]: imx390_bottomright_liimx390 position 4 numBuiltinModules 10
NvPclModuleListInitialize: NvPclModule list[5]: imx390_topright_liimx390 position 5 numBuiltinModules 10
NvPclModuleListInitialize: NvPclModule list[6]: imx390_bottomcenter_liimx390 position 6 numBuiltinModules 10
NvPclModuleListInitialize: NvPclModule list[7]: imx390_topcenter_liimx390 position 7 numBuiltinModules 10
NvPclModuleListInitialize: NvPclModule list[8]: imx390_frontcenter_liimx390 position 8 numBuiltinModules 10
NvPclModuleListInitialize: NvPclModule list[9]: imx390_rearcenter_liimx390 position 9 numBuiltinModules 10
NvPclHwScanExternalCameras -- adding video9 to discover list
NvPclHwScanExternalCameras -- adding video8 to discover list
NvPclHwScanExternalCameras -- adding video7 to discover list
NvPclHwScanExternalCameras -- adding video6 to discover list
NvPclHwScanExternalCameras -- adding video5 to discover list
NvPclHwScanExternalCameras -- adding video4 to discover list
NvPclHwScanExternalCameras -- adding video3 to discover list
NvPclHwScanExternalCameras -- adding video2 to discover list
NvPclHwScanExternalCameras -- adding video1 to discover list
NvPclHwScanExternalCameras -- adding video0 to discover list
NvPclModuleListInitialize: numPlugableModules 10 +++
NvPclHwAddModules isVirtual 1 ^^^^^^^^
NvPclHwAddModules isVirtual 0 ^^^^^^^^
NvPclModuleListInitialize: numPlugableModules 0 ---
getHotplugMonitor: Getting hotplug monitor instance
initializeHotplug++
hotPlugfunc ++
addWatch: Watch added wd='1'
CheckProcDTExists: INFO: accessing /proc/device-tree/tegra-virtual-camera-platform/modules; No such file or directory
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
setHotplugCallback: Registered new callback client
NvPclSetHotplugCallback: ----------------------
hotPlugfunc: reading from inotify FD, Thread waiting
NvPclOpen: ++++++++++++++++++++++
NvPclStateControllerOpen: Found GUID 0 match at index[0]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98a1aaf0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98a2ce60
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98a2c690
NvPclHwInitializeModule: allocate overrides pathname @ 0xaaab1798fe90
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98aad560
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98be62d0
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16
CheckOverridesPermissions: stat(/Calib/camera_override.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/camera_overrides.isp] 2/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/camera_overrides.isp] 5/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/camera_overrides.isp) call failed
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_bottomleft_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_bottomleft_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_bottomleft_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_bottomleft_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_bottomleft_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_bottomleft_liimx390.isp) call failed
---- imager: No override file found. ----
Imager: looking for override file [/mnt/factory/camera/factory.bin] 1/16
Imager: looking for override file [/Calib/factory.bin] 2/16
Imager: looking for override file [/Calib/calibration.bin] 3/16
Imager: looking for override file [(null)] 4/16
Imager: looking for override file [(null)] 5/16
Imager: looking for override file [(null)] 6/16
Imager: looking for override file [(null)] 7/16
Imager: looking for override file [(null)] 8/16
Imager: looking for override file [(null)] 9/16
Imager: looking for override file [(null)] 10/16
Imager: looking for override file [(null)] 11/16
Imager: looking for override file [(null)] 12/16
Imager: looking for override file [(null)] 13/16
Imager: looking for override file [(null)] 14/16
Imager: looking for override file [(null)] 15/16
Imager: looking for override file [(null)] 16/16
Imager: looking for override file [/data/vendor/nvcam/settings/factory.bin] 1/16
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_bottomleft_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_bottomleft_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_bottomleft_liimx390.bin] 4/16
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_sensor)
NvPclCreateDriver: Found a Driver name match (v4l2_sensor)
NvPclConnectDrivers: hImager was NULL, creating new imager
NvPclInitializeDrivers: v4l2_sensor ++++++++++++++++++
OFDPropertyGetString: could not read property [devnode-bus]
OFDPropertyGetString: could not read property [use_decibel_gain]
OFDPropertyGetString: could not read property [delayed_gain]
OFDPropertyCopyToLong: could not read property [has-eeprom]
OFDPropertyGetString: could not read property [supports-alt-exp]
OFDPropertyGetString: could not read property [sync_sensor]
OFDPropertyGetString: could not read property [type]
loadSubType: Sensor type missing in DT, 206
OFDPropertyCopyToLong: could not read property [set_mode_delay_ms]
OFDPropertyGetString: could not read property [mode0.phy_mode]
OFDPropertyCopyToLong: could not read property [mode0.dynamic_pixel_bit_depth]
OFDPropertyCopyToFloat: could not read property [mode0.gain_step_pitch]
OFDPropertyCopyToLong: could not read property [mode0.clk_settletime]
OFDPropertyCopyToLong: could not read property [mode0.embedded_metadata_width]
OFDPropertyCopyToLong: could not read property [mode0.lane_polarity]
OFDPropertyGetString: could not read property [mode0.x_start]
OFDPropertyGetString: could not read property [mode0.y_start]
OFDPropertyGetString: could not read property [mode0.x_end]
OFDPropertyGetString: could not read property [mode0.y_end]
OFDPropertyGetString: could not read property [mode0.h_scaling]
OFDPropertyGetString: could not read property [mode0.v_scaling]
initialize: Loaded Driver: 1 Modes Available--------------
NvPclInitializeDrivers: v4l2_sensor ------------------
NvPclOpen: ----------------------
LSC: LSC surface is not based on full res!
NvPclStateControllerOpen: Found GUID 1 match at index[1]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d191b0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d002a0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ab3c50
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ab3ce0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ab3290
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ab3320
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_centerleft_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_centerleft_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_centerleft_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_centerleft_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_centerleft_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_centerleft_liimx390.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_centerleft_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_centerleft_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_centerleft_liimx390.bin] 4/16
NvPclStateControllerOpen: Found GUID 2 match at index[2]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d71b30
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ccc5b0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d89190
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98cd83c0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ccc640
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98aaf0a0
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_centerright_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_centerright_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_centerright_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_centerright_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_centerright_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_centerright_liimx390.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_centerright_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_centerright_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_centerright_liimx390.bin] 4/16
NvPclStateControllerOpen: Found GUID 3 match at index[3]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d15b20
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d77e40
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ab1330
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d15bb0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98aaec20
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98aaecb0
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_topleft_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_topleft_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_topleft_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_topleft_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_topleft_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_topleft_liimx390.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_topleft_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_topleft_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_topleft_liimx390.bin] 4/16
NvPclStateControllerOpen: Found GUID 4 match at index[4]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d710d0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98cd8250
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98aae010
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ab2ff0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98cca500
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98cc7c50
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_bottomright_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_bottomright_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_bottomright_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_bottomright_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_bottomright_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_bottomright_liimx390.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_bottomright_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_bottomright_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_bottomright_liimx390.bin] 4/16
NvPclStateControllerOpen: Found GUID 5 match at index[5]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d70170
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d18700
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d165a0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d70200
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ccc2c0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d78830
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_topright_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_topright_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_topright_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_topright_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_topright_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_topright_liimx390.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_topright_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_topright_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_topright_liimx390.bin] 4/16
NvPclStateControllerOpen: Found GUID 6 match at index[6]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff990c1510
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98c939c0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98c93a50
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d88a00
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d88a90
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d17e60
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_bottomcenter_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_bottomcenter_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_bottomcenter_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_bottomcenter_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_bottomcenter_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_bottomcenter_liimx390.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_bottomcenter_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_bottomcenter_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_bottomcenter_liimx390.bin] 4/16
NvPclStateControllerOpen: Found GUID 7 match at index[7]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98c8f5a0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98c143c0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98ac54d0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98aad790
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d172e0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff990c1ee0
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_topcenter_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_topcenter_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_topcenter_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_topcenter_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_topcenter_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_topcenter_liimx390.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_topcenter_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_topcenter_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_topcenter_liimx390.bin] 4/16
NvPclStateControllerOpen: Found GUID 8 match at index[8]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff992d5e80
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98c19db0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff992d5f10
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98c8ff80
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98cc7e20
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d18a60
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_frontcenter_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_frontcenter_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_frontcenter_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_frontcenter_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_frontcenter_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_frontcenter_liimx390.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_frontcenter_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_frontcenter_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_frontcenter_liimx390.bin] 4/16
NvPclStateControllerOpen: Found GUID 9 match at index[9]
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98c13580
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98cc38c0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98cc3830
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98d70be0
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98c93750
NvPclHwInitializeModule: allocate overrides pathname @ 0xffff98cc3950
LoadOverridesFile: looking for override file [/data/vendor/nvcam/settings/imx390_rearcenter_liimx390.isp] 6/16
CheckOverridesPermissions: stat(/data/vendor/nvcam/settings/imx390_rearcenter_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/imx390_rearcenter_liimx390.isp] 7/16
CheckOverridesPermissions: stat(/opt/nvidia/nvcam/settings/imx390_rearcenter_liimx390.isp) call failed
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/imx390_rearcenter_liimx390.isp] 8/16
CheckOverridesPermissions: stat(/var/nvidia/nvcam/settings/imx390_rearcenter_liimx390.isp) call failed
Imager: looking for override file [/data/vendor/nvcam/settings/imx390_rearcenter_liimx390.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/imx390_rearcenter_liimx390.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/imx390_rearcenter_liimx390.bin] 4/16
=== gst-launch-1.0[2887]: CameraProvider initialized (0xffff98c93ae0)NvPclPowerOn: +++++++++++
NvPclPowerOn: -----------
NvPclSettingsUpdate: Sending Updated Settings through PCL
NvPclSettingsApply: Applying last settings through PCL
apply:+++++++++++++++++++++++
writeMode: Target mode Id(0): Resolution 1920x1080
writeFrameRate: INPUT frameRate:30.000000
writeGain: INPUT gainCtrl:0 analogGain:0.000000
updateOutputSettings: OUTPUT frameRate:30.000000
updateOutputSettings: OUTPUT analogGain:0.000000
apply:-----------------------
NvPclSettingsApply: Reading PCL settings
writeGain: INPUT gainCtrl:a analogGain:1.000100
writeExposure: INPUT expTime:0.033330
updateOutputSettings: OUTPUT analogGain:1.000000
updateOutputSettings: OUTPUT expTime:0.033330
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 0 draining session frameStart events 3
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 529)
SCF: Error InvalidState: Sensor GUID 0 is in error state. Skipping requests, capture sequence ID = 1 continue draining session frameStart events 2
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 543)
SCF: Error InvalidState: Sensor GUID 0 is in error state. Skipping requests, capture sequence ID = 2 continue draining session frameStart events 1
PowerServiceCore:handleRequests: timePassed = 4680
SCF: Error InvalidState: Sensor 0 already in same state
(in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 0 draining session frameEnd events 3
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 646)
SCF: Error InvalidState: Sensor GUID 0 is in error state. Skipping requests, capture sequence ID = 3 continue draining session frameStart events 1
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 1 draining session frameEnd events 3
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 2 draining session frameEnd events 2
SCF: Error Timeout: Sending critical error event for Session 0
(in src/api/Session.cpp, function sendErrorEvent(), line 1039)
SCF: Error BadParameter: CC has already been disposed (in src/components/CaptureContainerManager.cpp, function dispose(), line 161)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 3 draining session frameEnd events 1
NvPclPowerOff: +++++++++++
NvPclPowerOff: -----------
=== gst-launch-1.0[2887]: CameraProvider destroyed (0xffff98c93ae0)NvPclClose: ++++++++++++++++++++++
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xaaab1798fe90
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98aad560
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98be62d0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98a1aaf0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98a2ce60
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98a2c690
NvPclStateControllerClose: Module imx390_bottomleft_liimx390 closed
NvPclClose: ----------------------
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ab3ce0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ab3290
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ab3320
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d191b0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d002a0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ab3c50
NvPclStateControllerClose: Module imx390_centerleft_liimx390 closed
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98cd83c0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ccc640
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98aaf0a0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d71b30
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ccc5b0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d89190
NvPclStateControllerClose: Module imx390_centerright_liimx390 closed
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d15bb0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98aaec20
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98aaecb0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d15b20
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d77e40
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ab1330
NvPclStateControllerClose: Module imx390_topleft_liimx390 closed
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ab2ff0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98cca500
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98cc7c50
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d710d0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98cd8250
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98aae010
NvPclStateControllerClose: Module imx390_bottomright_liimx390 closed
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d70200
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ccc2c0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d78830
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d70170
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d18700
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d165a0
NvPclStateControllerClose: Module imx390_topright_liimx390 closed
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d88a00
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d88a90
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d17e60
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff990c1510
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98c939c0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98c93a50
NvPclStateControllerClose: Module imx390_bottomcenter_liimx390 closed
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98aad790
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d172e0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff990c1ee0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98c8f5a0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98c143c0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98ac54d0
NvPclStateControllerClose: Module imx390_topcenter_liimx390 closed
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98c8ff80
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98cc7e20
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d18a60
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff992d5e80
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98c19db0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff992d5f10
NvPclStateControllerClose: Module imx390_frontcenter_liimx390 closed
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98d70be0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98c93750
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98cc3950
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98c13580
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98cc38c0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0xffff98cc3830
NvPclStateControllerClose: Module imx390_rearcenter_liimx390 closed
NvPclShutdown: ++++++++++++++++++++++
NvPclModuleListShutdown: Client still conntected, skipping shutdown
NvPclShutdown: ----------------------
NvPclRemoveHotplugCallback: ++++++++++++++++++++++
shutdownHotplug: Requesting thread exit
hotPlugfunc: Read 16 bytes from inotify FD
hotPlugfunc: A File was Modified 00008000 NAME : CREATE : 00000100, DELETE : 00000200 IGNORED : 00008000 CLOSE_WRITE : 00000008
hotPlugfunc: Exit thread
hotPlugfunc: close failure error: 'Bad file descriptor' (9)
hotPlugfunc --
shutdownHotplug -- : shutdown of hotplug is complete
Removed callback client
NvPclRemoveHotplugCallback: ----------------------
=== gst-launch-1.0[2887]: Connection closed (FFFF9E1BB840)=== gst-launch-1.0[2887]: Connection cleaned up (FFFF9E1BB840)
