Hi all,
I am working with an IMX274 camera who has a 1280x540@240fps mode. I want to capture with Nvcamerasrc GST plugin, but it has a limitation in the framerate pad caps of 120 fps maximum.
Here is the gst-inspect output that shows the framerate limitation:
ubuntu@tegra-ubuntu:~/carlos_test$ gst-inspect-1.0 nvcamerasrc
Factory Details:
Rank primary (256)
Long-name Nvidia Camera Source
Klass Video/Capture
Description Nvidia Camera Source
Author Jitendra Kumar <jitendrak@nvidia.com>
Plugin Details:
Name nvcamera
Description Nvidia Video Capture Component
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcamera.so
Version 1.2.0
License Proprietary
Source module nvcamera
Binary package NvCamera
Origin URL http://nvidia.com
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
format: { I420, NV12, UYVY }
framerate: [ 0/1, 120/1 ]
Is there any way to obtain access to nvcamerasrc gst plugin source code, to give support for 240 fps framerate, or at least any possibility of getting a binary if that plugin that supports the 240 fps. Also, it will be very helpful any related guide on how to capture and test this camera driver mode (1280x540@240fps) passing through the ISP (V4l2src only gives raw bayer output, but I need YUV or I420 so this is not an option).
I will apreciate any help!!
Thanks a lot in advance!
Best regards,
Daniel
