I have been having trouble with gst-launch-1.0 trying to get streaming going. I have a custom one-lane CSI panoramic camera 1920x480 running 30FPS. “v4l2-ctl” works fine, no errors, at 30FPS
Running “cheese” application streams but wI see a noticeable lag in the stream.
Next we tried gst-launch-1.0 with v4l2src daemon:
gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw, width=1920, height=480, framerate=30/1’ ! xvimagesink -ev
I see the first frame, then it freezes (no errors in dmesg).
Next I tried running gst-launch-1.0 with nvcamera daemon:
gst-launch-1.0 nvcamerasrc ! ‘video/x-raw(memory:NVMM) , width=(int)1920, height=(int)480, format=(string)I420, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw, format=(string)I420’ ! xvimagesink -ev
It immediately fails, so I started the nvcamera daemon manually. This is what I get for failures:
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
PCLHW_DTParser
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/pffcam_center_lipffcam.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/pffcam_center_lipffcam.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/pffcam_center_lipffcam.isp] 8/16---- imager: No override file found. ----
(NvOdmDevice) Error ModuleNotPresent: V4L2Device not available (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function findDevice(), line 231)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function initialize(), line 54)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 97)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 2. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 596)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 781)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 276)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 439)
