I’m running sample codes given in CUDA SDK on win xp that doesn’t have a GPU enabled graphics card. I’m using VS-2008 and in device emulation mode. I’m getting this error when compiling the .cu file
nvcc fatal : Could not open input file C:\DOCUME~1\Murali_Krishna05\Local Settings\Temp/tmpxft_00000af8_00000000-1
Due to which no object file is being created. Few past threads reg same issue didn’t work(removing quotes in path variables"
