Nvcc on Linux tries to resolve ::lerp as std::lerp with compute 80 or higher
...(93): error: more than one instance of overloaded function "lerp" matches the argument list:
            function "std::lerp(float, float, float) noexcept" (declared at line 1911 of /usr/include/c++/11/cmath)
            function "lerp(float, float, float)" (declared at line 1226 of .../helper_math.h)
            argument types are: (const float, const float, const float)
   auto x0 = ::lerp(a, b, relPos.x);
The above error happens on Linux when compiling with compute architecture 8.0 but not 6.1. It also doesn’t happen on Windows.
On Linux, removing the lerp(float,float,float) definition from helper_math.h solves this. On Windows it causes compilation to fail.
The Linux behaviour seems like an error, since ::lerp shouldn’t be resolved as std::lerp.
I tried it with SDKs 12.4 and 12.8.
Anyone encountered this? Any idea how to bypass it except for different code for Windows and Linux?
helper_math.h is not part of the CUDA toolkit.
It is part of CUDA sample codes which are not intended to be used for production code.
So don’t include or use helper_math.h
Then fix your code.
I understand, though this looks to me like a problem on the compiler side, so ā€œfix your codeā€ feels both condescending and wrong. I think it would be better if NVIDIA fixed is own code.
(But thanks for the quick reply.)
sorry to have been condescending and wrong
it looks to me like you have 2 candidates on the linux side (because one is coming from linux system headers, which I don’t necessarily expect to match windows system headers.)
what is the problem on the compiler side? Are you referring to this:
Can you provide a short, complete example of the issue?
I tried this on CUDA 12.8.1, but that did not show an issue:
$ cat test.cu
#include <./cuda-samples/Common/helper_math.h>
__device__ float f(float a, float b, float c){
  return ::lerp(a,b,c);
$ nvcc -arch=sm_80 -I.  -dc test.cu
inline __device__ __host__ float lerp(float a, float b, float t)
	return a + t * (b - a);
__global__ void interpolate(const float* a, const float* b, const float* t, float* result)
	int i = blockIdx.x * blockDim.x + threadIdx.x;
	result[i] = ::lerp(a[i], b[i], t[i]);
This shows the problem.
It’s compiled with CMake with:
set(CMAKE_CUDA_ARCHITECTURES "61;80")
add_compile_options($<$<COMPILE_LANGUAGE:CUDA>:--std=c++20>)
add_compile_options($<$<COMPILE_LANGUAGE:CUDA>:--extended-lambda>)
add_compile_options($<$<COMPILE_LANGUAGE:CUDA>:--expt-relaxed-constexpr>)
I don’t think the flags matter. They’re just there because I used what I normally use. Compiles fine with arch 61 but not with arch 80.
Edit: I initially posted with ā€˜lerp’ instead of ā€˜::lerp’, but got the same problem with both.
I didn’t have any trouble compiling that on CUDA 12.8.1:
$ cat test2.cu
        result[i] = lerp(a[i], b[i], t[i]);
$ nvcc -arch=sm_80 -I.  -dc test2.cu
Can you shown the full cmake verbose compilation output?
Thanks. I’ll try to debug the compilation to see when the problem surfaces.
ahh
The -std=c++20 flag shows the issue:
$ nvcc -arch=sm_80 -I.  -dc test2.cu -std=c++20
test2.cu(10): error: more than one instance of overloaded function "lerp" matches the argument list:
            function "lerp(float, float, float)" (declared at line 1)
1 error detected in the compilation of "test2.cu".
Thanks. Good to know you see it.
I have seen other situations where the device code compiler ā€œresolvesā€ undecorated functions using the standard library (perhaps, unexpectedly). So it’s not obvious to me that is not allowed. (I don’t know.)
If you think it is a (nvcc) bug, probably best to file a bug.
If you are looking for workarounds,
it seems like one possibility would be to include your own definition in a namespace, then call out that namespace specifically:
$ cat test2.cu
namespace foo{
        result[i] = foo::lerp(a[i], b[i], t[i]);
And, FWIW, I see the same failure using the non-namespace code, whether I compile for -arch=sm_61 or -arch=sm_80. That error doesn’t appear to be arch-dependent.
Okay, thanks. It surfaced when I first used arch 80, but it might have had to do with other defaults of the compiler. IIRC I was using C++17 at the time, so perhaps it matters there.
Anyway, I opened a bug, so I’ll wait to see what happens there and in the mean time hack this thing. Thanks for the help.
Thanks for filing a ticket (ID 5238032) . It is under review and we will bring back conclusion here .
