NVDEC clocks frequency is lower than the value of specification
There is the following information in https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/PlatformPowerAndPerformance/JetsonOrinNxSeriesAndJetsonAgxOrinSeries.html#supported-modes-and-power-efficiency.
SoC clocks maximal frequency (MHz)
nvdec: 857.6
And, I checked NVDEC clocks frequency via jetson_stats.
Check1
I used https://github.com/dusty-nv/jetson-utils/tree/master/video/video-viewer.
./video-viewer file:///opt/nvidia/vpi2/samples/assets/dashcam.mp4
In this case, jetson_stats reports 857MHz as NVDEC clocks frequency.
This is equivalent to the value mentioned above.
Check2
I used nvgstplayer.
nvgstplayer -i /opt/nvidia/vpi2/samples/assets/dashcam.mp4
In this case, jetson_stats reports 128MHz as NVDEC clocks frequency.
This is lower than the value of specification.
So, I would like to know why there is difference of clocks frequency.
Environment
My environment is as follows.
  • Jetson Orin NX 16GB
  • Jetson Linux 35.4.1
  • Power mode MAXN
By default the engine is run in dynamic frequency scaling(DFS). Please refer to the examples in
Accelerated GStreamer — Jetson Linux Developer Guide documentation
And set the property to nvv4l2decoder:
  enable-max-performance: Set to enable max performance
                        flags: readable, writable
                        Boolean. Default: false
Thank you for your information. I understood.
