First of all, I sorted out the RGB/BGR color conversion issue. By adding “video/x-raw(memory:NVMM), format=RGBA” it forced RGBA instead of BGRx which was the caps for nvvidconv by default. Working pipeline with good colors:
gst-launch-1.0 -v filesrc location=/data/sample_cam6.mkv ! decodebin ! nvvidconv ! "video/x-raw(memory:NVMM), format=RGBA" ! nvdewarper config-file=/data/dewarper.txt ! nveglglessink
Below is the -v output for the pipeline you mentioned:
gst-launch-1.0 -v filesrc location=/data/source_images/fisheye_3072_100.jpg ! decodebin ! imagefreeze ! nvvidconv ! nvdewarper config-file=/data/dewarper.txt ! nvvidconv ! nveglglessink
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = "image/jpeg\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ sof-marker\=\(int\)0"
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstJpegDec:jpegdec0.GstPad:sink: caps = "image/jpeg\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ sof-marker\=\(int\)0"
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstJpegDec:jpegdec0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)mpeg2\,\ colorimetry\=\(string\)1:4:0:0\,\ framerate\=\(fraction\)0/1"
/GstPipeline:pipeline0/GstImageFreeze:imagefreeze0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)25/1\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)mpeg2\,\ colorimetry\=\(string\)1:4:0:0"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv0.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)BGRx\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)25/1"
/GstPipeline:pipeline0/Gstnvdewarper:nvdewarper0.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ framerate\=\(fraction\)25/1\,\ width\=\(int\)1280\,\ height\=\(int\)3840"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv1.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ framerate\=\(fraction\)25/1\,\ width\=\(int\)1280\,\ height\=\(int\)3840"
/GstPipeline:pipeline0/GstEglGlesSink:eglglessink0.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ framerate\=\(fraction\)25/1\,\ width\=\(int\)1280\,\ height\=\(int\)3840"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv1.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ framerate\=\(fraction\)25/1\,\ width\=\(int\)1280\,\ height\=\(int\)3840"
/GstPipeline:pipeline0/Gstnvdewarper:nvdewarper0.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)BGRx\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)25/1"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)25/1\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)mpeg2\,\ colorimetry\=\(string\)1:4:0:0"
/GstPipeline:pipeline0/GstImageFreeze:imagefreeze0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)mpeg2\,\ colorimetry\=\(string\)1:4:0:0\,\ framerate\=\(fraction\)0/1"
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstDecodePad:src_0.GstProxyPad:proxypad1: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)mpeg2\,\ colorimetry\=\(string\)1:4:0:0\,\ framerate\=\(fraction\)0/1"
nvvidconv0: NOT SUPPROTED CONVERSION ... Use videoconvert ... EXITING...
ERROR: from element /GstPipeline:pipeline0/GstImageFreeze:imagefreeze0: Internal data stream error.
Additional debug info:
gstimagefreeze.c(851): gst_image_freeze_src_loop (): /GstPipeline:pipeline0/GstImageFreeze:imagefreeze0:
stream stopped, reason not-supported
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
/GstPipeline:pipeline0/GstEglGlesSink:eglglessink0.GstPad:sink: caps = "NULL"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv1.GstPad:src: caps = "NULL"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv1.GstPad:sink: caps = "NULL"
/GstPipeline:pipeline0/Gstnvdewarper:nvdewarper0.GstPad:src: caps = "NULL"
/GstPipeline:pipeline0/Gstnvdewarper:nvdewarper0.GstPad:sink: caps = "NULL"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv0.GstPad:src: caps = "NULL"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv0.GstPad:sink: caps = "NULL"
/GstPipeline:pipeline0/GstImageFreeze:imagefreeze0.GstPad:src: caps = "NULL"
/GstPipeline:pipeline0/GstImageFreeze:imagefreeze0.GstPad:sink: caps = "NULL"
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstDecodePad:src_0.GstProxyPad:proxypad1: caps = "NULL"
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstDecodePad:src_0: caps = "NULL"
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstJpegDec:jpegdec0.GstPad:src: caps = "NULL"
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstJpegDec:jpegdec0.GstPad:sink: caps = "NULL"
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = "NULL"
Freeing pipeline ...
What I am trying right now is pinpoint exactly what it is that is that is throwing the error when trying to run the dewarper plugin on a single image. This pipeline below without nvdewarper works and shows the output before fakesink as exactly the same as the working video pipeline:
gst-launch-1.0 -v filesrc location=/data/source_images/fisheye_3072_100.jpg ! decodebin ! imagefreeze ! "video/x-raw, format=(string)I420, framerate=(fraction)20/1" ! nvvidconv ! "video/x-raw(memory:NVMM)" ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)RGBA" ! fakesink
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)20/1"
When now trying to add the dewarp plugin, I get this:
gst-launch-1.0 -v filesrc location=/data/source_images/fisheye_3072_100.jpg ! decodebin ! imagefreeze ! "video/x-raw, format=(string)I420, framerate=(fraction)20/1" ! nvvidconv ! "video/x-raw(memory:NVMM)" ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)RGBA" ! nvdewarper config-file=/data/dewarper.txt ! fakesink
/GstPipeline:pipeline0/GstImageFreeze:imagefreeze0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)mpeg2\,\ colorimetry\=\(string\)1:4:0:0\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)mpeg2\,\ colorimetry\=\(string\)1:4:0:0\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv0.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv1.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/Gstnvdewarper:nvdewarper0.GstPad:src: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ framerate\=\(fraction\)20/1\,\ width\=\(int\)1280\,\ height\=\(int\)3840"
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ framerate\=\(fraction\)20/1\,\ width\=\(int\)1280\,\ height\=\(int\)3840"
/GstPipeline:pipeline0/Gstnvdewarper:nvdewarper0.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)RGBA\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv1.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = "video/x-raw\(memory:NVMM\)\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/Gstnvvidconv:nvvidconv0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)mpeg2\,\ colorimetry\=\(string\)1:4:0:0\,\ framerate\=\(fraction\)20/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)I420\,\ width\=\(int\)3072\,\ height\=\(int\)3072\,\ interlace-mode\=\(string\)progressive\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ chroma-site\=\(string\)mpeg2\,\ colorimetry\=\(string\)1:4:0:0\,\ framerate\=\(fraction\)20/1"
ERROR:gstnvdewarper.cpp:1406:GstFlowReturn gst_nvdewarper_transform(GstBaseTransform*, GstBuffer*, GstBuffer*): assertion failed: (frameinfo != NULL)
Aborted (core dumped)
Any help is appriciated.
Also very interested in more documentation and information regarding the dewarp plugin if possible, especially if it is being developed for the jetson platform and included in the jetson deepstream sdk. Thanks!
