Here is the output of the gst-inspect-1.0 nvarguscamerasrc command.
Factory Details:
Rank primary (256)
Long-name NvArgusCameraSrc
Klass Video/Capture
Description nVidia ARGUS Camera Source
Author Viranjan Pagar <vpagar@nvidia.com>, Amit Pandya <apandya@nvidia.com>
Plugin Details:
Name nvarguscamerasrc
Description nVidia ARGUS Source Component
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
Version 1.0.0
License Proprietary
Source module nvarguscamerasrc
Binary package NvARGUSCameraSrc
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstNvArgusCameraSrc
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
format: { (string)NV12 }
framerate: [ 0/1, 2147483647/1 ]
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SRC: 'src'
Pad Template: 'src'
Element Properties:
acquire-wait : Set the waiting time for the acquireFrame before timeout. Default 5000000000 (in nanosec)
flags: readable, writable
Unsigned Integer64. Range: 5000000000 - 18446744073709551615 Default: 5000000000
aeantibanding : property to set the auto exposure antibanding mode
Enum "GstNvArgusCamAeAntiBandingMode" Default: 1, "AeAntibandingMode_Auto"
(0): AeAntibandingMode_Off - GST_NVCAM_AEANTIBANDING_OFF
(1): AeAntibandingMode_Auto - GST_NVCAM_AEANTIBANDING_AUTO
(2): AeAntibandingMode_50HZ - GST_NVCAM_AEANTIBANDING_50HZ
(3): AeAntibandingMode_60HZ - GST_NVCAM_AEANTIBANDING_60HZ
aelock : set or unset the auto exposure lock
Boolean. Default: false
aeregion : Property to set region of interest for auto exposure
with values of ROI coordinates (left, top, right, bottom)
and weight (float number) in that order, to set the property
use for example: aeregion="0 0 256 256 1"
String. Default: null
awblock : set or unset the auto white balance lock
blocksize : Size in bytes to read per buffer (-1 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
do-timestamp : Apply current stream time to buffers
Boolean. Default: true
ee-mode : property to select edge enhnacement mode
Enum "GstNvArgusCamEEMode" Default: 1, "EdgeEnhancement_Fast"
(0): EdgeEnhancement_Off - GST_NVCAM_EE_OFF
(1): EdgeEnhancement_Fast - GST_NVCAM_EE_FAST
(2): EdgeEnhancement_HighQuality - GST_NVCAM_EE_HIGHQUALITY
ee-strength : property to adjust edge enhancement strength
Float. Range: -1 - 1 Default: -1
event-wait : Set the waiting time for the event before timeout. Default 3000000000 (in nanosec)
Unsigned Integer64. Range: 3000000000 - 18446744073709551615 Default: 3000000000
exposurecompensation: property to adjust exposure compensation
Float. Range: -2 - 2 Default: 0
exposuretimerange : Property to adjust exposure time range in nanoseconds
Use string with values of Exposure Time Range (low, high)
in that order, to set the property.
eg: exposuretimerange="34000 358733000"
gainrange : Property to adjust gain range
Use string with values of Gain Time Range (low, high)
eg: gainrange="1 16"
ispdigitalgainrange : Property to adjust digital gain range
Use string with values of ISP Digital Gain Range (low, high)
eg: ispdigitalgainrange="1 8"
name : The name of the object
flags: readable, writable, 0x2000
String. Default: "nvarguscamerasrc0"
num-buffers : Number of buffers to output before sending EOS (-1 = unlimited)
Integer. Range: -1 - 2147483647 Default: -1
parent : The parent of the object
Object of type "GstObject"
saturation : Property to adjust saturation value
Float. Range: 0 - 2 Default: 1
sensor-id : Set the id of camera sensor to use. Default 0.
Integer. Range: 0 - 255 Default: 0
sensor-mode : Set the camera sensor mode to use. Default -1 (Select the best match)
Integer. Range: -1 - 255 Default: -1
silent : Produce verbose output ?
timeout : timeout to capture in seconds (Either specify timeout or num-buffers, not both)
Unsigned Integer. Range: 0 - 2147483647 Default: 0
tnr-mode : property to select temporal noise reduction mode
Enum "GstNvArgusCamTNRMode" Default: 1, "NoiseReduction_Fast"
(0): NoiseReduction_Off - GST_NVCAM_NR_OFF
(1): NoiseReduction_Fast - GST_NVCAM_NR_FAST
(2): NoiseReduction_HighQuality - GST_NVCAM_NR_HIGHQUALITY
tnr-strength : property to adjust temporal noise reduction strength
total-sensor-modes : Query the number of sensor modes available. Default 0
flags: readable
typefind : Run typefind before negotiating (deprecated, non-functional)
flags: readable, writable, deprecated
wbmode : White balance affects the color temperature of the photo
Enum "GstNvArgusCamWBMode" Default: 1, "auto"
(0): off - GST_NVCAM_WB_MODE_OFF
(1): auto - GST_NVCAM_WB_MODE_AUTO
(2): incandescent - GST_NVCAM_WB_MODE_INCANDESCENT
(3): fluorescent - GST_NVCAM_WB_MODE_FLUORESCENT
(4): warm-fluorescent - GST_NVCAM_WB_MODE_WARM_FLUORESCENT
(5): daylight - GST_NVCAM_WB_MODE_DAYLIGHT
(6): cloudy-daylight - GST_NVCAM_WB_MODE_CLOUDY_DAYLIGHT
(7): twilight - GST_NVCAM_WB_MODE_TWILIGHT
(8): shade - GST_NVCAM_WB_MODE_SHADE
(9): manual - GST_NVCAM_WB_MODE_MANUAL
