Nvdrmvideosink python error handling
Hi i am using this pipeline, for showing a livestream over hdmi:
“appsrc ! videoconvert ! nvvidconv ! video/x-raw(memory:NVMM),width=”+str(displaywidth)+“,height=”+str(displayheight)+",format=NV12 ! nvdrmvideosink sync=false "
everything works as expected. But if i restart the hdmi monitor, the python scripts continues, but gstreamer showing this warning. monitor screen is black with some (unnecessary) mc.errors.
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (1663) writeFrame OpenCV | GStreamer warning: Error pushing buffer to GStreamer pipeline
How to handle this warning / restart the script ?
try:
        stream.write(vis)
    except cv2.error as error:
        print("[Error]: {}".format(error))
        break
    except Exception:
        break
    except Warning:
        break
Best Regards
Martin
Please share your release version:
$ head -1 /etc/nv_tegra_release
And we would need your help to provide steps so that we follow to reproduce the issue. Please check if you can make a test app based on this simple test app:
Nvoverlaysink ignores properties when pipeline is restarted - #6 by DaneLLL
I have easily reproduced that :
  1. Swicth to virtual console with Alt-Ctrl-F3 and login
  2. Run the pipeline:
gst-launch-1.0 videotestsrc ! nvvidconv ! nvdrmvideosink
  1. Power off monitor
  2. Power on monitor
  3. The pipeline has been stopped by an error with the following messages:
Failed to set plane
Failed to display frame buffer
It works fine with nvoverlaysink instead of nvdrmvideosink.
This use-case may not be verified. We expect the screen is on for running the gstreamer command. Will try to reproduce it and check if we can support this use-case.
