when I run the following Gstreamer pipeline on Xavier , I came with the error with rtmp
nvidia@nvidia:~/Videos$ gst-launch-1.0 v4l2src ! ‘video/x-raw, width=(int)640, height=(int)480’ ! nvvidconv ! omxh264enc bitrate=300000 control-rate=variable ! h264parse ! queue ! flvmux name=muxer alsasrc device=hw:1 ! audioresample ! “audio/x-raw,rate=48000” ! queue ! voaacenc bitrate=32000 ! aacparse ! queue ! muxer. muxer. ! rtmpsink location="rtmp://192.168.1.114/home/nvidia/Videos/test live=1 "
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstAudioSrcClock
Redistribute latency…
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
ERROR: from element /GstPipeline:pipeline0/GstRTMPSink:rtmpsink0: Could not open resource for writing.
Additional debug info:
gstrtmpsink.c(245): gst_rtmp_sink_render (): /GstPipeline:pipeline0/GstRTMPSink:rtmpsink0:
Could not connect to RTMP stream "rtmp://192.168.1.114/home/nvidia/Videos/test live=1 " for writing
Execution ended after 0:00:01.829953125
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
I google this question and to install Nginx on Xavier, but when I start the nginx service , I came with the following question:
nvidia@nvidia:~$ sudo service nginx start
Job for nginx.service failed because the control process exited with error code.
See “systemctl status nginx.service” and “journalctl -xe” for details.
nvidia@nvidia:~$ systemctl status nginx.service
● nginx.service
Loaded: loaded (/etc/init.d/nginx; generated)
Active: failed (Result: exit-code) since Thu 2020-02-13 15:24:16 CST; 10s ago
Docs: man:systemd-sysv-generator(8)
Process: 8467 ExecStart=/etc/init.d/nginx start (code=exited, status=203/EXEC)
2月 13 15:24:16 nvidia systemd[1]: Starting nginx.service…
2月 13 15:24:16 nvidia systemd[8467]: nginx.service: Failed to execute command:
2月 13 15:24:16 nvidia systemd[8467]: nginx.service: Failed at step EXEC spawnin
2月 13 15:24:16 nvidia systemd[1]: nginx.service: Control process exited, code=e
2月 13 15:24:16 nvidia systemd[1]: nginx.service: Failed with result ‘exit-code’
2月 13 15:24:16 nvidia systemd[1]: Failed to start nginx.service.
Could anybody show me the key point to solve this question ,I will be appreciated for your help!
