My platfrom is AGX Xaiver(16G), I try to encode the yuv frame into H.264 with nvenc encoder. The application doesn’t work after a period of time, I can get buffer from capture_plane, but the size is always is 0. How to deal this ? where can I get more usefull information?
Please share which release version you are using. And do you run this sample:
/usr/src/jetson_multimedia_api/samples/01_video_encode
HI DaneLLL
The version info is as below:
- Jetson-AGX
- Jetpack UNKNOWN [L4T 35.1.0]
- NV Power Mode: MAXN - Type: 0
- jetson_stats.service: active
- Libraries:
- CUDA: 11.4.239
- cuDNN: 8.4.1.50
- TensorRT: 8.4.1.5
- OpenCV: 4.5.4 compiled CUDA: NO
- VPI: 2.1.6
- Vulkan: 1.3.203
I have already tried the sample, it works. Please tell me where can I get more nvenc logs, thanks.
We would suggest upgrade to Jetpack 5.1(r35.2.1) and give it a try. Or if Kernel 4.9 is good for you, you may try Jetpack 4.6.3(r32.7.3)
Any way to get more detail? or where can I get nvenc driver log?
You can add --dbg-level 3 to get more log prints:
01_video_encode$ ./video_encode 1080.yuv 1920 1080 H264 a.264 --dbg-level 3
