I am reaching out regarding an issue with an NVIDIA Jetson AGX Orin Developer Kit running Ubuntu 22.04.5 LTS (R36 release, Revision 4.7, GCID: 42132812, BOARD: generic, EABI: aarch64).
We use this system to control a Boston Dynamics Spot robot. The connection drops at irregular intervals (anywhere from a few minutes to about half), and more recently it sometimes fails soon after boot up
When the issue occurs, the following messages appear in dmesg:
nvethernet 6800000.ethernet eno1: Link is Down
nvethernet 6800000.ethernet: [xpcs_lane_bring_up][477][type:0x4][loga-0x0] PCS block lock SUCCESS
nvethernet 6800000.ethernet: [xpcs_lane_bring_up][470][type:0x4][loga-0x0] Failed to get PCS block lock
We have observed this issue on two different robots, and it occurs regardless of the Ethernet cables used. The problem also happens while the robot is stationary, so it does not appear to be related to movement or mechanical activity. We have tried using a USB-C to Ethernet adapter, which seems slightly more stable, but the issue still occurs eventually. In some cases, reconnecting the Ethernet cable temporarily restores the connection, though it only lasts for a few minutes before dropping again. However, when we control the robot using a laptop instead of the Jetson, the connection remains stable, which makes us think the issue is specific to the Jetson setup.
Here is the dmesg log
dmesg_log.txt (85.4 KB)
Could you please advise on possible causes or recommended troubleshooting steps?
Thank you for your support.
