Nvfortran、cuda fortran、openmp
Hello, I want to ask you some questions. Can nvfortran compile openmp statements? I want to use cuda fortran and openmp to rewrite my fortran serial code under linux.
Yes.
That’s fine, though if you’re wanting to use OpenMP to support multi-GPU programming, I prefer using MPI instead. With OpenMP you end up having to do domain decomposition and it’s more difficult to manage the memory movement. With MPI, domain decomposition is inherent, allows the program to run across multiple nodes, and GPU Aware MPI allows for direct memory transfers between GPUs.
-Mat
