IS Offloading Fortran to GPU with nvfortran on older GPU possible (CC61)
I am trying to use OpenMP to offload fortran code to a nvidia GPU using the Nvidia HPC SDK (https://developer.nvidia.com/hpc-sdk) and its nvfortran compiler.
The documentation (https://docs.nvidia.com/hpc-sdk/compilers/hpc-compilers-user-guide/index.html#openmp-use) for the current version states that to use the GPU features, you must have a GPU with compute capability greater than 7.0 (V100 generation of GPUs)/ My GPU has Compute capability of 6.1. Is there a way to get the compiler to make use of my older GPU (Quadro P2200)?
Compiler error message :
~/source/arunprasaada/Youtube_Tutorials/Fortran_OpenMP/Hello$ nvfortran ./arr_add.f95 -mp=gpu
nvfortran-Fatal-OpenMP GPU Offload is available only on systems with NVIDIA GPUs with compute capability '>= cc70'
Quote from the documentation:
Use the -⁠mp compiler switch to enable processing of OpenMP directives and pragmas. The most important sub-options to -⁠mp are the following:
  • gpu: OpenMP directives are compiled for GPU execution plus multicore CPU fallback; this feature is supported on NVIDIA V100 or later GPUs.
  • multicore: OpenMP directives are compiled for multicore CPU execution only; this sub-option is the default.
Are there other approaches for compiling fortran which can use OpenMP + Fortran to offload to GPUs that would support my gpu? I am hoping not to have to buy a newer GPU in this time of crazy prices and low supply.
No, sorry. We only support OpenMP Target Offload to V100s or later.
-Mat
Gotcha, thanks for the quick response! Is there any plan to support older GPUs?
No, no plans to support older GPU.
