I understand nvcc can generate GPU code using CUDA and OpenACC using #pragma acc kernels . Since OpenMP 4.0 released, it had the target construct to offload work to a GPU. Can nvcc be used to generate GPU code using the OpenMP target construct?
For OpenMP support, you need to use nvc++ (provided as part of the NVIDIA HPC SDK).
