Hi Mat,
I am compiling on the V100 system.
When I run nvaccelinfo, it says:
$ nvaccelinfo
NVRM version: NVIDIA UNIX x86_64 Kernel Module 450.51.05 Sun Jun 28 10:33:40 UTC 2020
No accelerators found.
Try nvaccelinfo -v for more information
I believe there was a conflict between my default cuda10.2 and nvhpc’s cuda. So I unloaded the default cuda.
If I unload the cuda module and then run I get proper nvaccelinfo output, since (I think) now it is picking nvhpc’s cuda.
$ module unload cuda102
$ nvaccelinfo
CUDA Driver Version: 11000
Device Number: 0
Device Name: Tesla V100-PCIE-16GB
Device Revision Number: 7.0
Global Memory Size: 16945512448
Number of Multiprocessors: 80
Concurrent Copy and Execution: Yes
Total Constant Memory: 65536
Total Shared Memory per Block: 49152
Registers per Block: 65536
Warp Size: 32
Maximum Threads per Block: 1024
Maximum Block Dimensions: 1024, 1024, 64
Maximum Grid Dimensions: 2147483647 x 65535 x 65535
Maximum Memory Pitch: 2147483647B
Texture Alignment: 512B
Clock Rate: 1380 MHz
Execution Timeout: No
Integrated Device: No
Can Map Host Memory: Yes
Compute Mode: default
Concurrent Kernels: Yes
ECC Enabled: Yes
Memory Clock Rate: 877 MHz
Memory Bus Width: 4096 bits
L2 Cache Size: 6291456 bytes
Max Threads Per SMP: 2048
Async Engines: 7
Unified Addressing: Yes
Managed Memory: Yes
Concurrent Managed Memory: Yes
Preemption Supported: Yes
Cooperative Launch: Yes
Multi-Device: Yes
Default Target: cc70
Now when I try to compile using nvc I get the error:
$ nvc -mp=gpu matrix.c
nvc-Error-OpenMP GPU Offload is available only on systems with NVIDIA GPUs with compute capability ‘>= cc70’
$ nvc -mp=gpu -gpu=cc70 matrix.c
nvc-Error-CUDA version 10.2 is not available in this installation.
Thank You.
Alok
