Hi everyone,
With NVHPC 25.7 we started to have the failure with nsys compute (works ok with 25.1 and 25.3):
!! nvfortran -cuda -acc=gpu -O3 -o psum_fortran_test psum_fortran_test.f90 -cudalib=cutensor
PROGRAM psum_test
IMPLICIT NONE
INTEGER, PARAMETER :: INITIAL_NCYCLES = 10000
INTEGER :: i = 1, imax = 16*1024*1024
INTEGER :: ncycles, usec, incr
ncycles = INITIAL_NCYCLES
do
if (i > imax) exit
if (i > 16*1024) ncycles = INITIAL_NCYCLES / 10;
if (i > 1024*1024) ncycles = INITIAL_NCYCLES / 100;
usec = test(i)
if (i < 10 .or. mod(i,10) == 1) then
write (*,'(A,I0,A,F0.2)') "i=", i, " usec=", real(usec)/real(ncycles)
endif
incr = (i/100)*10
if (incr == 0 .and. i < 11) incr = 1
if (incr == 0) incr = 10
i = i + incr
end do
CONTAINS
FUNCTION TEST(N)
use cutensorex, only: SUM_PREFIX
INTEGER :: N
INTEGER :: test
INTEGER :: i, k
INTEGER :: count_rate, count_start, count_end
INTEGER, ALLOCATABLE :: x(:), y(:)
ALLOCATE(X(N), Y(N))
x = [( merge(i, -i, mod(i,2)==1), i=1,N )]
!$acc data copy(x,y)
call system_clock(count_rate = count_rate)
call system_clock(count_start)
do k = 1, ncycles
y = SUM_PREFIX(x)
end do
call cudaDeviceSynchronize()
call system_clock(count_end)
!$acc end data
test = INT(real(count_end - count_start) / real(count_rate) * 1e6)
END FUNCTION
END PROGRAM
The compiler line:
nvfortran -cuda -acc=gpu -O3 -o psum_test_fortran psum_test_fortran.f90 -cudalib=cutensor
The nsys says:
$ nsys profile -t cuda -s none -f true -o psum-profile.nsys-ui psum_test_fortran
WARNING: CPU context switch tracing not supported, disabling.
Try the 'nsys status --environment' command to learn more.
Connection to Agent lost. This is most likely a bug. Internal reason: 'End of file'.
Please refer to the troubleshooting section of the docs:
https://docs.nvidia.com/nsight-systems/UserGuide/index.html#troubleshooting
I do not have 25.9 so I can’t check if the issue is still there.
Any workaround?
Best regards,
Alexey
