Nvidia contianer l4t-pytorch:r35.1.0-pth1.11-py3 running on Jetson AGX Orin, pytorch can not using gpu
Hello,everyone.
I am using Jetson AGX Orin for my project. And the env of the host is likes below:
I deployed a pytorch image provided by Nvidia(NVIDIA L4T PyTorch | NVIDIA NGC) on the machine, but pytorch reported that it cannot detect GPUs. Container Info like below:
The abnormal behavior is as follows:
However, I am able to use GPU smoothly using the Jetpack6 image, but my project currently requires the use of Jetpack5 image.
Is there a restriction that requires the host and image to use the same jetpack version? Or AGX Orin still requires the use of JetPack6 software version?
Since PyTorch is built with a specific CUDA version, please use the container that is aligned to your JetPack environment.
For example, nvcr.io/nvidia/l4t-pytorch:r35.2.1-pth2.0-py3 for JetPack 5.
nvcr.io/nvidia/pytorch:24.08-py3-igpu for JetPack 6.
