Hello guys,
I’m using Jetpack-5.0-DP
/ L4T-R34.1.1
and I noticed that there is an issue when nvidia-display-driver
is loaded.
Could you please help to fix the issue ?
Here is the logs:
[ 26.146649] nvidia-modeset: Loading NVIDIA UNIX Kernel Mode Setting Driver for aarch64 34.1.1 Release Build (buildbrain@mobile-u64-5414-d7000) Mon May 16 21:12:27 PDT 2022
[ 26.146703] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[ 26.146707] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:295
[ 26.146715] CPU: 2 PID: 1892 Comm: modprobe Tainted: G O 5.10.65-tegra #1
[ 26.146717] Hardware name: /, BIOS r34.1-975eef6 05/16/2022
[ 26.146719] Call trace:
[ 26.146732] dump_backtrace+0x0/0x1a0
[ 26.146735] show_stack+0x2c/0x40
[ 26.146744] dump_stack+0xd8/0x138
[ 26.146779] os_dump_stack+0x14/0x1c [nvidia]
[ 26.146794] tlsEntryUnreference+0x198/0x1a0 [nvidia]
[ 26.146809] gpumgrGetSomeGpu+0x80/0x98 [nvidia]
[ 26.146823] threadPriorityRestore+0xa8/0x2f0 [nvidia]
[ 26.146838] rmclientConstruct_IMPL+0x160/0x258 [nvidia]
[ 26.146852] __nvoc_ctor_RmClient+0x5c/0x88 [nvidia]
[ 26.146867] __nvoc_objCreate_RmClient+0x7c/0x118 [nvidia]
[ 26.146881] resservClientFactory+0x28/0x90 [nvidia]
[ 26.146896] serverAllocClient+0x19c/0x318 [nvidia]
[ 26.146910] serverAllocResource+0x140/0x2e8 [nvidia]
[ 26.146925] rmapiAllocWithSecInfo+0x17c/0x2e8 [nvidia]
[ 26.146940] rmapiAllocWithSecInfoTls+0x74/0xa8 [nvidia]
[ 26.146954] rmapiInitDeprecatedContext+0x520/0x598 [nvidia]
[ 26.146993] nvkms_call_rm+0x5c/0x90 [nvidia_modeset]
[ 26.147022] nvRmApiAlloc+0x30/0x40 [nvidia_modeset]
[ 26.147025] do_one_initcall+0x4c/0x2d0
[ 26.147034] do_init_module+0x5c/0x210
[ 26.147035] load_module+0x2068/0x2680
[ 26.147037] __do_sys_finit_module+0xb4/0xf0
[ 26.147039] __arm64_sys_finit_module+0x28/0x40
[ 26.147046] el0_svc_common.constprop.0+0x7c/0x1c0
[ 26.147048] do_el0_svc+0x34/0xa0
[ 26.147054] el0_svc+0x1c/0x30
[ 26.147056] el0_sync_handler+0xa8/0xb0
[ 26.147058] el0_sync+0x16c/0x180
[ 26.147061] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[ 26.147063] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:295
[ 26.175219] fuse: init (API version 7.32)
[ 26.898176] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[ 26.898776] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[ 26.899452] NVRM rmapiAllocWithSecInfo: allocation failed; status: Given class-id not valid [NV_ERR_INVALID_CLASS] (0x00000022)
[ 26.899454] NVRM rmapiAllocWithSecInfo: client:0xc1d00001 parent:0xcaf00001 object:0x0 class:0x402c
[ 26.901131] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[ 26.912660] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 26.912668] CPU: 5 PID: 1882 Comm: Xorg Tainted: G O 5.10.65-tegra #1
[ 26.912669] Hardware name: /, BIOS r34.1-975eef6 05/16/2022
[ 26.912671] Call trace:
[ 26.912681] dump_backtrace+0x0/0x1a0
[ 26.912684] show_stack+0x2c/0x40
[ 26.912691] dump_stack+0xd8/0x138
[ 26.912727] os_dump_stack+0x14/0x1c [nvidia]
[ 26.912745] tlsEntryUnreference+0x198/0x1a0 [nvidia]
[ 26.912760] ctxdmaConstruct_IMPL+0x36c/0x3b8 [nvidia]
[ 26.912775] __nvoc_ctor_ContextDma+0x74/0xa8 [nvidia]
[ 26.912790] __nvoc_objCreate_ContextDma+0x78/0x118 [nvidia]
[ 26.912804] __nvoc_objCreateDynamic+0x54/0x60 [nvidia]
[ 26.912819] resservResourceFactory+0x74/0x100 [nvidia]
[ 26.912833] indexRemove+0x290/0x518 [nvidia]
[ 26.912848] serverAllocResourceUnderLock+0x214/0x5f0 [nvidia]
[ 26.912862] serverAllocResource+0x244/0x2e8 [nvidia]
[ 26.912877] rmapiAllocWithSecInfo+0x17c/0x2e8 [nvidia]
[ 26.912891] rmapiAllocWithSecInfoTls+0x74/0xa8 [nvidia]
[ 26.912905] rmapiInitDeprecatedContext+0x520/0x598 [nvidia]
[ 26.912940] nvkms_call_rm+0x5c/0x90 [nvidia_modeset]
[ 26.912964] nvRmApiAlloc+0x30/0x40 [nvidia_modeset]
[ 26.912985] nvkms_ioctl_common+0x174/0x1a0 [nvidia_modeset]
[ 26.913001] nvidia_frontend_unlocked_ioctl+0x58/0x78 [nvidia]
[ 26.913005] __arm64_sys_ioctl+0xa8/0xf0
[ 26.913009] el0_svc_common.constprop.0+0x7c/0x1c0
[ 26.913011] do_el0_svc+0x34/0xa0
[ 26.913014] el0_svc+0x1c/0x30
[ 26.913016] el0_sync_handler+0xa8/0xb0
[ 26.913017] el0_sync+0x16c/0x180
[ 26.913080] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 26.913130] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 26.913187] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 26.913236] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 26.913287] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 26.913339] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 26.964037] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0xffff:
[ 26.995607] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[ 26.996597] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.163333] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 27.163845] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[ 27.220323] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0xffff:
[ 27.378789] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 30.521057] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
[ 30.521981] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1175
Best regards,
Ilies
