JetPack 6.3 containerd and kubernetes
Hi
I’m trying to join our Jetson Orin ARX to our Kubernetes cluster but I am unable to get gpu support in containers running with containerd.
I basically get the same error as in this thread: Nvidia-container runtime with containerd error on Jetpack 6
But the conclusion in that thread is that this error was solved in JetPack 6 but I don’t see how that is the case. The issue is not vlanx as in the thread linked in that thread, pod network works correctly with flannel.
Running containers with gpu support in docker works as expected but not with containerd/runc.
Setup:
sudo apt install containerd nvidia-container-toolkit
sudo mkdir /etc/containerd
sudo containerd config default > /etc/containerd/config.toml
sudo nvidia-ctk runtime configure --runtime=containerd --nvidia-set-as-default
/etc/containerd/config.toml:
disabled_plugins = []
imports = []
oom_score = 0
plugin_dir = ""
required_plugins = []
root = "/var/lib/containerd"
state = "/run/containerd"
temp = ""
version = 2
[cgroup]
  path = ""
[debug]
  address = ""
  format = ""
  gid = 0
  level = ""
  uid = 0
[grpc]
  address = "/run/containerd/containerd.sock"
  gid = 0
  max_recv_message_size = 16777216
  max_send_message_size = 16777216
  tcp_address = ""
  tcp_tls_ca = ""
  tcp_tls_cert = ""
  tcp_tls_key = ""
  uid = 0
[metrics]
  address = ""
  grpc_histogram = false
[plugins]
  [plugins."io.containerd.gc.v1.scheduler"]
    deletion_threshold = 0
    mutation_threshold = 100
    pause_threshold = 0.02
    schedule_delay = "0s"
    startup_delay = "100ms"
  [plugins."io.containerd.grpc.v1.cri"]
    device_ownership_from_security_context = false
    disable_apparmor = false
    disable_cgroup = false
    disable_hugetlb_controller = true
    disable_proc_mount = false
    disable_tcp_service = true
    drain_exec_sync_io_timeout = "0s"
    enable_selinux = false
    enable_tls_streaming = false
    enable_unprivileged_icmp = false
    enable_unprivileged_ports = false
    ignore_deprecation_warnings = []
    ignore_image_defined_volumes = false
    max_concurrent_downloads = 3
    max_container_log_line_size = 16384
    netns_mounts_under_state_dir = false
    restrict_oom_score_adj = false
    sandbox_image = "registry.k8s.io/pause:3.6"
    selinux_category_range = 1024
    stats_collect_period = 10
    stream_idle_timeout = "4h0m0s"
    stream_server_address = "127.0.0.1"
    stream_server_port = "0"
    systemd_cgroup = false
    tolerate_missing_hugetlb_controller = true
    unset_seccomp_profile = ""
    [plugins."io.containerd.grpc.v1.cri".cni]
      bin_dir = "/opt/cni/bin"
      conf_dir = "/etc/cni/net.d"
      conf_template = ""
      ip_pref = ""
      max_conf_num = 1
    [plugins."io.containerd.grpc.v1.cri".containerd]
      default_runtime_name = "nvidia"
      disable_snapshot_annotations = true
      discard_unpacked_layers = false
      ignore_rdt_not_enabled_errors = false
      no_pivot = false
      snapshotter = "overlayfs"
      [plugins."io.containerd.grpc.v1.cri".containerd.default_runtime]
        base_runtime_spec = ""
        cni_conf_dir = ""
        cni_max_conf_num = 0
        container_annotations = []
        pod_annotations = []
        privileged_without_host_devices = false
        runtime_engine = ""
        runtime_path = ""
        runtime_root = ""
        runtime_type = ""
        [plugins."io.containerd.grpc.v1.cri".containerd.default_runtime.options]
      [plugins."io.containerd.grpc.v1.cri".containerd.runtimes]
        [plugins."io.containerd.grpc.v1.cri".containerd.runtimes.nvidia]
          cni_conf_dir = ""
          runtime_engine = ""
          runtime_path = ""
          runtime_root = ""
          runtime_type = "io.containerd.runc.v2"
          [plugins."io.containerd.grpc.v1.cri".containerd.runtimes.nvidia.options]
            BinaryName = "/usr/bin/nvidia-container-runtime"
            CriuImagePath = ""
            CriuPath = ""
            CriuWorkPath = ""
            IoGid = 0
            IoUid = 0
            NoNewKeyring = false
            NoPivotRoot = false
            Root = ""
            ShimCgroup = ""
            SystemdCgroup = true
        [plugins."io.containerd.grpc.v1.cri".containerd.runtimes.runc]
          cni_conf_dir = ""
          runtime_engine = ""
          runtime_path = ""
          runtime_root = ""
          [plugins."io.containerd.grpc.v1.cri".containerd.runtimes.runc.options]
            BinaryName = ""
            CriuImagePath = ""
            CriuPath = ""
            CriuWorkPath = ""
            IoGid = 0
            IoUid = 0
            NoPivotRoot = false
            Root = ""
            ShimCgroup = ""
      [plugins."io.containerd.grpc.v1.cri".containerd.untrusted_workload_runtime]
        cni_conf_dir = ""
        runtime_engine = ""
        runtime_path = ""
        runtime_root = ""
        runtime_type = ""
        [plugins."io.containerd.grpc.v1.cri".containerd.untrusted_workload_runtime.options]
    [plugins."io.containerd.grpc.v1.cri".image_decryption]
      key_model = "node"
    [plugins."io.containerd.grpc.v1.cri".registry]
      config_path = ""
      [plugins."io.containerd.grpc.v1.cri".registry.auths]
      [plugins."io.containerd.grpc.v1.cri".registry.configs]
      [plugins."io.containerd.grpc.v1.cri".registry.headers]
      [plugins."io.containerd.grpc.v1.cri".registry.mirrors]
    [plugins."io.containerd.grpc.v1.cri".x509_key_pair_streaming]
      tls_cert_file = ""
      tls_key_file = ""
  [plugins."io.containerd.internal.v1.opt"]
    path = "/opt/containerd"
  [plugins."io.containerd.internal.v1.restart"]
    interval = "10s"
  [plugins."io.containerd.internal.v1.tracing"]
  [plugins."io.containerd.metadata.v1.bolt"]
    content_sharing_policy = "shared"
  [plugins."io.containerd.monitor.v1.cgroups"]
    no_prometheus = false
  [plugins."io.containerd.runtime.v1.linux"]
    no_shim = false
    runtime = "runc"
    runtime_root = ""
    shim = "containerd-shim"
    shim_debug = false
  [plugins."io.containerd.runtime.v2.task"]
    platforms = ["linux/arm64/v8"]
    sched_core = false
  [plugins."io.containerd.service.v1.diff-service"]
    default = ["walking"]
  [plugins."io.containerd.service.v1.tasks-service"]
    rdt_config_file = ""
  [plugins."io.containerd.snapshotter.v1.aufs"]
    root_path = ""
  [plugins."io.containerd.snapshotter.v1.btrfs"]
    root_path = ""
  [plugins."io.containerd.snapshotter.v1.devmapper"]
    async_remove = false
    base_image_size = ""
    discard_blocks = false
    fs_options = ""
    fs_type = ""
    pool_name = ""
    root_path = ""
  [plugins."io.containerd.snapshotter.v1.native"]
    root_path = ""
  [plugins."io.containerd.snapshotter.v1.overlayfs"]
    mount_options = []
    root_path = ""
    sync_remove = false
    upperdir_label = false
  [plugins."io.containerd.snapshotter.v1.zfs"]
    root_path = ""
  [plugins."io.containerd.tracing.processor.v1.otlp"]
[proxy_plugins]
[stream_processors]
  [stream_processors."io.containerd.ocicrypt.decoder.v1.tar"]
    accepts = ["application/vnd.oci.image.layer.v1.tar+encrypted"]
    args = ["--decryption-keys-path", "/etc/containerd/ocicrypt/keys"]
    env = ["OCICRYPT_KEYPROVIDER_CONFIG=/etc/containerd/ocicrypt/ocicrypt_keyprovider.conf"]
    path = "ctd-decoder"
    returns = "application/vnd.oci.image.layer.v1.tar"
  [stream_processors."io.containerd.ocicrypt.decoder.v1.tar.gzip"]
    accepts = ["application/vnd.oci.image.layer.v1.tar+gzip+encrypted"]
    returns = "application/vnd.oci.image.layer.v1.tar+gzip"
[timeouts]
  "io.containerd.timeout.bolt.open" = "0s"
  "io.containerd.timeout.shim.cleanup" = "5s"
  "io.containerd.timeout.shim.load" = "5s"
  "io.containerd.timeout.shim.shutdown" = "3s"
  "io.containerd.timeout.task.state" = "2s"
[ttrpc]
  address = ""
  gid = 0
  uid = 0
If I try to launch a gpu enabled container with:
sudo ctr run --rm --gpus 0 --tty nvcr.io/nvidia/l4t-cuda:12.2.12-runtime cuda-test
I get this error:
ctr: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: NvRmMemInitNvmap failed with Permission denied
356: Memory Manager Not supported
****NvRmMemMgrInit failed**** error type: 196626
libnvrm_gpu.so: NvRmGpuLibOpen failed, error=196626
nvidia-container-cli: detection error: nvml error: unknown error: unknown
If I install docker instead and launch the container with:
sudo docker run -it --rm nvcr.io/nvidia/l4t-cuda:12.2.12-runtime
When using docker it works as expected and the GPU is accessible inside the container.
Am I doing something wrong? The same setup works on x86 machines with discrete Nvidia GPU:s.
You will need to add the account to video group to enable access.
Could you give it a try:
Ex.
$ sudo usermod -a -G video [name]
Does not seem to make any difference, I get the same error. I was already running as root so should not be needed I think.
But I did:
sudo usermod -a -G video root
sudo usermod -a -G video sysadm
sudo systemctl restart containerd
If I run the same command without “–gpu” the container starts but then the driver is not available in the container:
== CUDA ==
CUDA Version 12.2.12
Container image Copyright (c) 2016-2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
A copy of this license is made available in this container at /NGC-DL-CONTAINER-LICENSE for your convenience.
WARNING: The NVIDIA Driver was not detected.  GPU functionality will not be available.
   Use the NVIDIA Container Toolkit to start this container with GPU support; see
   https://docs.nvidia.com/datacenter/cloud-native/ .
Does the nvidia-container-cli support tegra based products?
The error seems to be coming from nvidia-container-cli.
If i run:
sudo nvidia-container-cli info
I get this error:
I have tried setting up GPU device injection using CDI according to:
https://docs.nvidia.com/datacenter/cloud-native/container-toolkit/latest/cdi-support.html
But I have been unsuccessful in getting that to work too… Any clarification on what must be done would be much appreciated since I’m out of ideas.
Confirmed that we can reproduce the same error with nvidia-container-cli.
We need to check with our internal team for more info and update.
Our internal team has confirmed that nivida-container-cli is no longer supported on Jetson that uses iGPUs.
Are there any equivalent replacement to allow gpu container runtime for Jetson?
Ok, I don’t really understand, how do I make it work? According to Supported Platforms — NVIDIA Container Toolkit 1.15.0 documentation nvidia-container-toolkit should support tegra based systems, how do I make it work with a container runtime such as containerd?
Thanks for your feedback.
We need to confirm this with our internal team and provide more info to you later.
There is a known issue with the Orin-based systems.
Our internal is now checking if the fix is included in the most recent release.
nvidia-container-cli won’t work on Jetson.
But the device plugin should have had a fix merged, please give it a try.
Please find more info in the below comment:
Thank you, I was able to get it to work in Kubernetes with device plugin version 16.1.
The documentation is lacking a bit but given your response above I suppose CDI is the only way to inject the driver into containers on Jetson platform.
I guess nvidia container runtime hook is not really required anymore but if you continue to use it the nvidia CDI device can be injected transparently like this.
# Generate cdi spec (--mode=csv workaround for jetson systems)
nvidia-ctk cdi generate --output=/etc/cdi/nvidia.yaml --mode=csv
# Force nvidia container runtime to use cdi
nvidia-ctk config --in-place --set nvidia-container-runtime.mode=cdi
# Configure containerd to use nvidia container toolkit runtime
Then I deployed nvidia-device-plugin 16.1 in kubernetes cluster:
helm repo add nvdp https://nvidia.github.io/k8s-device-plugin
helm repo update
helm upgrade -i nvdp nvdp/nvidia-device-plugin \
    --version=0.16.1 \
    --namespace nvidia-device-plugin \
    --create-namespace \
    --set gfd.enabled=true
The deployed node future discovery worker will not detect GPU on Jetson device so GPU device plugin and gpu feature discovery will not automatically be scheduled on Jetson nodes.
Therefore node must manually be labeled with “nvidia.com/gpu.present=true
kubectl label nodes jetson-orin-agx-node nvidia.com/gpu.present=true
