I have a Jetson Orin Nano and am trying to run k3s on it. However, all the pods/containers will never be created:
tyler@orin-nano-01:~$ curl -sfL https://get.k3s.io | sh -s - --docker --write-kubeconfig-mode 644 --write-kubeconfig $HOME/.kube/config
[INFO] Finding release for channel stable
[INFO] Using v1.29.6+k3s1 as release
[INFO] Downloading hash https://github.com/k3s-io/k3s/releases/download/v1.29.6+k3s1/sha256sum-arm64.txt
[INFO] Downloading binary https://github.com/k3s-io/k3s/releases/download/v1.29.6+k3s1/k3s-arm64
[INFO] Verifying binary download
[INFO] Installing k3s to /usr/local/bin/k3s
[INFO] Skipping installation of SELinux RPM
[INFO] Creating /usr/local/bin/kubectl symlink to k3s
[INFO] Creating /usr/local/bin/crictl symlink to k3s
[INFO] Skipping /usr/local/bin/ctr symlink to k3s, command exists in PATH at /usr/bin/ctr
[INFO] Creating killall script /usr/local/bin/k3s-killall.sh
[INFO] Creating uninstall script /usr/local/bin/k3s-uninstall.sh
[INFO] env: Creating environment file /etc/systemd/system/k3s.service.env
[INFO] systemd: Creating service file /etc/systemd/system/k3s.service
[INFO] systemd: Enabling k3s unit
Created symlink /etc/systemd/system/multi-user.target.wants/k3s.service → /etc/systemd/system/k3s.service.
[INFO] systemd: Starting k3s
tyler@orin-nano-01:~$ kubectl get nodes
NAME STATUS ROLES AGE VERSION
orin-nano-01 Ready control-plane,master 17s v1.29.6+k3s1
tyler@orin-nano-01:~$ kubectl get pods -A
NAMESPACE NAME READY STATUS RESTARTS AGE
kube-system coredns-6799fbcd5-f9mgq 0/1 ContainerCreating 0 7s
kube-system helm-install-traefik-5892k 0/1 ContainerCreating 0 8s
kube-system helm-install-traefik-crd-xlkb2 0/1 ContainerCreating 0 8s
kube-system local-path-provisioner-6f5d79df6-5bjpw 0/1 ContainerCreating 0 7s
kube-system metrics-server-54fd9b65b-2szjw 0/1 ContainerCreating 0 7s
tyler@orin-nano-01:~$ kubectl describe pod coredns-6799fbcd5-f9mgq -n kube-system
Namespace: kube-system
Priority: 2000000000
Priority Class Name: system-cluster-critical
Service Account: coredns
Node: orin-nano-01/192.168.1.230
Start Time: Fri, 05 Jul 2024 15:28:04 -0500
Labels: k8s-app=kube-dns
pod-template-hash=6799fbcd5
Annotations: <none>
Status: Pending
IP:
IPs: <none>
Controlled By: ReplicaSet/coredns-6799fbcd5
Containers:
coredns:
Container ID:
Image: rancher/mirrored-coredns-coredns:1.10.1
Image ID:
Ports: 53/UDP, 53/TCP, 9153/TCP
Host Ports: 0/UDP, 0/TCP, 0/TCP
Args:
-conf
/etc/coredns/Corefile
State: Waiting
Reason: ContainerCreating
Ready: False
Restart Count: 0
Limits:
memory: 170Mi
Requests:
cpu: 100m
memory: 70Mi
Liveness: http-get http://:8080/health delay=60s timeout=1s period=10s #success=1 #failure=3
Readiness: http-get http://:8181/ready delay=0s timeout=1s period=2s #success=1 #failure=3
Environment: <none>
Mounts:
/etc/coredns from config-volume (ro)
/etc/coredns/custom from custom-config-volume (ro)
/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-vdbv4 (ro)
Conditions:
Type Status
PodReadyToStartContainers False
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
config-volume:
Type: ConfigMap (a volume populated by a ConfigMap)
Optional: false
custom-config-volume:
Optional: true
kube-api-access-vdbv4:
Type: Projected (a volume that contains injected data from multiple sources)
TokenExpirationSeconds: 3607
ConfigMapName: kube-root-ca.crt
ConfigMapOptional: <nil>
DownwardAPI: true
QoS Class: Burstable
Node-Selectors: kubernetes.io/os=linux
Tolerations: CriticalAddonsOnly op=Exists
node-role.kubernetes.io/control-plane:NoSchedule op=Exists
node-role.kubernetes.io/master:NoSchedule op=Exists
node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Topology Spread Constraints: kubernetes.io/hostname:DoNotSchedule when max skew 1 is exceeded for selector k8s-app=kube-dns
Events:
Type Reason Age From Message
Normal Scheduled 19s default-scheduler Successfully assigned kube-system/coredns-6799fbcd5-f9mgq to orin-nano-01
Warning FailedCreatePodSandBox 15s kubelet Failed to create pod sandbox: rpc error: code = Unknown desc = failed to start sandbox container for pod "coredns-6799fbcd5-f9mgq": Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error setting cgroup config for procHooks process: openat2 /sys/fs/cgroup/kubepods.slice/kubepods-burstable.slice/kubepods-burstable-pod37077870_be63_4b9e_9bfa_872ce17336ca.slice/docker-6f56fb05536e2283dd3f00dc1a83ec36b0d7d5f1bde2ccd22643b87bcc0146ed.scope/cpu.weight: no such file or directory: unknown
Warning FailedCreatePodSandBox 5s kubelet Failed to create pod sandbox: rpc error: code = Unknown desc = failed to start sandbox container for pod "coredns-6799fbcd5-f9mgq": Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error setting cgroup config for procHooks process: openat2 /sys/fs/cgroup/kubepods.slice/kubepods-burstable.slice/kubepods-burstable-pod37077870_be63_4b9e_9bfa_872ce17336ca.slice/docker-a2c97b1da3c071dc360217b408e7fc0cd11fb1b8afd2b4e9c67283ddf1f5d083.scope/cpu.weight: no such file or directory: unknown
Normal SandboxChanged 4s (x2 over 9s) kubelet Pod sandbox changed, it will be killed and re-created.
Warning FailedCreatePodSandBox 1s kubelet Failed to create pod sandbox: rpc error: code = Unknown desc = failed to start sandbox container for pod "coredns-6799fbcd5-f9mgq": Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error setting cgroup config for procHooks process: openat2 /sys/fs/cgroup/kubepods.slice/kubepods-burstable.slice/kubepods-burstable-pod37077870_be63_4b9e_9bfa_872ce17336ca.slice/docker-497c9db51f20eb47b69e87fa46232f891b1747c6b403106989de0116c960ed71.scope/cpu.weight: no such file or directory: unknown
Some digging online seemed to point to cgroup related problems, but my tinkering with that hasn’t led to much.
Some background:
I’m running a custom kernel to enable the iSCSI TCP module. I followed this guide, and enabled
CONFIG_ISCI_TCP=mandCONFIG_SCSI_ISCSI_ATTRS=m(to eventually support Longhorn pods). I’ve also enabledCONFIG_FAIR_GROUP_SCHED=yandCONFIG_RT_GROUP_SCHED=yin attempts to fix this issue (to no avail). Everything else should be standard.- When I was running the “standard” kernel, k3s was able to create and run the pods.
I’m booting directly from an SSD, following this quick start guide.
I’ve updated and upgraded packages with
sudo apt update && sudo apt upgrade. -
I’m running the latest version of Jetpack:
tyler@orin-nano-01:~$ apt list --installed | grep nvidia-jetpack WARNING: apt does not have a stable CLI interface. Use with caution in scripts. nvidia-jetpack-dev/stable,now 6.0+b106 arm64 [installed,automatic] nvidia-jetpack-runtime/stable,now 6.0+b106 arm64 [installed,automatic] nvidia-jetpack/stable,now 6.0+b106 arm64 [installed] -
Other machine info:
tyler@orin-nano-01:~$ uname -a Linux orin-nano-01 5.15.136-rt-tegra #5 SMP PREEMPT_RT Fri Jul 5 13:52:58 CDT 2024 aarch64 aarch64 aarch64 GNU/Linux
Can anyone provide guidance on what I might be missing or what additional steps I should take to fix this?
