Cann't use gpu resources in containerd with k8s and orin nano
Hi,I’m having a problem about using of gpu resources in containerd. I’m using kubeEdge and k8s to deploy my system,and using Jetson orin nano 8G as my Edge nodes.
However,when I exec my container of pod and input nvidia-smi,I found that I got nothing.The details of this problem are as followed:
kubectl exec -it -n tensorrt-inference tensorrt-inference-8fd89ffb4-lxsds – /bin/bash
nvidia-smi
I’ve set NVIDIA device plugin and my app yaml by refering [Preformatted text](https://github.com/NVIDIA/k8s-device-plugin),here are my operations ans files:
sudo nvidia-ctk runtime configure --runtime=containerd --nvidia-set-as-default
sudo systemctl restart containerd
# Copyright (c) 2019, NVIDIA CORPORATION.  All rights reserved.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#     http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
apiVersion: apps/v1
kind: DaemonSet
metadata:
  namespace: kube-system
spec:
  selector:
    matchLabels:
  updateStrategy:
    type: RollingUpdate
  template:
    metadata:
      labels:
    spec:
      tolerations:
      - key: nvidia.com/gpu
        operator: Exists
        effect: NoSchedule
      # Mark this pod as a critical add-on; when enabled, the critical add-on
      # scheduler reserves resources for critical add-on pods so that they can
      # be rescheduled after a failure.
      # See https://kubernetes.io/docs/tasks/administer-cluster/guaranteed-scheduling-critical-addon-pods/
      priorityClassName: "system-node-critical"
      nodeSelector:
        nvidia.com/gpu.node: "true"
      containers:
      - image: nvcr.io/nvidia/k8s-device-plugin:v0.16.1
        env:
          - name: FAIL_ON_INIT_ERROR
            value: "false"
        securityContext:
          allowPrivilegeEscalation: false
          capabilities:
            drop: ["ALL"]
        volumeMounts:
        - name: device-plugin
          mountPath: /var/lib/kubelet/device-plugins
      volumes:
        hostPath:
          path: /var/lib/kubelet/device-plugins
apiVersion: v1
kind: Namespace
metadata:
  labels:
    pod-security.kubernetes.io/audit: privileged
    pod-security.kubernetes.io/enforce: privileged
    pod-security.kubernetes.io/warn: privileged
apiVersion: apps/v1
kind: Deployment
metadata:
  namespace: tensorrt-inference
  labels:
    app: tensorrt-inference
spec:
  replicas: 1
  selector:
    matchLabels:
  template:
    metadata:
      labels:
    spec:
      affinity:
        nodeAffinity:
          requiredDuringSchedulingIgnoredDuringExecution:
            nodeSelectorTerms:
            - matchExpressions:
              - key: kubernetes.io/arch  # 适用于 arm 平台
                operator: In
                values:
                - arm64
              - key: node-role.kubernetes.io/agent
                operator: Exists
      containers:
      - name: tensorrt-inference
        image: registry.cn-beijing.aliyuncs.com/smart_constrution/tensorrt_inference:1.0
        imagePullPolicy: IfNotPresent
        securityContext:
          privileged: true
        volumeMounts:
        - mountPath: /workspace
        command:
          - sh
        tty: true
      volumes:
      - name: workspace
        hostPath:
          path: /ssd/disk1/workspace
      hostNetwork: true
I’ve found similar problems,like [Preformatted text](https://forums.developer.nvidia.com/t/jetpack-6-3-containerd-and-kubernetes/296483) and [Preformatted text](https://forums.developer.nvidia.com/t/podman-gpu-on-jetson-agx-orin/297734),and got a solution.
But I don’t know how to solve my problem,because I don’t use podman.
Any helps of this problem would be appreciated.
This is my solution and I find my gpu with nvidia-ctk cdi list.But I don’t know what the next step is,I want to use gou resources via k8s:
(depthAI) aicons@edge1:~$ sudo nvidia-ctk cdi generate --output=/etc/cdi/nvidia.yaml --mode=csv
WARN[0000] Skipping CSV file /etc/nvidia-container-runtime/host-files-for-container.d/l4t.csv: failed to parse CSV file: failed to open /etc/nvidia-container-runtime/host-files-for-container.d/l4t.csv for reading: open /etc/nvidia-container-runtime/host-files-for-container.d/l4t.csv: no such file or directory
INFO[0000] Selecting /dev/dri/card0 as /dev/dri/card0
INFO[0000] Selecting /dev/dri/renderD128 as /dev/dri/renderD128
WARN[0000] Could not locate /dev/fb0: pattern /dev/fb0 not found
WARN[0000] Could not locate /dev/fb1: pattern /dev/fb1 not found
INFO[0000] Selecting /dev/host1x-fence as /dev/host1x-fence
INFO[0000] Selecting /dev/nvhost-as-gpu as /dev/nvhost-as-gpu
INFO[0000] Selecting /dev/nvhost-ctrl-gpu as /dev/nvhost-ctrl-gpu
WARN[0000] Could not locate /dev/nvhost-ctrl-nvdla0: pattern /dev/nvhost-ctrl-nvdla0 not found
WARN[0000] Could not locate /dev/nvhost-ctrl-nvdla1: pattern /dev/nvhost-ctrl-nvdla1 not found
WARN[0000] Could not locate /dev/nvhost-ctrl-pva0: pattern /dev/nvhost-ctrl-pva0 not found
INFO[0000] Selecting /dev/nvhost-ctxsw-gpu as /dev/nvhost-ctxsw-gpu
INFO[0000] Selecting /dev/nvhost-dbg-gpu as /dev/nvhost-dbg-gpu
INFO[0000] Selecting /dev/nvhost-gpu as /dev/nvhost-gpu
INFO[0000] Selecting /dev/nvhost-nvsched-gpu as /dev/nvhost-nvsched-gpu
INFO[0000] Selecting /dev/nvhost-power-gpu as /dev/nvhost-power-gpu
INFO[0000] Selecting /dev/nvhost-prof-ctx-gpu as /dev/nvhost-prof-ctx-gpu
INFO[0000] Selecting /dev/nvhost-prof-dev-gpu as /dev/nvhost-prof-dev-gpu
INFO[0000] Selecting /dev/nvhost-prof-gpu as /dev/nvhost-prof-gpu
INFO[0000] Selecting /dev/nvhost-sched-gpu as /dev/nvhost-sched-gpu
INFO[0000] Selecting /dev/nvhost-tsg-gpu as /dev/nvhost-tsg-gpu
INFO[0000] Selecting /dev/nvgpu/igpu0/as as /dev/nvgpu/igpu0/as
INFO[0000] Selecting /dev/nvgpu/igpu0/channel as /dev/nvgpu/igpu0/channel
INFO[0000] Selecting /dev/nvgpu/igpu0/ctrl as /dev/nvgpu/igpu0/ctrl
INFO[0000] Selecting /dev/nvgpu/igpu0/ctxsw as /dev/nvgpu/igpu0/ctxsw
INFO[0000] Selecting /dev/nvgpu/igpu0/dbg as /dev/nvgpu/igpu0/dbg
INFO[0000] Selecting /dev/nvgpu/igpu0/nvsched as /dev/nvgpu/igpu0/nvsched
INFO[0000] Selecting /dev/nvgpu/igpu0/power as /dev/nvgpu/igpu0/power
INFO[0000] Selecting /dev/nvgpu/igpu0/prof as /dev/nvgpu/igpu0/prof
INFO[0000] Selecting /dev/nvgpu/igpu0/prof-ctx as /dev/nvgpu/igpu0/prof-ctx
INFO[0000] Selecting /dev/nvgpu/igpu0/prof-dev as /dev/nvgpu/igpu0/prof-dev
INFO[0000] Selecting /dev/nvgpu/igpu0/sched as /dev/nvgpu/igpu0/sched
INFO[0000] Selecting /dev/nvgpu/igpu0/tsg as /dev/nvgpu/igpu0/tsg
INFO[0000] Selecting /dev/nvidia-modeset as /dev/nvidia-modeset
INFO[0000] Selecting /dev/nvidia0 as /dev/nvidia0
INFO[0000] Selecting /dev/nvidiactl as /dev/nvidiactl
INFO[0000] Selecting /dev/nvmap as /dev/nvmap
INFO[0000] Selecting /dev/nvsciipc as /dev/nvsciipc
INFO[0000] Selecting /dev/v4l2-nvdec as /dev/v4l2-nvdec
WARN[0000] Could not locate /dev/v4l2-nvenc: pattern /dev/v4l2-nvenc not found
INFO[0000] Selecting /dev/dri/by-path as /dev/dri/by-path
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvv4l2.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvv4l2.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/desktop-shell.so as /usr/lib/aarch64-linux-gnu/nvidia/weston/desktop-shell.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/drm-backend.so as /usr/lib/aarch64-linux-gnu/nvidia/weston/drm-backend.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/EGLWLInputEventExample as /usr/lib/aarch64-linux-gnu/nvidia/weston/EGLWLInputEventExample
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/EGLWLMockNavigation as /usr/lib/aarch64-linux-gnu/nvidia/weston/EGLWLMockNavigation
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/fullscreen-shell.so as /usr/lib/aarch64-linux-gnu/nvidia/weston/fullscreen-shell.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/gl-renderer.so as /usr/lib/aarch64-linux-gnu/nvidia/weston/gl-renderer.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/hmi-controller.so as /usr/lib/aarch64-linux-gnu/nvidia/weston/hmi-controller.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/ivi-controller.so as /usr/lib/aarch64-linux-gnu/nvidia/weston/ivi-controller.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/ivi-shell.so as /usr/lib/aarch64-linux-gnu/nvidia/weston/ivi-shell.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/LayerManagerControl as /usr/lib/aarch64-linux-gnu/nvidia/weston/LayerManagerControl
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/libilmClient.so.2.2.0 as /usr/lib/aarch64-linux-gnu/nvidia/weston/libilmClient.so.2.2.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/libilmCommon.so.2.2.0 as /usr/lib/aarch64-linux-gnu/nvidia/weston/libilmCommon.so.2.2.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/libilmControl.so.2.2.0 as /usr/lib/aarch64-linux-gnu/nvidia/weston/libilmControl.so.2.2.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/libilmInput.so.2.2.0 as /usr/lib/aarch64-linux-gnu/nvidia/weston/libilmInput.so.2.2.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/libweston-6.so.0 as /usr/lib/aarch64-linux-gnu/nvidia/weston/libweston-6.so.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/libweston-desktop-6.so.0 as /usr/lib/aarch64-linux-gnu/nvidia/weston/libweston-desktop-6.so.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/simple-weston-client as /usr/lib/aarch64-linux-gnu/nvidia/weston/simple-weston-client
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/spring-tool as /usr/lib/aarch64-linux-gnu/nvidia/weston/spring-tool
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/wayland-backend.so as /usr/lib/aarch64-linux-gnu/nvidia/weston/wayland-backend.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-calibrator as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-calibrator
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-clickdot as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-clickdot
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-cliptest as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-cliptest
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-content-protection as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-content-protection
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-debug as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-debug
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-desktop-shell as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-desktop-shell
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-dnd as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-dnd
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-eventdemo as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-eventdemo
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-flower as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-flower
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-fullscreen as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-fullscreen
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-image as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-image
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-info as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-info
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-ivi-shell-user-interface as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-ivi-shell-user-interface
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-keyboard as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-keyboard
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-launch as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-launch
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-multi-resource as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-multi-resource
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-output-mode as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-output-mode
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-resizor as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-resizor
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-scaler as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-scaler
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-screenshooter as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-screenshooter
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-dmabuf-egldevice as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-dmabuf-egldevice
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-egl as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-egl
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-pattern-hdr as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-pattern-hdr
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-shm as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-shm
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-touch as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-simple-touch
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-smoke as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-smoke
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-stacking as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-stacking
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-subsurfaces as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-subsurfaces
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-terminal as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-terminal
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-transformed as /usr/lib/aarch64-linux-gnu/nvidia/weston/weston-transformed
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvdrmvideosink.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvdrmvideosink.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvipcpipeline.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvipcpipeline.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvtee.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvtee.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/nvgstcapture-1.0_README.txt as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/nvgstcapture-1.0_README.txt
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/nvgstipctestapp-1.0_README.txt as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/nvgstipctestapp-1.0_README.txt
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/gstreamer-1.0/nvgstplayer-1.0_README.txt as /usr/lib/aarch64-linux-gnu/gstreamer-1.0/nvgstplayer-1.0_README.txt
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/libgstnvegl-1.0.so.0 as /usr/lib/aarch64-linux-gnu/libgstnvegl-1.0.so.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/libgstnvexifmeta.so as /usr/lib/aarch64-linux-gnu/libgstnvexifmeta.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/libgstnvivameta.so as /usr/lib/aarch64-linux-gnu/libgstnvivameta.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/libnvsample_cudaprocess.so as /usr/lib/aarch64-linux-gnu/libnvsample_cudaprocess.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libgstnvcustomhelper.so.1.0.0 as /usr/lib/aarch64-linux-gnu/nvidia/libgstnvcustomhelper.so.1.0.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libgstnvdsseimeta.so.1.0.0 as /usr/lib/aarch64-linux-gnu/nvidia/libgstnvdsseimeta.so.1.0.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnveglstreamproducer.so as /usr/lib/aarch64-linux-gnu/nvidia/libnveglstreamproducer.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvdla_compiler.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvdla_compiler.so
INFO[0000] Selecting /etc/vulkansc/icd.d/nvidia_icd_vksc.json as /etc/vulkansc/icd.d/nvidia_icd_vksc.json
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/ld.so.conf as /usr/lib/aarch64-linux-gnu/nvidia/ld.so.conf
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libcuda.so.1.1 as /usr/lib/aarch64-linux-gnu/nvidia/libcuda.so.1.1
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libGLX_nvidia.so.0 as /usr/lib/aarch64-linux-gnu/nvidia/libGLX_nvidia.so.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libjetsonpower.so as /usr/lib/aarch64-linux-gnu/nvidia/libjetsonpower.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvargus.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvargus.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvargus_socketclient.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvargus_socketclient.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvargus_socketserver.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvargus_socketserver.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvbuf_fdmap.so.1.0.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvbuf_fdmap.so.1.0.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurface.so.1.0.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurface.so.1.0.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurftransform.so.1.0.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurftransform.so.1.0.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcameratools.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcameratools.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcamerautils.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcamerautils.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcam_imageencoder.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcam_imageencoder.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcamlog.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcamlog.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcamv4l2.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcamv4l2.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcapture.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcapture.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcolorutil.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcolorutil.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcucompat.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcucompat.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcudla.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcudla.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvcuvidv4l2.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvcuvidv4l2.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvdc.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvdc.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvddk_2d_v2.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvddk_2d_v2.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvddk_vic.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvddk_vic.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvdecode2eglimage.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvdecode2eglimage.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvdla_runtime.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvdla_runtime.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvdsbufferpool.so.1.0.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvdsbufferpool.so.1.0.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnveventlib.so as /usr/lib/aarch64-linux-gnu/nvidia/libnveventlib.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvexif.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvexif.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvfnet.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvfnet.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstoredefog.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstoredefog.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstorehdfx.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstorehdfx.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvfusacapinterface.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvfusacapinterface.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvfusacap.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvfusacap.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_boot.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_boot.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_camera.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_camera.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_force.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_force.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_generic.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_generic.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_gpucompute.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_gpucompute.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_graphics.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_graphics.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_il.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_il.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_spincircle.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_spincircle.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_tbc.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_tbc.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_ui.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_ui.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-allocator.so.1 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-allocator.so.1
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-eglcore.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-eglcore.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-gbm.so.1.1.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-gbm.so.1.1.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-wayland.so.1.1.11 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-wayland.so.1.1.11
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glcore.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glcore.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glsi.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glsi.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glvkspirv.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glvkspirv.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-gpucomp.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-gpucomp.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-kms.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-kms.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-ml.so.1 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-ml.so.1
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-nvvm.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-nvvm.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-ptxjitcompiler.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-ptxjitcompiler.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-rmapi-tegra.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-rmapi-tegra.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-rtcore.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-rtcore.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-tls.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-tls.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-vksc-core.so.540.3.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-vksc-core.so.540.3.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvid_mapper.so.1.0.0 as /usr/lib/aarch64-linux-gnu/nvidia/libnvid_mapper.so.1.0.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvimp.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvimp.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvisppg.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvisppg.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvisp.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvisp.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvisp_utils.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvisp_utils.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvjpeg.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvjpeg.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_2d.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_2d.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia2d.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia2d.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_dla.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_dla.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_eglstream.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_eglstream.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ide_parser.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ide_parser.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ide_sci.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ide_sci.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_iep_sci.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_iep_sci.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ijpd_sci.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ijpd_sci.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ijpe_sci.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ijpe_sci.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_iofa_sci.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_iofa_sci.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_isp_ext.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_isp_ext.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedialdc.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedialdc.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_tensor.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_tensor.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_contentpipe.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_contentpipe.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_image.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_image.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_utils.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_utils.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_video.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_video.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_parser.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_parser.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmm.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmm.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_utils.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_utils.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvodm_imager.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvodm_imager.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvofsdk.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvofsdk.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvoggopus.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvoggopus.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvomxilclient.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvomxilclient.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvomx.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvomx.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvosd.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvosd.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvos.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvos.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvparser.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvparser.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvphsd.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvphsd.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvphs.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvphs.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvplayfair.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvplayfair.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvpva_algorithms.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvpva_algorithms.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvpvaintf.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvpvaintf.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvpva.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvpva.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvpvaumd.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvpvaumd.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_chip.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_chip.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_gpu.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_gpu.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_host1x.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_host1x.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_mem.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_mem.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_stream.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_stream.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_surface.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_surface.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_sync.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_sync.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvscf.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvscf.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvscibuf.so.1 as /usr/lib/aarch64-linux-gnu/nvidia/libnvscibuf.so.1
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvscicommon.so.1 as /usr/lib/aarch64-linux-gnu/nvidia/libnvscicommon.so.1
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvscievent.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvscievent.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvsciipc.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvsciipc.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvscistream.so.1 as /usr/lib/aarch64-linux-gnu/nvidia/libnvscistream.so.1
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvscisync.so.1 as /usr/lib/aarch64-linux-gnu/nvidia/libnvscisync.so.1
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvsocsys.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvsocsys.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvtegrahv.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvtegrahv.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvtracebuf.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvtracebuf.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvtvmr_2d.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvtvmr_2d.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvtvmr.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvtvmr.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvv4lconvert.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvv4lconvert.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvvic.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvvic.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvvideoencode_ppe.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvvideoencode_ppe.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libnvvideo.so as /usr/lib/aarch64-linux-gnu/nvidia/libnvvideo.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libsensors.hal-client.nvs.so as /usr/lib/aarch64-linux-gnu/nvidia/libsensors.hal-client.nvs.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libsensors_hal.nvs.so as /usr/lib/aarch64-linux-gnu/nvidia/libsensors_hal.nvs.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libsensors.l4t.no_fusion.nvs.so as /usr/lib/aarch64-linux-gnu/nvidia/libsensors.l4t.no_fusion.nvs.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libtegrav4l2.so as /usr/lib/aarch64-linux-gnu/nvidia/libtegrav4l2.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libtegrawfd.so as /usr/lib/aarch64-linux-gnu/nvidia/libtegrawfd.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvargus.so as /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvargus.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvcuvidvideocodec.so as /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvcuvidvideocodec.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvvideocodec.so as /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvvideocodec.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libVkLayer_json_gen.so as /usr/lib/aarch64-linux-gnu/nvidia/libVkLayer_json_gen.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libVkSCLayer_khronos_validation.so as /usr/lib/aarch64-linux-gnu/nvidia/libVkSCLayer_khronos_validation.so
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/libvulkansc.so.1.0.10 as /usr/lib/aarch64-linux-gnu/nvidia/libvulkansc.so.1.0.10
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/nvidia/nvidia_icd.json as /usr/lib/aarch64-linux-gnu/nvidia/nvidia_icd.json
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf as /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0 as /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv1_CM_nvidia.so.1 as /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv1_CM_nvidia.so.1
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2 as /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2
INFO[0000] Selecting /usr/lib/aarch64-linux-gnu/tegra-egl/nvidia.json as /usr/lib/aarch64-linux-gnu/tegra-egl/nvidia.json
INFO[0000] Selecting /usr/lib/firmware/tegra19x/nvhost_nvdec040_ns.fw as /usr/lib/firmware/tegra19x/nvhost_nvdec040_ns.fw
INFO[0000] Selecting /usr/lib/firmware/tegra23x/nvhost_nvdec050_desc_prod.bin as /usr/lib/firmware/tegra23x/nvhost_nvdec050_desc_prod.bin
INFO[0000] Selecting /usr/sbin/nvidia-smi as /usr/sbin/nvidia-smi
INFO[0000] Selecting /usr/share/doc/nvidia-tegra/LICENSE.nvidia-smi as /usr/share/doc/nvidia-tegra/LICENSE.nvidia-smi
WARN[0000] Could not locate /usr/lib/aarch64-linux-gnu/tegra: pattern /usr/lib/aarch64-linux-gnu/tegra not found
INFO[0000] Selecting /etc/nv_tegra_release as /etc/nv_tegra_release
WARN[0000] Failed to locate symlink /usr/lib/aarch64-linux-gnu/tegra
INFO[0000] Generated CDI spec with version 0.5.0
(depthAI) aicons@edge1:~$ nvidia-ctk cdi list
INFO[0000] Found 2 CDI devices
nvidia.com/gpu=0
nvidia.com/gpu=all
The CSV solution is merged to the NVIDIA Container Toolkit and the NVIDIA GPU Device plugin (v1.16.1 and v0.16.0) so you should not need it anymore.
What is the exact output of the nvidia-smi?
Is there any error or just empty?
