Kubeedge gpu jetson
edge01,docker,cri-docker,
root@zckmaster:/home/zck# kubectl get pods -A -o wide
NAMESPACE NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
default gpu-deployment-64f6b8cb49-vsr82 0/1 RunContainerError 55 (12s ago) 3h56m 10.88.0.31 edge01
kube-flannel kube-flannel-cloud-ds-vks67 1/1 Running 5 (8h ago) 3d8h 192.168.31.155 zckmaster
kube-system coredns-66f779496c-t96dj 1/1 Running 4 (8h ago) 3d8h 10.244.0.20 zckmaster
kube-system coredns-66f779496c-vwvhk 1/1 Running 4 (8h ago) 3d8h 10.244.0.19 zckmaster
kube-system etcd-zckmaster 1/1 Running 4 (8h ago) 3d8h 192.168.31.155 zckmaster
kube-system kube-apiserver-zckmaster 1/1 Running 8 (8h ago) 3d8h 192.168.31.155 zckmaster
kube-system kube-controller-manager-zckmaster 1/1 Running 6 (8h ago) 3d8h 192.168.31.155 zckmaster
kube-system kube-proxy-jgmjm 1/1 Running 4 (8h ago) 3d8h 192.168.31.155 zckmaster
kube-system kube-scheduler-zckmaster 1/1 Running 5 (8h ago) 3d8h 192.168.31.155 zckmaster
kube-system metrics-server-98cfbdb89-cv5jw 1/1 Running 2 (8h ago) 32h 192.168.31.155 zckmaster
kube-system nvidia-device-plugin-daemonset-24q4f 0/1 Terminating 0 2d6h nvidia-desktop
kube-system nvidia-device-plugin-daemonset-d6zq5 1/1 Running 0 3h58m 10.88.0.30 edge01
kubeedge cloudcore-6c6b957ff8-wkcrt 1/1 Running 16 (8h ago) 9h 192.168.31.155 zckmaster
kubeedge edge-eclipse-mosquitto-2dpf2 1/1 Running 6 (34h ago) 2d10h 192.168.31.175 nvidia-desktop
kubeedge edge-eclipse-mosquitto-ddw89 1/1 Running 3 (5h33m ago) 32h 192.168.31.175 edge01
kubeedge edge-eclipse-mosquitto-r4zwr 1/1 Running 1 (8h ago) 3d6h 192.168.159.186 zck-virtual-machine
find gpu-deployment-64f6b8cb49-vsr82 is bad
root@zckmaster:/home/zck# kubectl describe pod gpu-deployment-64f6b8cb49-vsr82
Namespace: default
Priority: 0
Service Account: default
Node: edge01/192.168.31.175
Start Time: Fri, 25 Jul 2025 20:30:02 +0800
Labels: app=gpu
pod-template-hash=64f6b8cb49
Annotations:
Status: Running
IP: 10.88.0.31
IPs:
IP: 10.88.0.31
Controlled By: ReplicaSet/gpu-deployment-64f6b8cb49
Containers:
gpu-container:
Container ID: docker://a63efd122233f14aa86bf09c1effe02f4b62f46cb3888e0a272089cc838e427e
Image: mnist:2.0
Image ID: docker://sha256:152ccec105291c7dc8aecab2cd0344aa3b7e708bf1af0af351505571297ab038
Port: 80/TCP
Host Port: 0/TCP
State: Waiting
Reason: CrashLoopBackOff
Last State: Terminated
Reason: ContainerCannotRun
Message: failed to create task for container: failed to create shim task: OCI runtime create failed: could not apply required modification to OCI specification: error modifying OCI spec: failed to inject CDI devices: unresolvable CDI devices nvidia.com/gpu=tegra: unknown
Exit Code: 128
Started: Sat, 26 Jul 2025 00:26:14 +0800
Finished: Sat, 26 Jul 2025 00:26:14 +0800
Ready: False
Restart Count: 55
Limits:
cpu: 1
memory: 512Mi
nvidia.com/gpu: 1
Requests:
cpu: 1
memory: 512Mi
nvidia.com/gpu: 1
Environment:
Mounts:
/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-7xbb6 (ro)
Conditions:
Type Status
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
kube-api-access-7xbb6:
Type: Projected (a volume that contains injected data from multiple sources)
TokenExpirationSeconds: 3607
ConfigMapName: kube-root-ca.crt
ConfigMapOptional:
DownwardAPI: true
QoS Class: Guaranteed
Node-Selectors:
Tolerations: node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
find nvidia-device-plugin-daemonset-d6zq5 is good
oot@zckmaster:/home/zck# kubectl logs nvidia-device-plugin-daemonset-d6zq5 -n kube-system
I0725 12:27:59.174360 1 main.go:199] Starting FS watcher.
I0725 12:27:59.174677 1 main.go:206] Starting OS watcher.
I0725 12:27:59.175839 1 main.go:221] Starting Plugins.
I0725 12:27:59.175876 1 main.go:278] Loading configuration.
I0725 12:27:59.179561 1 main.go:303] Updating config with default resource matching patterns.
I0725 12:27:59.179967 1 main.go:314]
Running with config:
“version”: “v1”,
“flags”: {
“migStrategy”: “none”,
“failOnInitError”: false,
“mpsRoot”: “”,
“nvidiaDriverRoot”: “/”,
“nvidiaDevRoot”: “/”,
“gdsEnabled”: false,
“mofedEnabled”: false,
“useNodeFeatureAPI”: null,
“deviceDiscoveryStrategy”: “auto”,
“plugin”: {
“passDeviceSpecs”: false,
“deviceListStrategy”: [
“envvar”
“deviceIDStrategy”: “uuid”,
“cdiAnnotationPrefix”: “cdi.k8s.io/”,
“nvidiaCTKPath”: “/usr/bin/nvidia-ctk”,
“containerDriverRoot”: “/driver-root”
“resources”: {
“gpus”: [
“pattern”: “",
“name”: “nvidia.com/gpu
“sharing”: {
“timeSlicing”: {}
I0725 12:27:59.179988 1 main.go:317] Retrieving plugins.
I0725 12:27:59.200510 1 server.go:216] Starting GRPC server for ‘nvidia.com/gpu
I0725 12:27:59.201963 1 server.go:147] Starting to serve ‘nvidia.com/gpu’ on /var/lib/kubelet/device-plugins/nvidia-gpu.sock
I0725 12:27:59.205694 1 server.go:154] Registered device plugin for ‘nvidia.com/gpu’ with Kubelet
I0725 16:10:13.496282 1 main.go:246] inotify: /var/lib/kubelet/device-plugins/kubelet.sock created, restarting.
I0725 16:10:13.496431 1 main.go:353] Stopping plugins.
I0725 16:10:13.496455 1 server.go:185] Stopping to serve ‘nvidia.com/gpu’ on /var/lib/kubelet/device-plugins/nvidia-gpu.sock
I0725 16:10:13.496807 1 main.go:221] Starting Plugins.
I0725 16:10:13.496825 1 main.go:278] Loading configuration.
I0725 16:10:13.497593 1 main.go:303] Updating config with default resource matching patterns.
I0725 16:10:13.497829 1 main.go:314]
“version”: “v1”,
“flags”: {
“mpsRoot”: “”,
“plugin”: {
“envvar”
“resources”: {
“gpus”: [
“pattern”: "
“sharing”: {
“timeSlicing”: {}
I0725 16:10:13.497854 1 main.go:317] Retrieving plugins.
I0725 16:10:13.517453 1 server.go:216] Starting GRPC server for ‘nvidia.com/gpu
I0725 16:10:13.519003 1 server.go:147] Starting to serve ‘nvidia.com/gpu’ on /var/lib/kubelet/device-plugins/nvidia-gpu.sock
I0725 16:10:13.525814 1 server.go:154] Registered device plugin for ‘nvidia.com/gpu’ with Kubelet
i donot know where wrong please help me
The issue you’re facing appears to be related to a Kubernetes deployment on a Jetson Orin Nano device, specifically with a pod named gpudeployment64f6b8cb49vsr82 that is experiencing a RunContainerError and is in a CrashLoopBackOff state. This indicates that the container within the pod is crashing or failing to start, causing Kubernetes to repeatedly attempt to restart it.
To diagnose and potentially resolve this issue, let’s break down the key points from the information provided:
  1. Pod Status: The pod gpudeployment64f6b8cb49vsr82 is in a Running state but has a Ready status of False, indicating that the container within the pod is not ready to receive traffic. The Restart Count is 55, showing that the container has been restarted many times.
  2. Container Error: The container gpucontainer within the pod has a State of Waiting with a Reason of CrashLoopBackOff. The Last State is Terminated with an Exit Code of 128. The Message indicates a failure to create a task for the container due to an inability to apply required modifications to the OCI specification, specifically mentioning an error related to injecting CDI devices (nvidia.com/gpu) and an unknown device (nvidia.com/gpu-tegra).
  3. NVIDIA Device Plugin: The logs from the nvidiadeviceplugindaemonsetd6zq5 pod, which is responsible for managing NVIDIA GPU devices in the Kubernetes cluster, show successful startup and registration of the device plugin with Kubelet. This suggests that the NVIDIA device plugin is functioning correctly and is able to serve the nvidia.com/gpu resource.
Comparison and Analysis:
  • Device Plugin vs. Pod Error: The successful operation of the NVIDIA device plugin contrasts with the error experienced by the gpudeployment64f6b8cb49vsr82 pod. This suggests that the issue might not be with the device plugin itself but rather with how the pod is configured to use the GPU resource or with the environment in which the pod is running.
  • Container Runtime and OCI Specification: The error message mentions a failure to apply modifications to the OCI specification, which is related to the container runtime environment. This could indicate a compatibility issue between the container runtime (e.g., Docker) and the NVIDIA device plugin, or an issue with the container’s configuration.
  • GPU Resource Allocation: The pod’s configuration requests 1 GPU (nvidia.com/gpu: 1), which should be allocatable given the successful operation of the NVIDIA device plugin. However, the error related to injecting CDI devices suggests there might be an issue with how the GPU resource is being requested or allocated to the container.
Potential Solutions:
  1. Check Container Runtime Compatibility: Ensure that the container runtime (e.g., Docker) is compatible with the NVIDIA device plugin and the Jetson Orin Nano’s GPU architecture.
  2. Verify Pod Configuration: Review the pod’s configuration to ensure that it correctly requests and utilizes the nvidia.com/gpu resource. Check for any typos or incorrect settings in the pod’s YAML/JSON definition.
  3. Update NVIDIA Device Plugin: If you’re using an older version of the NVIDIA device plugin, consider updating to the latest version, as newer versions may resolve known issues or improve compatibility.
  4. Inspect Container Runtime Logs: Look into the container runtime logs (e.g., Docker logs) for more detailed error messages that might provide additional insight into the failure to create the container.
  5. Environment and Dependency Checks: Ensure that all necessary dependencies for running GPU-accelerated containers are installed and configured correctly on the Jetson Orin Nano device.
By systematically addressing these potential issues, you should be able to identify and resolve the problem preventing your pod from running successfully.
jetpack
I noticed that when I enter
sudo nvidia-ctk cdi generate --output=/etc/cdi/nvidia.yaml --mode=csv
and then run
nvidia-ctk cdi list,
the terminal only shows
nvidia.com/gpu=all and nvidia.com/gpu=0,
but nvidia.com/gpu=tegra is missing.
After I manually added tegra to /etc/cdi/nvidia.yaml and regenerated the file, the container failed with:
This error disappeared once I resolved the issue, but why does nvidia-ctk cdi list (version 6.2.1) fail to generate nvidia.com/gpu=tegra automatically?
HELP HELP
Could you share more info about how you solve the issue?
After generating the file, can Kubernetes run well on your environment?
in /etc/cdi/nvidia.yaml
**I duplicated the block for nvidia.com/gpu=0, pasted it at the end of the file, and renamed it to nvidia.com/gpu=tegra. **
Is the device name nvidia.com/gpu=tegra present in other JetPack versions, or is this simply an instability in version 6.2.1?
  • containerEdits:
    deviceNodes:
    • path: /dev/host1x-fence
    • path: /dev/nvhost-as-gpu
    • path: /dev/nvhost-ctrl-gpu
    • path: /dev/nvhost-ctxsw-gpu
    • path: /dev/nvhost-dbg-gpu
    • path: /dev/nvhost-gpu
    • path: /dev/nvhost-nvsched-gpu
    • path: /dev/nvhost-power-gpu
    • path: /dev/nvhost-prof-ctx-gpu
    • path: /dev/nvhost-prof-dev-gpu
    • path: /dev/nvhost-prof-gpu
    • path: /dev/nvhost-sched-gpu
    • path: /dev/nvhost-tsg-gpu
    • path: /dev/nvidia-modeset
    • path: /dev/nvidia0
    • path: /dev/nvidiactl
    • path: /dev/nvmap
    • path: /dev/nvsciipc
    • path: /dev/v4l2-nvdec
    • path: /dev/dri/card0
    • path: /dev/dri/card1
    • path: /dev/dri/renderD128
    • path: /dev/dri/renderD129
    • path: /dev/nvgpu/igpu0/as
    • path: /dev/nvgpu/igpu0/channel
    • path: /dev/nvgpu/igpu0/ctrl
    • path: /dev/nvgpu/igpu0/ctxsw
    • path: /dev/nvgpu/igpu0/dbg
    • path: /dev/nvgpu/igpu0/nvsched
    • path: /dev/nvgpu/igpu0/power
    • path: /dev/nvgpu/igpu0/prof
    • path: /dev/nvgpu/igpu0/prof-ctx
    • path: /dev/nvgpu/igpu0/prof-dev
    • path: /dev/nvgpu/igpu0/sched
    • path: /dev/nvgpu/igpu0/tsg
      hooks:
    • args:
      • nvidia-cdi-hook
      • create-symlinks
      • –link
      • /usr/lib/aarch64-linux-gnu/nvidia/nvidia_icd.json::/etc/vulkan/icd.d/nvidia_icd.json
      • –link
      • ../nvidia/libnvidia-allocator.so::/usr/lib/aarch64-linux-gnu/gbm/nvidia-drm_gbm.so
      • –link
      • libnvidia-allocator.so.1::/usr/lib/aarch64-linux-gnu/nvidia/libnvidia-allocator.so
      • –link
      • ../nvidia/libnvidia-allocator.so::/usr/lib/aarch64-linux-gnu/gbm/tegra_gbm.so
      • –link
      • ../nvidia/libnvidia-allocator.so::/usr/lib/aarch64-linux-gnu/gbm/tegra-udrm_gbm.so
      • –link
      • nvidia/libcuda.so::/usr/lib/aarch64-linux-gnu/libcuda.so
      • –link
      • libcuda.so.1.1::/usr/lib/aarch64-linux-gnu/nvidia/libcuda.so
      • –link
      • nvidia/libnvcucompat.so::/usr/lib/aarch64-linux-gnu/libnvcucompat.so
      • –link
      • nvidia/libnvcudla.so::/usr/lib/aarch64-linux-gnu/libnvcudla.so
      • –link
      • nvidia/libnvv4l2.so::/usr/lib/aarch64-linux-gnu/libv4l2.so.0.0.999999
      • –link
      • nvidia/libnvv4lconvert.so::/usr/lib/aarch64-linux-gnu/libv4lconvert.so.0.0.999999
      • –link
      • ../../../nvidia/libv4l2_nvargus.so::/usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so
      • –link
      • ../../../nvidia/libv4l2_nvcuvidvideocodec.so::/usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvcuvidvideocodec.so
      • –link
      • ../../../nvidia/libv4l2_nvvideocodec.so::/usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvvideocodec.so
      • –link
      • libcuda.so.1.1::/usr/lib/aarch64-linux-gnu/nvidia/libcuda.so.1
      • –link
      • libnvbufsurface.so.1.0.0::/usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurface.so
      • –link
      • libnvbufsurftransform.so.1.0.0::/usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurftransform.so
      • –link
      • libnvdsbufferpool.so.1.0.0::/usr/lib/aarch64-linux-gnu/nvidia/libnvdsbufferpool.so
      • –link
      • libnvidia-egl-gbm.so.1.1.0::/usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-gbm.so.1
      • –link
      • libnvidia-egl-wayland.so.1.1.11::/usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-wayland.so.1
      • –link
      • libnvidia-kms.so.540.4.0::/usr/lib/aarch64-linux-gnu/nvidia/libnvidia-kms.so
      • –link
      • libnvidia-nvvm.so.540.4.0::/usr/lib/aarch64-linux-gnu/nvidia/libnvidia-nvvm.so.4
      • –link
      • libnvidia-ptxjitcompiler.so.540.4.0::/usr/lib/aarch64-linux-gnu/nvidia/libnvidia-ptxjitcompiler.so.1
      • –link
      • libnvidia-vksc-core.so.1::/usr/lib/aarch64-linux-gnu/nvidia/libnvidia-vksc-core.so
      • –link
      • libnvidia-vksc-core.so.540.4.0::/usr/lib/aarch64-linux-gnu/nvidia/libnvidia-vksc-core.so.1
      • –link
      • libnvid_mapper.so.1.0.0::/usr/lib/aarch64-linux-gnu/nvidia/libnvid_mapper.so
      • –link
      • libnvscibuf.so.1::/usr/lib/aarch64-linux-gnu/nvidia/libnvscibuf.so
      • –link
      • libnvscicommon.so.1::/usr/lib/aarch64-linux-gnu/nvidia/libnvscicommon.so
      • –link
      • libnvscistream.so.1::/usr/lib/aarch64-linux-gnu/nvidia/libnvscistream.so
      • –link
      • libnvscisync.so.1::/usr/lib/aarch64-linux-gnu/nvidia/libnvscisync.so
      • –link
      • libnvv4l2.so::/usr/lib/aarch64-linux-gnu/nvidia/libv4l2.so.0
      • –link
      • libnvv4lconvert.so::/usr/lib/aarch64-linux-gnu/nvidia/libv4lconvert.so.0
      • –link
      • libvulkansc.so.1::/usr/lib/aarch64-linux-gnu/nvidia/libvulkansc.so
      • –link
      • libvulkansc.so.1.0.10::/usr/lib/aarch64-linux-gnu/nvidia/libvulkansc.so.1
      • –link
      • libwayland-client.so.0::/usr/lib/aarch64-linux-gnu/nvidia/libwayland-client.so
      • –link
      • libwayland-client.so.0.22.0::/usr/lib/aarch64-linux-gnu/nvidia/libwayland-client.so.0
      • –link
      • libwayland-cursor.so.0::/usr/lib/aarch64-linux-gnu/nvidia/libwayland-cursor.so
      • –link
      • libwayland-cursor.so.0.22.0::/usr/lib/aarch64-linux-gnu/nvidia/libwayland-cursor.so.0
      • –link
      • libwayland-egl.so.1.22.0::/usr/lib/aarch64-linux-gnu/nvidia/libwayland-egl.so.1
      • –link
      • libwayland-egl.so.1::/usr/lib/aarch64-linux-gnu/nvidia/libwayland-egl.so
      • –link
      • libwayland-server.so.0::/usr/lib/aarch64-linux-gnu/nvidia/libwayland-server.so
      • –link
      • libwayland-server.so.0.22.0::/usr/lib/aarch64-linux-gnu/nvidia/libwayland-server.so.0
      • –link
      • ../../../lib/aarch64-linux-gnu/tegra-egl/nvidia.json::/usr/share/glvnd/egl_vendor.d/10_nvidia.json
      • –link
      • libcuda.so.1::/usr/lib/aarch64-linux-gnu/nvidia/libcuda.so
      • –link
      • libGLX_nvidia.so.0::/usr/lib/aarch64-linux-gnu/nvidia/libGLX_indirect.so.0
        hookName: createContainer
        path: /usr/bin/nvidia-cdi-hook
    • args:
      • nvidia-cdi-hook
      • update-ldcache
      • –folder
      • –folder
      • /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0
      • –folder
      • /usr/lib/aarch64-linux-gnu/tegra-egl
        mounts:
    • containerPath: /etc/nv_tegra_release
      hostPath: /etc/nv_tegra_release
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /dev/dri/by-path
      hostPath: /dev/dri/by-path
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/bin/nvidia-cuda-mps-control
      hostPath: /usr/bin/nvidia-cuda-mps-control
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/bin/nvidia-cuda-mps-server
      hostPath: /usr/bin/nvidia-cuda-mps-server
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/sbin/nvidia-smi
      hostPath: /usr/sbin/nvidia-smi
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /etc/vulkansc/icd.d/nvidia_icd_vksc.json
      hostPath: /etc/vulkansc/icd.d/nvidia_icd_vksc.json
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/ld.so.conf
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/ld.so.conf
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libGLX_nvidia.so.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libGLX_nvidia.so.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libVkLayer_json_gen.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libVkLayer_json_gen.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libVkSCLayer_khronos_validation.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libVkSCLayer_khronos_validation.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libcuda.so.1.1
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libcuda.so.1.1
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libjetsonpower.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libjetsonpower.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvargus.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvargus.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvargus_socketclient.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvargus_socketclient.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvargus_socketserver.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvargus_socketserver.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvbuf_fdmap.so.1.0.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvbuf_fdmap.so.1.0.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurface.so.1.0.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurface.so.1.0.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurftransform.so.1.0.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurftransform.so.1.0.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcam_imageencoder.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcam_imageencoder.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcameratools.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcameratools.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcamerautils.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcamerautils.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcamlog.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcamlog.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcamv4l2.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcamv4l2.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcapture.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcapture.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcolorutil.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcolorutil.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcucompat.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcucompat.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcudla.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcudla.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcuvidv4l2.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvcuvidv4l2.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvdc.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvdc.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvddk_2d_v2.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvddk_2d_v2.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvddk_vic.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvddk_vic.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvdecode2eglimage.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvdecode2eglimage.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvdla_runtime.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvdla_runtime.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvdsbufferpool.so.1.0.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvdsbufferpool.so.1.0.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnveventlib.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnveventlib.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvexif.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvexif.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfnet.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfnet.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstoredefog.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstoredefog.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstorehdfx.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstorehdfx.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfusacap.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfusacap.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfusacapinterface.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvfusacapinterface.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_boot.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_boot.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_camera.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_camera.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_force.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_force.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_generic.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_generic.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_gpucompute.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_gpucompute.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_graphics.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_graphics.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_il.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_il.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_spincircle.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_spincircle.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_tbc.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_tbc.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_ui.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvgov_ui.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvid_mapper.so.1.0.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvid_mapper.so.1.0.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-allocator.so.1
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-allocator.so.1
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-gbm.so.1.1.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-gbm.so.1.1.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-wayland.so.1.1.11
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-egl-wayland.so.1.1.11
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-eglcore.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-eglcore.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glcore.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glcore.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glsi.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glsi.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glvkspirv.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-glvkspirv.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-gpucomp.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-gpucomp.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-kms.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-kms.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-ml.so.1
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-ml.so.1
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-nvvm.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-nvvm.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-ptxjitcompiler.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-ptxjitcompiler.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-rmapi-tegra.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-rmapi-tegra.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-rtcore.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-rtcore.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-tls.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-tls.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-vksc-core.so.540.4.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvidia-vksc-core.so.540.4.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvimp.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvimp.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvisp.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvisp.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvisp_utils.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvisp_utils.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvisppg.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvisppg.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvjpeg.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvjpeg.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia2d.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia2d.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_2d.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_2d.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_dla.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_dla.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_eglstream.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_eglstream.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ide_parser.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ide_parser.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ide_sci.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ide_sci.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_iep_sci.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_iep_sci.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ijpd_sci.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ijpd_sci.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ijpe_sci.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_ijpe_sci.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_iofa_sci.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_iofa_sci.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_isp_ext.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_isp_ext.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_tensor.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_tensor.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedialdc.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmedialdc.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmm.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmm.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_contentpipe.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_contentpipe.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_parser.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_parser.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_utils.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_utils.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_image.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_image.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_utils.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_utils.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_video.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvmmlite_video.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvodm_imager.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvodm_imager.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvofsdk.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvofsdk.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvoggopus.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvoggopus.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvomx.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvomx.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvomxilclient.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvomxilclient.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvos.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvos.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvosd.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvosd.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvparser.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvparser.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvphs.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvphs.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvphsd.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvphsd.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvplayfair.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvplayfair.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvpva.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvpva.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvpva_algorithms.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvpva_algorithms.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvpvaintf.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvpvaintf.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvpvaumd.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvpvaumd.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_chip.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_chip.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_gpu.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_gpu.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_host1x.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_host1x.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_mem.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_mem.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_stream.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_stream.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_surface.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_surface.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_sync.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_sync.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscf.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscf.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscibuf.so.1
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscibuf.so.1
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscicommon.so.1
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscicommon.so.1
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscievent.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscievent.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvsciipc.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvsciipc.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscistream.so.1
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscistream.so.1
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscisync.so.1
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvscisync.so.1
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvsocsys.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvsocsys.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvtegrahv.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvtegrahv.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvtracebuf.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvtracebuf.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvtvmr.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvtvmr.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvtvmr_2d.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvtvmr_2d.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvv4l2.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvv4l2.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvv4lconvert.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvv4lconvert.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvvic.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvvic.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvvideo.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvvideo.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvvideoencode_ppe.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libnvvideoencode_ppe.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libsensors.hal-client.nvs.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libsensors.hal-client.nvs.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libsensors.l4t.no_fusion.nvs.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libsensors.l4t.no_fusion.nvs.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libsensors_hal.nvs.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libsensors_hal.nvs.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libtegrav4l2.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libtegrav4l2.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libtegrawfd.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libtegrawfd.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvargus.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvargus.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvcuvidvideocodec.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvcuvidvideocodec.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvvideocodec.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libv4l2_nvvideocodec.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libvulkansc.so.1.0.10
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libvulkansc.so.1.0.10
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libwayland-client.so.0.22.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libwayland-client.so.0.22.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libwayland-cursor.so.0.22.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libwayland-cursor.so.0.22.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libwayland-egl.so.1.22.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libwayland-egl.so.1.22.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/libwayland-server.so.0.22.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/libwayland-server.so.0.22.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/nvidia_icd.json
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/nvidia_icd.json
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf
      hostPath: /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0
      hostPath: /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv1_CM_nvidia.so.1
      hostPath: /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv1_CM_nvidia.so.1
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2
      hostPath: /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/tegra-egl/nvidia.json
      hostPath: /usr/lib/aarch64-linux-gnu/tegra-egl/nvidia.json
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/firmware/tegra19x/nvhost_nvdec040_ns.fw
      hostPath: /usr/lib/firmware/tegra19x/nvhost_nvdec040_ns.fw
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/firmware/tegra23x/nvhost_nvdec050_desc_prod.bin
      hostPath: /usr/lib/firmware/tegra23x/nvhost_nvdec050_desc_prod.bin
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/share/doc/nvidia-tegra/LICENSE.nvidia-smi
      hostPath: /usr/share/doc/nvidia-tegra/LICENSE.nvidia-smi
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/EGLWLInputEventExample
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/EGLWLInputEventExample
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/EGLWLMockNavigation
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/EGLWLMockNavigation
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/LayerManagerControl
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/LayerManagerControl
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/color-lcms.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/color-lcms.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/desktop-shell.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/desktop-shell.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/drm-backend.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/drm-backend.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/fullscreen-shell.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/fullscreen-shell.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/gl-renderer.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/gl-renderer.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/headless-backend.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/headless-backend.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/hmi-controller.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/hmi-controller.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/ivi-controller.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/ivi-controller.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/ivi-shell.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/ivi-shell.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libilmClient.so.2.3.2
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libilmClient.so.2.3.2
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libilmCommon.so.2.3.2
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libilmCommon.so.2.3.2
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libilmControl.so.2.3.2
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libilmControl.so.2.3.2
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libilmInput.so.2.3.2
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libilmInput.so.2.3.2
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libweston-13.so.0
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/libweston-13.so.0
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/simple-weston-client
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/simple-weston-client
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/spring-tool
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/spring-tool
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/wayland-backend.so
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/wayland-backend.so
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-calibrator
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-calibrator
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-clickdot
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-clickdot
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-cliptest
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-cliptest
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-content-protection
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-content-protection
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-debug
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-debug
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-desktop-shell
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-desktop-shell
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-dnd
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-dnd
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-eventdemo
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-eventdemo
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-flower
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-flower
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-fullscreen
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-fullscreen
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-image
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-image
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-ivi-shell-user-interface
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-ivi-shell-user-interface
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-keyboard
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-keyboard
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-multi-resource
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-multi-resource
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-presentation-shm
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-presentation-shm
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-resizor
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-resizor
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-scaler
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-scaler
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-screenshooter
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-screenshooter
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-damage
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-damage
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-dmabuf-egl
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-dmabuf-egl
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-dmabuf-egldevice
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-dmabuf-egldevice
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-dmabuf-feedback
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-dmabuf-feedback
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-egl
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-egl
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-im
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-im
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-shm
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-shm
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-touch
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-simple-touch
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-smoke
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-smoke
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-stacking
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-stacking
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-subsurfaces
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-subsurfaces
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-tablet
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-tablet
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-terminal
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-terminal
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-touch-calibrator
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-touch-calibrator
      options:
      • ro
      • nosuid
      • nodev
      • bind
    • containerPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-transformed
      hostPath: /usr/lib/aarch64-linux-gnu/nvidia/weston-13.0/weston-transformed
      options:
The nvidia.com/gpu=0 should be expected. We got the same output in our environment as well:
$ sudo nvidia-ctk cdi list
INFO[0000] Found 4 CDI devices
nvidia.com/gpu=0
nvidia.com/gpu=all
nvidia.com/pva=0
nvidia.com/pva=all
Have you configured it with the docker runtime?
If not, could you give it a try to see if this can solve the Exit Code: 128 error?
$ sudo nvidia-ctk cdi generate --output=/etc/cdi/nvidia.yaml
$ sudo nvidia-ctk runtime configure --runtime=docker --cdi.enabled=true
$ sudo systemctl restart docker
