I updated my kernel to 5.17.9 today and nvidia driver for my gpu gtx3080 stopped working, and i found out the issue by trying to run nvidia-smi and got the error message NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I have tried to downgrade my kernel, reinstall the driver, so far no luck. Please find the bug report attached. nvidia-bug-report.log.gz (109.9 KB)
You set your system compiler to gcc 8.2 but you need gcc 12 to build the modules for your kernel. Please switch to the correct gcc, then try reinstalling the driver.
Hello, this was indeed the issue. I changed the default gcc into 8.2 to allow matlab cuda running. Now i changed the system default back to gcc 12 it is working perfectly. Thanks very much for you help!
