NVIDIA 510 driver: Fedora 35 will not boot
This might be old news:
Kernel is 5.16.5-200.fc35.x86_64
o/s #1: Fedora 35 Workstation
o/s #2: Fedora 35 KDE Plasma
GPU: GTX 1080 Ti
System will not boot.
Rolled the driver back to 470.103.01
Problem solved:
  1. Update kernel to 5.16.6-200
koji download-build --arch=x86_64 kernel-5.16.6-200.fc35 && sudo dnf update kernel*
https://bodhi.fedoraproject.org/updates/FEDORA-2022-519c1ac29f
https://koji.fedoraproject.org/koji/buildinfo?buildID=1913374
  1. Uninstall Nvidia 470 driver:
sudo dnf remove xorg-x11-drv-nvidia\*
  1. Reboot
  2. Install Nvidia 510.47.03 driver
  3. Reboot
I am just a regular user that tried to update Fedora 35 today and I got the boot issue. I follow the steps I can boot but I still have issues to load some components . Nvidia-settings does not work and if I try to update Fedora I get this.
Problem 1: package xorg-x11-drv-nvidia-3:510.47.03-1.fc35.x86_64 requires nvidia-settings(x86-64) = 3:510.47.03, but none of the providers can be installed
  • cannot install the best update candidate for package xorg-x11-drv-nvidia-3:470.74-1.fc35.x86_64
  • package nvidia-settings-3:510.47.03-1.fc35.x86_64 is filtered out by modular filtering
    Problem 2: package xorg-x11-drv-nvidia-cuda-3:510.47.03-1.fc35.x86_64 requires nvidia-persistenced(x86-64) = 3:510.47.03, but none of the providers can be installed
  • cannot install the best update candidate for package xorg-x11-drv-nvidia-cuda-3:470.74-1.fc35.x86_64
  • package nvidia-persistenced-3:510.47.03-1.fc35.x86_64 is filtered out by modular filtering
    Problem 3: package akmod-nvidia-3:510.47.03-2.fc35.x86_64 requires nvidia-kmod-common >= 3:510.47.03, but none of the providers can be installed
  • package xorg-x11-drv-nvidia-3:510.47.03-1.fc35.x86_64 requires nvidia-settings(x86-64) = 3:510.47.03, but none of the providers can be installed
  • cannot install the best update candidate for package akmod-nvidia-3:470.74-1.fc35.x86_64
  • package nvidia-kmod-common-3:510.47.03-1.fc35.noarch is filtered out by modular filtering
    Problem 4: problem with installed package xorg-x11-drv-nvidia-cuda-3:470.74-1.fc35.x86_64
  • package xorg-x11-drv-nvidia-cuda-3:470.74-1.fc35.x86_64 requires xorg-x11-drv-nvidia-cuda-libs(x86-64) = 3:470.74-1.fc35, but none of the providers can be installed
  • cannot install both xorg-x11-drv-nvidia-cuda-libs-3:510.47.03-1.fc35.x86_64 and xorg-x11-drv-nvidia-cuda-libs-3:470.74-1.fc35.x86_64
  • package xorg-x11-drv-nvidia-cuda-3:510.47.03-1.fc35.x86_64 requires nvidia-persistenced(x86-64) = 3:510.47.03, but none of the providers can be installed
  • cannot install the best update candidate for package xorg-x11-drv-nvidia-cuda-libs-3:470.74-1.fc35.x86_64
    Problem 5: package nvidia-settings-3:470.74-1.fc35.x86_64 requires nvidia-kmod-common >= 3:470.74, but none of the providers can be installed
  • package xorg-x11-drv-nvidia-3:470.74-1.fc35.x86_64 requires libnvidia-glcore.so.470.74()(64bit), but none of the providers can be installed
  • package xorg-x11-drv-nvidia-3:470.74-1.fc35.x86_64 requires libnvidia-tls.so.470.74()(64bit), but none of the providers can be installed
  • package xorg-x11-drv-nvidia-3:470.74-1.fc35.x86_64 requires xorg-x11-drv-nvidia-libs(x86-64) = 3:470.74-1.fc35, but none of the providers can be installed
  • cannot install both xorg-x11-drv-nvidia-libs-3:510.47.03-1.fc35.x86_64 and xorg-x11-drv-nvidia-libs-3:470.74-1.fc35.x86_64
  • cannot install the best update candidate for package xorg-x11-drv-nvidia-libs-3:470.74-1.fc35.x86_64
  • cannot install the best update candidate for package nvidia-settings-3:470.74-1.fc35.x86_64
  • package nvidia-kmod-common-3:510.39.01-1.fc35.noarch is filtered out by modular filtering
    Problem 6: problem with installed package xorg-x11-drv-nvidia-3:470.74-1.fc35.x86_64
  • package xorg-x11-drv-nvidia-libs-3:470.74-1.fc35.x86_64 requires (xorg-x11-drv-nvidia-libs(x86-32) = 3:470.74-1.fc35 if mesa-libGL(x86-32)), but none of the providers can be installed
  • cannot install both xorg-x11-drv-nvidia-libs-3:510.47.03-1.fc35.i686 and xorg-x11-drv-nvidia-libs-3:470.74-1.fc35.i686
  • cannot install the best update candidate for package xorg-x11-drv-nvidia-libs-3:470.74-1.fc35.i686
  • cannot install the best update candidate for package mesa-libGL-21.3.5-1.fc35.i686
Any tips?
For now I went back to kernel 5.15 and the old drivers because some components for the 510 are not available yet like the nvidia-settings, so I will wait for now.
For the 510 driver to work, you need kernel 5.16.6-200
I did installed it, and it didn’t work.
it is missing nvidia-settings new version like I said. And if I try to update I got those errors above.
If I try to manually install it I get this:
Last metadata expiration check: 0:01:41 ago on Tue 08 Feb 2022 11:30:26 AM -03.
Error:
Problem: conflicting requests
  • package akmod-nvidia-3:510.47.03-2.fc35.x86_64 requires nvidia-kmod-common >= 3:510.47.03, but none of the providers can be installed
    (try to add ā€˜ā€“skip-broken’ to skip uninstallable packages)
Got it working installing from the nvidia repositories directly using the instructions on this site.
Thanks for the help
