NVIDIA Driver Installation skipped during bare-metal install
• Hardware (T4/V100/Xavier/Nano/etc)
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here) 4.0.1-tf2.9.1
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I want to run the AutoML experiments, for which I was installing the TAO REST API.
Current System: SSH into 10.103.48.174 server with Ubuntu 20.04.
I set up my hosts as follows:
[master]
10.103.48.174 ansible_ssh_user='username' ansible_ssh_pass='password' ansible_ssh_extra_args='-o StrictHostKeyChecking=no'
Setup my tao-toolkit-api-ansible-values.yml as follows:
ngc_api_key: amx2cDV........
ngc_email: myname@mycorp.com
api_chart: https://helm.ngc.nvidia.com/nvidia/tao/charts/tao-toolkit-api-4.0.0.tgz
api_values: ./tao-toolkit-api-helm-values.yml
cluster_name: tao-toolkit-api-demo
I have passwordless sudo access as well.
Now I run bash setup.sh check-inventory.yml and it gives no output.
Finally I run bash setup.sh install
The code runs through most TASKS but skips a lot. for example -
Considering the fact that it first uninstalls all NVIDIA drivers, now I am left with no nvidia driver on my system because this install task is somehow skipped.
Report installed versions shows none installed
And then it FAILS at
I have the following questions:
1. Is the way of specifying the IP address, and details in the host file correct?
2. Why is it skipping the driver installation process?
3. How do I fix the final error for the TASK [Validate GPU Operator Version for Cloud Native Core 6.1]
It is ok.
Can you upload the full logs?
Just to clarify, for the IP part, I am already on 10.103.48.174, inside a conda environment, and that’s the same machine I want as master, so I have entered its IP details, that’s a plausible way of doing this right?
Yes, for a single node cluster, you can list only the master node.
Please try latest notebook,
ngc registry resource download-version "nvidia/tao/tao-getting-started:4.0.2"
and also use latest tao-api.
api_chart: https://helm.ngc.nvidia.com/nvidia/tao/charts/tao-toolkit-api-4.0.2.tgz
Also, you can also get the hint from TAO AutoML - TAO Toolkit Setup - #11 by jay.duff to set the IP from the output of $ hostname -i
Sure I will try that,
Just curious - where is this v4.0.2 mentioned? I can see only v4.0.1 on the documentation pages
The notebook link is in TAO Toolkit Getting Started | NVIDIA NGC
The link can be found in TAO Toolkit Quick Start Guide - NVIDIA Docs
All computer vision samples are included in the getting started resource on NGC.
The tao-api link can be found in TAO Toolkit | NVIDIA NGC
Thankyou
Got confused because TAO Toolkit v4.0.1 (Latest Release) - NVIDIA Docs says v4.0.1 is the latest release
I’ll try this out and update here
I did follow this as well as used v4.0.2 for everything and I get stuck at the same place as that person actually.
TASK [Waiting for the Cluster to become available] takes forever to load, I’ve waited 15 minutes, tried it twice. Rebooting the system actually did push it past that place where I was stuck, but the NVIDIA drivers installation is still being skipped and 2 validations are failing fatally.
Tried with 127.0.1.1 as IP instead of the actual address of the server.
When I do nvidia-smi, it still shows not found
That is expected.
When running here, please open a new terminal and run
$ kubectl delete crd clusterpolicies.nvidia.com
So I’ll have to install nvidia drivers from scratch again? And everything else that was uninstalled?
It is not needed to install nvidia driver.
Please run $bash setup.sh install
This is the output of running bash setup.sh install. At the end of running it, there was no driver found for nvidia-smi
Can you share the output while uploading a .txt file via button ?
To get the info from nvidia-smi, please run below command.
$ kubectl get pods
then you can find the pod which is named nvidia-smi-xxxx, then,
$ kubectl exec nvidia-smi-xxxx -- nvidia-smi
This works. So to access the GPU on my server, I have to use kubectl everytime? Just nvidia-smi won’t work? Sorry, I’m not familiar with Kubernetes
To get the info from nvidia-smi, yes, please run above command.
Usually the nvidia-smi pod’s name will not be changed. So, you just need to run
I get it that this command works, but I would also like to access via just nvidia-smi
What should I do for that?
I ran $ bash setup.sh install is there anything else that needs to be done?
It will not be working now since you already install tao-api. When you are using tao-api, please use above way to get the info.
