TAO AutoML - TAO Toolkit Setup
• Hardware (T4/V100/Xavier/Nano/etc) - AMD64 based Ubuntu 20.04, TAO Toolkit Setup, (2) RTX 3080 TI, setting up TAO Toolkit - this is my server so I’m assuming “bare metal” setup. ref: Setup - NVIDIA Docs
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
haven’t gotten that far - but working towards AutoML
ref: AutoML - NVIDIA Docs
i.e. trying to get a working TAO server first
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
Not applicable - haven’t gotten that far
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
AMD64 Ubuntu 20.04 desktop w/ 2 RTX 3080 TIs
followed “bare metal” installation directions
when executing: bash setup.sh install
got a error: cat: target-os: No such file or directory
Since I know I’m Ubuntu 20.04, I changed the script:
function prepare_cnc() {
local os
os=“Ubuntu”
local os_version
os_version=“20.04”
The script appears to run okay - until new error:
TASK [Report Versions] ****************************************************************************************************************************************************************************
ok: [127.0.0.1] => {
“msg”: [
" Components Matrix Version || Installed Version ",
"GPU Operator Version v1.10.1 || ",
"Nvidia Container Driver Version 510.47.03 || ",
"GPU Operator NV Toolkit Driver v1.9.0 || ",
"K8sDevice Plugin Version v0.11.0 || ",
"Data Center GPU Manager(DCGM) Version 2.3.4-2.6.4 || ",
"Node Feature Discovery Version v0.10.1 || ",
"GPU Feature Discovery Version v0.5.0 || ",
"Nvidia validator version v1.10.1 || ",
"Nvidia MIG Manager version 0.3.0 || ",
“Note: NVIDIA Mig Manager is valid for only Amphere GPU’s like A100, A30”,
“Please validate between Matrix Version and Installed Version listed above”
TASK [Componenets Matrix Versions Vs Installed Versions] ******************************************************************************************************************************************
skipping: [127.0.0.1]
TASK [Validate the GPU Operator pods State] *******************************************************************************************************************************************************
fatal: [127.0.0.1]: FAILED! => {“changed”: true, “cmd”: “kubectl get pods --all-namespaces | egrep -v ‘kube-system|NAME’”, “delta”: “0:00:00.042849”, “end”: “2023-05-12 13:04:11.768863”, “failed_when_result”: true, “msg”: “non-zero return code”, “rc”: 1, “start”: “2023-05-12 13:04:11.726014”, “stderr”: “”, “stderr_lines”: , “stdout”: “”, “stdout_lines”: }
…ignoring
TASK [Report GPU Operator Pods] *******************************************************************************************************************************************************************
“msg”:
TASK [Validate GPU Operator Version for Cloud Native Core 6.2 and 7.0] ****************************************************************************************************************************
changed: [127.0.0.1]
TASK [Validate GPU Operator Version for Cloud Native Core 6.1] ************************************************************************************************************************************
fatal: [127.0.0.1]: FAILED! => {“changed”: true, “cmd”: “helm ls -A | grep gpu-operator | awk ‘{print $NF}’ | grep -v VERSION | sed ‘s/v//g’”, “delta”: “0:00:00.028749”, “end”: “2023-05-12 13:04:12.236032”, “failed_when_result”: true, “msg”: “”, “rc”: 0, “start”: “2023-05-12 13:04:12.207283”, “stderr”: “”, “stderr_lines”: , “stdout”: “”, “stdout_lines”: }
PLAY RECAP ****************************************************************************************************************************************************************************************
127.0.0.1 : ok=40 changed=23 unreachable=0 failed=1 skipped=19 rescued=0 ignored=1
How can I correct this GPU Operator for Cloud Native Core error?
Can you share the result of
$ kubectl get pods
Then, please run below against the pods,
$ kubectl describe pod <pod_name>
For example,
$ kubectl describe pod tao-toolkit-api-app-pod-<str>
More, please uninstall nvidia-driver and re-run.
$ sudo apt purge nvidia-driver-*
$ sudo apt autoremove
$ sudo apt autoclean
I checked my NVIDIA driver. X.Org X server being used.
I selected 525 and rebooted.
ubuntu@5950X:~/tao-getting-started_v4.0.1$ nvidia-smi
Mon May 15 14:53:46 2023
| NVIDIA-SMI 525.105.17   Driver Version: 525.105.17   CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:0B:00.0  On |                  N/A |
|  0%   30C    P8    28W / 350W |    589MiB / 12288MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  NVIDIA GeForce ...  Off  | 00000000:0C:00.0 Off |                  N/A |
|  0%   29C    P8     5W / 350W |     10MiB / 12288MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      1863      G   /usr/lib/xorg/Xorg                102MiB |
|    0   N/A  N/A      4852      G   /usr/lib/xorg/Xorg                135MiB |
|    0   N/A  N/A      5562      G   /usr/bin/gnome-shell              132MiB |
|    0   N/A  N/A      6547      G   ...404034420474974049,262144      205MiB |
|    1   N/A  N/A      1863      G   /usr/lib/xorg/Xorg                  4MiB |
|    1   N/A  N/A      4852      G   /usr/lib/xorg/Xorg                  4MiB |
I re-ran the installation, same result
note, I also ran the kubectl get pods:
TASK [Validate GPU Operator Version for Cloud Native Core 6.1] *************************************************************************************************************************************************************************************************************************************************************************
fatal: [127.0.0.1]: FAILED! => {"changed": true, "cmd": "helm ls -A | grep gpu-operator |  awk '{print $NF}' | grep -v VERSION | sed 's/v//g'", "delta": "0:00:00.027629", "end": "2023-05-15 14:58:24.533876", "failed_when_result": true, "msg": "", "rc": 0, "start": "2023-05-15 14:58:24.506247", "stderr": "", "stderr_lines": [], "stdout": "", "stdout_lines": []}
PLAY RECAP *****************************************************************************************************************************************************************************************************************************************************************************************************************************
ubuntu@5950X:~/tao-getting-started_v4.0.1/setup/quickstart_api_bare_metal$ kubectl get pods
No resources found in default namespace.
I also ran the apt purge/remove/clean
re-ran the setup.sh
same results:
fatal: [127.0.0.1]: FAILED! => {"changed": true, "cmd": "helm ls -A | grep gpu-operator |  awk '{print $NF}' | grep -v VERSION | sed 's/v//g'", "delta": "0:00:00.029867", "end": "2023-05-15 15:03:21.542528", "failed_when_result": true, "msg": "", "rc": 0, "start": "2023-05-15 15:03:21.512661", "stderr": "", "stderr_lines": [], "stdout": "", "stdout_lines": []}
ubuntu@5950X:~/tao-getting-started_v4.0.1/setup/quickstart_api_bare_metal$ nvidia-smi
bash: /usr/bin/nvidia-smi: No such file or directory
I noticed I’m back to driver: X.Org X server
Could you run below
$ sudo apt purge nvidia-driver-525
Then reboot and run again?
$ bash setup.sh install
I removed drivers per your instructions, no problem.
rebooted.
however, it looks like the install generated the same results:
TASK [Report Versions] ********************************************************************************************************************************************************************************************************
“msg”: [
TASK [Componenets Matrix Versions Vs Installed Versions] **********************************************************************************************************************************************************************
TASK [Validate the GPU Operator pods State] ***********************************************************************************************************************************************************************************
fatal: [127.0.0.1]: FAILED! => {“changed”: true, “cmd”: “kubectl get pods --all-namespaces | egrep -v ‘kube-system|NAME’”, “delta”: “0:00:00.057455”, “end”: “2023-05-18 08:33:58.809700”, “failed_when_result”: true, “msg”: “non-zero return code”, “rc”: 1, “start”: “2023-05-18 08:33:58.752245”, “stderr”: “”, “stderr_lines”: , “stdout”: “”, “stdout_lines”: }
…ignoring
TASK [Report GPU Operator Pods] ***********************************************************************************************************************************************************************************************
“msg”:
TASK [Validate GPU Operator Version for Cloud Native Core 6.2 and 7.0] ********************************************************************************************************************************************************
fatal: [127.0.0.1]: FAILED! => {“changed”: true, “cmd”: “helm ls -A | grep gpu-operator | awk ‘{print $NF}’ | grep -v VERSION | sed ‘s/v//g’”, “delta”: “0:00:00.026909”, “end”: “2023-05-18 08:33:59.245347”, “failed_when_result”: true, “msg”: “”, “rc”: 0, “start”: “2023-05-18 08:33:59.218438”, “stderr”: “”, “stderr_lines”: , “stdout”: “”, “stdout_lines”: }
Could you blacklist nouveau?
$ lsmod | grep nouveau
Open below.
sudo vim /etc/modprobe.d/blacklist.conf
In the end, add below
blacklist nouveau
Run below to take effect.
sudo update-initramfs -u
Then,
reboot
Check if the nouveau is not available now.
thanks for your continued help. I followed your instructions but I’m still loading the nouveau driver:
ubuntu@5950X:~$ lsmod | grep nouveau
ubuntu@5950X:~$ sudo nano /etc/modprobe.d/blacklist.conf
ubuntu@5950X:~/tao-getting-started_v4.0.1/setup/quickstart_api_bare_metal$ grep nouv /etc/modprobe.d/blacklist.conf
blacklist nouveau
ubuntu@5950X:~$ sudo update-initramfs -u
update-initramfs: Generating /boot/initrd.img-5.15.0-71-generic
ubuntu@5950X:~$ cd tao-getting-started_v4.0.1/setup/quickstart_api_bare_metal/
ubuntu@5950X:~/tao-getting-started_v4.0.1/setup/quickstart_api_bare_metal$ lsmod | grep nouveau
I checked Software and Updates,
Using X.Org X server - Nouveau display driver …
Could you share the latest result of $ lsmod | grep nouveau ?
I did. (it was easy to miss, it returned nothing)
the line before “I checked Software …”
I made the change,
grep to show I made the change
updated, rebooted
I am not familiar with lsmod but it looks like it didn’t do anything
Can you download 4.0.2 notebook from TAO Toolkit Getting Started | NVIDIA NGC and run again?
ngc registry resource download-version “nvidia/tao/tao-getting-started:4.0.2”
cd tao-getting-started_v4.0.2/setup/quickstart_api_bare_metal/
vim hosts
cat hosts
bash setup.sh check-inventory
Please share the result and logs. Thanks.
good progress and I think I identified my original mistake.
I installed latest version of ngc:
echo “export PATH="$PATH:$(pwd)/ngc-cli"” >> ~/.bash_profile && source ~/.bash_profile
ubuntu@5950X:~$ ngc --version
NGC CLI 3.21.1
version 4.0.2
ubuntu@5950X:~$ ngc registry resource download-version “nvidia/tao/tao-getting-started:4.0.2”
“download_end”: “2023-05-20 10:56:49.118397”,
“download_start”: “2023-05-20 10:56:47.115539”,
“download_time”: “2s”,
“files_downloaded”: 378,
“local_path”: “/home/ubuntu/tao-getting-started_v4.0.2”,
“size_downloaded”: “2.43 MB”,
“status”: “Completed”,
“transfer_id”: “tao-getting-started_v4.0.2”
edit hosts
I think this was my original problem. I have never used ansible and didn’t understand what I was doing. I am installing this on a single computer (master) with no worker nodes.
I assumed I wanted my master to be local host and used:
127.0.0.1
this time, I used 127.0.1.1 and it seems to work (- added to # to avoid format problem)
ubuntu@5950X:~/tao-getting-started_v4.0.2/setup/quickstart_api_bare_metal$ cat hosts
-# List all hosts below.
-# For single node deployment, listing the master is enough.
[master]
-# Example of host accessible using ssh private key
-# 127.0.0.1 ansible_ssh_user=‘ubuntu’ ansible_ssh_private_key_file=‘/home/ubuntu/.ssh/id_rsa’
127.0.1.1 ansible_ssh_user=‘ubuntu’ ansible_ssh_pass=mypassword ansible_ssh_extra_args=‘-o StrictHostKeyChecking=no’
[nodes]
-# Example of host accessible using ssh password
-# 1.1.1.2 ansible_ssh_user=‘ubuntu’ ansible_ssh_pass=‘some-password’ ansible_ssh_extra_args=‘-o StrictHostKeyChecking=no’
check inventory
ubuntu@5950X:~/tao-getting-started_v4.0.2/setup/quickstart_api_bare_metal$ bash setup.sh check-inventory
TASK [print host details] *************************************************************************************************************************************************************************************************************************************
ok: [127.0.1.1 → localhost] => {
“host_details”: [
“host”: “5950X”,
“os”: “Ubuntu”,
“os_version”: “20.04”
TASK [check all instances have single os] *********************************************************************************************************************************************************************************************************************
TASK [check all instances have single os version] *************************************************************************************************************************************************************************************************************
TASK [capture os] *********************************************************************************************************************************************************************************************************************************************
changed: [127.0.1.1 → localhost]
TASK [capture os version] *************************************************************************************************************************************************************************************************************************************
127.0.1.1 : ok=16 changed=3 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
127.0.1.1 : ok=70 changed=41 unreachable=0 failed=0 skipped=453 rescued=0 ignored=0
install
ubuntu@5950X:~/tao-getting-started_v4.0.2/setup/quickstart_api_bare_metal$ bash setup.sh install
Provide the path to the hosts file [./hosts]:
Provide the ngc-api-key: cHJoO–edited–4MzAx
Provide the ngc-email: jay.duff@cfacorp.com
Provide the api-chart [https://helm.ngc.nvidia.com/nvidia/tao/charts/tao-toolkit-api-4.0.2.tgz]:
Provide the api-values [./tao-toolkit-api-helm-values.yml]:
Provide the cluster-name: mycluster
Provide the value for enable_mig (no/yes) [no]:
Provide the value for mig_profile [all-disabled]:
Provide the value for mig_strategy (single/mixed) [single]:
Provide the value for nvidia_driver_version [“510.47.03”]:
skipped many lines here..
PLAY [master] *************************************************************************************************************************************************************************************************************************************************
TASK [Gathering Facts] ****************************************************************************************************************************************************************************************************************************************
ok: [127.0.1.1]
TASK [Waiting for the Cluster to become available] ************************************************************************************************************************************************************************************************************
WAITED 15 minutes, control-C
validate
similar result, waited 20 minutes for cluster
ubuntu@5950X:~/tao-getting-started_v4.0.2/setup/quickstart_api_bare_metal$ bash setup.sh validate
PLAY [all] ****************************************************************************************************************************************************************************************************************************************************
ok: [127.0.1.1]
TASK [check os] ***********************************************************************************************************************************************************************************************************************************************
ok: [127.0.1.1]
TASK [check os version] ***************************************************************************************************************************************************************************************************************************************
ok: [127.0.1.1]
TASK [check disk size sufficient] *****************************************************************************************************************************************************************************************************************************
skipping: [127.0.1.1]
TASK [check sufficient memory] ********************************************************************************************************************************************************************************************************************************
ok: [127.0.1.1]
TASK [check sufficient number of cpu cores] *******************************************************************************************************************************************************************************************************************
ok: [127.0.1.1]
TASK [check sudo privileges] **********************************************************************************************************************************************************************************************************************************
ok: [127.0.1.1]
TASK [capture gpus per node] **********************************************************************************************************************************************************************************************************************************
changed: [127.0.1.1]
TASK [check not more than 1 gpu per node] *********************************************************************************************************************************************************************************************************************
ok: [127.0.1.1]
TASK [check exactly 1 master] *********************************************************************************************************************************************************************************************************************************
TASK [capture host details] ***********************************************************************************************************************************************************************************************************************************
“host_details”: [
“host”: “5950X”,
“os”: “Ubuntu”,
127.0.1.1 : ok=15 changed=1 unreachable=0 failed=0 skipped=1 rescued=0 ignored=0
ok: [127.0.1.1]
reboot & retry
validate
TASK [Report Cuda Validation] *********************************************************************************************************************************************************************************
ok: [127.0.1.1] => {
“msg”: [
“[Vector addition of 50000 elements]”,
“Copy input data from the host memory to the CUDA device”,
“CUDA kernel launch with 196 blocks of 256 threads”,
“Copy output data from the CUDA device to the host memory”,
“Test PASSED”,
“Done”,
“pod "cuda-vector-add" deleted”
TASK [Report Network Operator version] ************************************************************************************************************************************************************************
TASK [Report Mellanox MOFED Driver Version] *******************************************************************************************************************************************************************
TASK [Report RDMA Shared Device Plugin Version] ***************************************************************************************************************************************************************
TASK [Report SRIOV Device Plugin Version] *********************************************************************************************************************************************************************
TASK [Report Container Networking Plugin Version] *************************************************************************************************************************************************************
TASK [Report Multus Version] **********************************************************************************************************************************************************************************
TASK [Report Whereabouts Version] *****************************************************************************************************************************************************************************
TASK [Status Check] *******************************************************************************************************************************************************************************************
TASK [debug] **************************************************************************************************************************************************************************************************
“msg”: “All tasks should be changed or ok, if it’s failed or ignoring means that validation task failed.”
127.0.1.1 : ok=47 changed=27 unreachable=0 failed=0 skipped=30 rescued=0 ignored=0
install (after reboot)
cluster started after a few minutes
looks like success (skipped many lines):
TASK [create kube directory] ************************************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [ensure kubeconfig file exists] ****************************************************************************************************************************************************************************************************************************************************
changed: [localhost]
TASK [merge kubeconfig to existing] *****************************************************************************************************************************************************************************************************************************************************
TASK [make merged-kubeconfig default] ***************************************************************************************************************************************************************************************************************************************************
127.0.1.1 : ok=25 changed=17 unreachable=0 failed=0 skipped=2 rescued=0 ignored=0
localhost : ok=10 changed=5 unreachable=0 failed=0 skipped=2 rescued=0 ignored=0
final steps
ubuntu@5950X:~/tao-getting-started_v4.0.2/setup/quickstart_api_bare_metal$ hostname -i
127.0.1.1
ubuntu@5950X:~/tao-getting-started_v4.0.2/setup/quickstart_api_bare_metal$ kubectl get service ingress-nginx-controller -o jsonpath=‘{.spec.ports[0].nodePort}’
32080
I think I’m good now. Thanks for you patience and help.
For someone else reading this, my main lessons were:
  • use password for ansible setup
  • use 127.0.1.1 (in a setup with just one master computer)
Glad to know it is working now. Thanks for the info!
