Nvidia GeForce GTX 560 M not recognized as an OpenCL platform with Ubuntu HWE-5.15
Before to update to Linux Mint 21, based on Ubuntu 22.04 LTS, I have tried 5.15.0-50 kernel with HWE. This was intended as a test of my hardware compatibility with the hardware stack of Ubuntu 22.04, before a possible update.
At a first glance, all seemed OK; nut I noticed that LibreOffice was unable to use OpenCL. A simple “clinfo” command confirmed this:
  $ clinfo
  Number of platforms 0
I went back from 5.15.0-50 kernel to 5.4.0-128 one. Now, “clinfo” output is:
$ clinfo
 Number of platforms 1
   Platform Name NVIDIA CUDA
   Platform Vendor NVIDIA Corporation
   Platform Version OpenCL 1.2 CUDA 9.1.84
   Platform Profile FULL_PROFILE
   Platform Extensions cl_khr_global_int32_base_atomics
 cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics
 cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd
 cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll
 cl_nv_copy_opts cl_nv_create_buffer
   Platform Extensions function suffix NV
 Number of devices 1
   Device Name GeForce GTX 560M
   Device Vendor NVIDIA Corporation
   Device Vendor ID 0x10de
   Device Version OpenCL 1.1 CUDA
   Driver Version 390.154
   Device OpenCL C Version OpenCL C 1.1
   Device Type GPU
   Device Topology (NV) PCI-E, 01:00.0
   Device Profile FULL_PROFILE
   Device Available Yes
   Compiler Available Yes
   Max compute units 4
   Max clock frequency 1550MHz
   Compute Capability (NV) 2.1
   Max work item dimensions 3
   Max work item sizes 1024x1024x64
   Max work group size 1024
   Preferred work group size multiple 32
   Warp size (NV) 32
   Preferred / native vector sizes
     char 1 / 1
     short 1 / 1
     int 1 / 1
     long 1 / 1
     half 0 / 0 (n/a)
     float 1 / 1
     double 1 / 1 (cl_khr_fp64)
   Half-precision Floating-point support (n/a)
   Single-precision Floating-point support (core)
     Denormals Yes
     Infinity and NANs Yes
     Round to nearest Yes
     Round to zero Yes
     Round to infinity Yes
     IEEE754-2008 fused multiply-add Yes
     Support is emulated in software No
     Correctly-rounded divide and sqrt operations No
   Double-precision Floating-point support (cl_khr_fp64)
     Denormals Yes
     Round to zero Yes
   Address bits 64, Little-Endian
   Global memory size 3150839808 (2.934GiB)
   Error Correction support No
   Max memory allocation 787709952 (751.2MiB)
   Unified memory for Host and Device No
   Integrated memory (NV) No
   Minimum alignment for any data type 128 bytes
   Alignment of base address 4096 bits (512 bytes)
   Global Memory cache type Read/Write
   Global Memory cache size 65536 (64KiB)
   Global Memory cache line size 128 bytes
   Image support Yes
     Max number of samplers per kernel 16
     Max 2D image size 16384x16384 pixels
     Max 3D image size 2048x2048x2048 pixels
     Max number of read image args 128
     Max number of write image args 8
   Local memory type Local
   Local memory size 49152 (48KiB)
   Registers per block (NV) 32768
   Max number of constant args 9
   Max constant buffer size 65536 (64KiB)
   Max size of kernel argument 4352 (4.25KiB)
   Queue properties
     Out-of-order execution Yes
     Profiling Yes
   Profiling timer resolution 1000ns
   Execution capabilities
     Run OpenCL kernels Yes
     Run native kernels No
     Kernel execution timeout (NV) Yes
   Concurrent copy and kernel execution (NV) Yes
    Number of async copy engines 1
   Device Extensions cl_khr_global_int32_base_atomics
 NULL platform behavior
   clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) NVIDIA CUDA
   clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [NV]
   clCreateContext(NULL, ...) [default] Success [NV]
   clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) No platform
   clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
   clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) No platform
   clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
   clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) Invalid device type for platform
   clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) No platform
 ICD loader properties
   ICD loader Name OpenCL ICD Loader
   ICD loader Vendor OCL Icd free software
   ICD loader Version 2.2.11
   ICD loader Profile OpenCL 2.1
And LibreOffice now accepts OpenCL.
Nothing else than the kernel has changed between the two “clinfo” commands.
Here is some more information on my system (“inxi” command outputs):
With 5.15.0-50 kernel:
System: Kernel: 5.15.0-50-generic arch: x86_64 bits: 64 compiler: gcc v: 9.4.0 Desktop: MATE v: 1.26.0
 wm: Metacity dm: LightDM Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Machine:
 Type: Laptop System: ASUSTeK product: G74Sx v: 1.0 serial: <superuser required>
 Mobo: ASUSTeK model: G74Sx v: 1.0 serial: <superuser required> BIOS: American Megatrends
   v: G74Sx.203 date: 09/23/2011
Battery:
 ID-1: BAT0 charge: 40.5 Wh (100.0%) condition: 40.5/72.8 Wh (55.6%) volts: 15.5 min: 14.4
   model: ASUSTek G74--52 serial: N/A status: full
CPU:
 Info: quad core model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge rev: 7
   cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
 Speed (MHz): avg: 2908 high: 3062 min/max: 800/3100 cores: 1: 2952 2: 3055 3: 2843 4: 2868
   5: 2907 6: 3062 7: 2791 8: 2793 bogomips: 35118
 Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
 Device-1: NVIDIA GF116M [GeForce GT 560M] vendor: ASUSTeK driver: nvidia v: 390.154 arch: Fermi
   pcie: speed: 5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1251
 Device-2: IMC Networks Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-1.2:4
   chip-ID: 13d3:5134
 Display: x11 server: X.Org v: 1.20.13 with: Xwayland driver: X: loaded: nvidia
   unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia display-ID: :0 screens: 1
 Screen-1: 0 s-res: 1920x1080 s-dpi: 128
 Monitor-1: LVDS-0 res: 1920x1080 dpi: 128 diag: 438mm (17.26")
 OpenGL: renderer: GeForce GTX 560M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.154 direct render: Yes
Audio:
 Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: ASUSTeK 6
   driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
 Device-2: NVIDIA GF116 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
   pcie: speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0bee
 Sound API: ALSA v: k5.15.0-48-generic running: yes
 Sound Server-1: PulseAudio v: 13.99.1 running: yes
Network:
 Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: AzureWave AW-NB037H 802.11bgn
   driver: ath9k v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:002b
 IF: wlp3s0 state: up mac: <filter>
 Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK U6V/U31J
   laptop driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 9000 bus-ID: 05:00.0
   chip-ID: 10ec:8168
 IF: enp5s0 state: down mac: <filter>
 IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
 IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth:
 Device-1: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-1.1:6
   chip-ID: 0cf3:3005
 Report: hciconfig ID: hci0 rfk-id: 3 state: down bt-service: N/A rfk-block: hardware: no
   software: yes address: <filter>
Drives:
 Local Storage: total: 931.51 GiB used: 281.61 GiB (30.2%)
 ID-1: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB speed: 6.0 Gb/s
   serial: <filter>
Partition:
 ID-1: / size: 139.75 GiB used: 14.81 GiB (10.6%) fs: ext4 dev: /dev/sda1
 ID-2: /home size: 744.98 GiB used: 266.8 GiB (35.8%) fs: ext4 dev: /dev/sda2
Swap:
 ID-1: swap-1 type: partition size: 30.52 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
USB:
 Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
 Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
   chip-ID: 8087:0024
 Device-1: 1-1.1:6 info: Qualcomm Atheros AR3011 Bluetooth type: Bluetooth driver: btusb
   rev: 1.1 speed: 12 Mb/s chip-ID: 0cf3:3005
 Device-2: 1-1.2:4 info: IMC Networks Integrated Webcam type: Video driver: uvcvideo rev: 2.0
   speed: 480 Mb/s chip-ID: 13d3:5134
 Device-3: 1-1.4:5 info: Realtek RTS5139 Card Reader Controller type: <vendor specific>
   driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc rev: 2.0 speed: 480 Mb/s chip-ID: 0bda:0139
 Hub-3: 2-0:1 info: Full speed or root hub ports: 8 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
 Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
   chip-ID: 8087:0024
 Device-1: 2-1.2:3 info: Trust type: Mouse driver: hid-generic,usbhid rev: 1.1 speed: 1.5 Mb/s
   chip-ID: 145f:01d9
 Hub-5: 2-1.3:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 05e3:0608
 Device-1: 2-1.3.3:5 info: Wacom CTL-470 [Bamboo Connect] type: Mouse,HID driver: usbhid,wacom
   rev: 2.0 speed: 12 Mb/s chip-ID: 056a:00dd
 Device-2: 2-1.3.4:6 info: Microsoft Digital Media Keyboard 3000 type: Keyboard,HID
   driver: microsoft,usbhid rev: 2.0 speed: 1.5 Mb/s chip-ID: 045e:0730
 Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s
   chip-ID: 1d6b:0002
 Hub-7: 4-0:1 info: Super-speed hub ports: 1 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003
Sensors:
 System Temperatures: cpu: 70.0 C mobo: N/A gpu: nvidia temp: 61 C
 Fan Speeds (RPM): cpu: 2900
Repos:
 Packages: 2273 pm: dpkg pkgs: 2238 pm: flatpak pkgs: 35
 No active apt repos in: /etc/apt/sources.list
 Active apt repos in: /etc/apt/sources.list.d/flatpak-stable-focal.list
   1: deb http: //ppa.launchpad.net/flatpak/stable/ubuntu focal main
 Active apt repos in: /etc/apt/sources.list.d/graphics-drivers-ppa-focal.list
   1: deb http: //ppa.launchpad.net/graphics-drivers/ppa/ubuntu focal main
 Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
   1: deb http: //packages.linuxmint.com una main upstream import backport
   2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
   3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
   4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
   5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
   6: deb http: //archive.canonical.com/ubuntu/ focal partner
 Active apt repos in: /etc/apt/sources.list.d/tor.list
   1: deb https: //deb.torproject.org/torproject.org/ focal main
Info:
 Processes: 284 Uptime: 30m Memory: 15.6 GiB used: 1.92 GiB (12.3%) Init: systemd v: 245
 target: graphical (5) default: graphical Compilers: gcc: 9.4.0 alt: 9 Client: Unknown python3.8
 client inxi: 3.3.22
With 5.4.0-128 kernel:
System:
  Kernel: 5.4.0-128-generic arch: x86_64 bits: 64 compiler: gcc v: 9.4.0 Desktop: MATE v: 1.26.0
Machine:
Battery:
  ID-1: BAT0 charge: 40.5 Wh (100.0%) condition: 40.5/72.8 Wh (55.6%) volts: 15.3 min: 14.4
CPU:
  Speed (MHz): avg: 2917 high: 3028 min/max: 800/3100 cores: 1: 2992 2: 2908 3: 3028 4: 2793
    5: 2915 6: 2794 7: 2998 8: 2911 bogomips: 35122
Graphics:
    chip-ID: 13d3:5134
Audio:
  Sound API: ALSA v: k5.4.0-128-generic running: yes
Network:
    chip-ID: 10ec:8168
Bluetooth:
    chip-ID: 0cf3:3005
Drives:
  Local Storage: total: 931.51 GiB used: 280.63 GiB (30.1%)
    serial: <filter>
Partition:
  ID-1: / size: 139.75 GiB used: 13.33 GiB (9.5%) fs: ext4 dev: /dev/sda1
  ID-2: /home size: 744.98 GiB used: 267.29 GiB (35.9%) fs: ext4 dev: /dev/sda2
Swap:
USB:
    chip-ID: 8087:0024
    chip-ID: 8087:0024
    chip-ID: 145f:01d9
    chip-ID: 1d6b:0002
Sensors:
  System Temperatures: cpu: 59.0 C mobo: N/A gpu: nvidia temp: 50 C
  Fan Speeds (RPM): cpu: 2700
Repos:
  Packages: 2231 pm: dpkg pkgs: 2195 pm: flatpak pkgs: 36
Info:
  Processes: 303 Uptime: 4m Memory: 15.61 GiB used: 2.01 GiB (12.9%) Init: systemd v: 245
  client inxi: 3.3.22
In both cases, installed graphics driver is “nvidia-driver-390”, 390.154-0ubuntu0.20.04.1.
NB: test done again with 5.15.0-56 kernel and 390.157 drivers with the same result:
 $ clinfo
while it still works with 5.4.0-135 kernel and 390.157 drivers.
Regards,
MN
Fermi based gpu, only supported up to cuda 8.
I am not sure of what you says, since GTX 560 M works with Cuda 9.1.84 and kernel 5.4:
“Platform Version OpenCL 1.2 CUDA 9.1.84”
(read the second clinfo output)
And system change was limited to kernel, nothing related to Nvidia installation had changed (system stayed on a basis of Ubuntu 20.04 LTS; with kernel 5.15 it became equivalent to Ubuntu 20.04 LTS HWE, with hardware enhancement and the same hardware stack as Ubuntu 22.04 LTS).
Regards,
MN
F=Fermi=Cuda 8.
It won’t work with cuda 9.
The clinfo output with 5.4 kernel shows it DOES work with Cuda 9.
MN
Sorry, I misread.
To make things clear:
Fermi does not work with cuda 9, but of course OpenCL will still work on the cuda 9 capable 390 driver.
Please check if the driver works and vidia-uvm is loaded.
Thanks for your answer; how can I check nvidia-uvm is loaded? While I am running 5.4 kernel and OpenCL works, I have no process and no service with the name “nvidia-uvm”. (I have two processes with nvidia, “nvidia” and "nvidia-modeset).
Moreover, if nvidia-uvm is not automatically loaded (in my 5.15 kernel configuration), how can I manually load it?
The graphics driver 390.157 works with both kernels, including accelerated graphics OpenGL.
Regards,
MN
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
Here is the log.
nvidia-bug-report.log.gz (121.1 KB)
I have noted that there is no nvidia-uvm in my dev directory.
I have tried to correct this with the following bash, from “Cuda Installation Guide for Linux”:
#!/bin/bash
/sbin/modprobe nvidia
if [ "$?" -eq 0 ]; then
  # Count the number of NVIDIA controllers found.
  NVDEVS=`lspci | grep -i NVIDIA`
  N3D=`echo "$NVDEVS" | grep "3D controller" | wc -l`
  NVGA=`echo "$NVDEVS" | grep "VGA compatible controller" | wc -l`
  N=`expr $N3D + $NVGA - 1`
  for i in `seq 0 $N`; do
    mknod -m 666 /dev/nvidia$i c 195 $i
  done
  mknod -m 666 /dev/nvidiactl c 195 255
else
  exit 1
fi
/sbin/modprobe nvidia-uvm
  # Find out the major device number used by the nvidia-uvm driver
  D=`grep nvidia-uvm /proc/devices | awk '{print $1}'`
  mknod -m 666 /dev/nvidia-uvm c $D 0
else
  exit 1
fi
However, I get the following error when I launch the bash, even with sudo:
modprobe: FATAL: Module nvidia-uvm not found in directory /lib/modules/5.15.0-56-generic
So, it seems something is missing.
My question now: how to get the missing module ?
Regards,
MN
That’s odd, according to the logs, the nvidia-uvm module was built and installed for both the 5.4 and 5.15 kernel.
Don’t know if a copy of it is still in /var/lib/dkms/nvidia/390.157/build/
BTW, you should rather remove “nomsi” from kernel cmdline.
Maybe just run
sudo depmod -a
to recreate the module database.
  • In GRUB, “pci=nomsi,noaer” is here because of USB 3.0 hardware (Fresco Logic FL1000G USB 3.0 Host Controller).
  • I have an “nvidia-uvm.ko” in “/var/lib/dkms/nvidia/390.157/5.4.0-135-generic/x86_64/module”. Can I copy it somewhere to solve the problem?
  • “sudo depmod -a” didn’t solve the problem, reinstallation of “nvidia-driver-390” neither.
    Regards,
    MN
I finally solved the problem that way:
sudo apt install linux-modules-nvidia-390-5.15.0-56-generic
where: “390” is the number of my Nvidia driver, and “5.15.0-56-generic” is the name of my kernel (output of “uname -r”).
This induced the installation of the following packages: “linux-modules-nvidia-390-5.15.0-56-generic”, “linux-objects-nvidia-390-5.15.0-56-generic”, “linux-signatures-nvidia-390-5.15.0-56-generic”.
And now, my clinfo with 5.15.0-56 kernel:
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
Number of devices                                 1
  Driver Version                                  390.157
  Device Type                                     GPU
  Max compute units                               4
  Warp size (NV)                                  32
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    Denormals                                     Yes
    Round to zero                                 Yes
    Denormals                                     Yes
    Round to zero                                 Yes
  Image support                                   Yes
  Queue properties
    Profiling                                     Yes
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
Regards,
MN
