Secure boot is disabled (Other OS selected) In system info it see my Nvidia GPU, but cant see cli programs. Also i installed with opencl-icd command which i found in this forum.
I dont know where it is. Is it might be the problem before installing nvidia i removed by purge nvidia, and in clinfo i cant see the cuda. In forum i realize someone solved the issue with installing cuda. Also cuda installition installing some dependencies too. Which i autoremove after removing cuda.
I might did a few changes in /etc/OpenCL/vendors
And when i type nvidia-settings its giving me the error of cant opening directory and in X11 making another conf file
ii firmware-nvidia-gsp 525.125.06-1~deb12u1 amd64 NVIDIA GSP firmware
ii glx-alternative-nvidia 1.2.2 amd64 allows the selection of NVIDIA as GLX provider
ii libegl-nvidia0:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary EGL library
ii libgl1-nvidia-glvnd-glx:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL/GLX library (GLVND variant)
ii libgles-nvidia1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL|ES 1.x library
ii libgles-nvidia2:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL|ES 2.x library
ii libglx-nvidia0:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary GLX library
ii libnvidia-allocator1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA allocator runtime library
ii libnvidia-cfg1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-compiler:amd64 525.125.06-1~deb12u1 amd64 NVIDIA runtime compiler library
ii libnvidia-egl-gbm1:amd64 1.1.0-2 amd64 GBM EGL external platform library for NVIDIA
ii libnvidia-egl-wayland1:amd64 1:1.1.10-1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-eglcore:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary EGL core libraries
ii libnvidia-encode1:amd64 525.125.06-1~deb12u1 amd64 NVENC Video Encoding runtime library
ii libnvidia-glcore:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL/GLX core libraries
ii libnvidia-glvkspirv:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary Vulkan Spir-V compiler library
ii libnvidia-ml-dev:amd64 11.8.86~11.8.0-5~deb12u1 amd64 NVIDIA Management Library (NVML) development files
ii libnvidia-ml1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA Management Library (NVML) runtime library
ii libnvidia-nvvm4:amd64 525.125.06-1~deb12u1 amd64 NVIDIA NVVM Compiler library
ii libnvidia-ptxjitcompiler1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA PTX JIT Compiler library
ii libnvidia-rtcore:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary Vulkan ray tracing (rtcore) library
ii nvidia-alternative 525.125.06-1~deb12u1 amd64 allows the selection of NVIDIA as GLX provider
ii nvidia-cuda-dev:amd64 11.8.89~11.8.0-5~deb12u1 amd64 NVIDIA CUDA development files
ii nvidia-cuda-gdb 11.8.86~11.8.0-5~deb12u1 amd64 NVIDIA CUDA Debugger (GDB)
ii nvidia-cuda-toolkit 11.8.89~11.8.0-5~deb12u1 amd64 NVIDIA CUDA development toolkit
ii nvidia-cuda-toolkit-doc 11.8.0-5~deb12u1 all NVIDIA CUDA and OpenCL documentation
ii nvidia-detect 525.125.06-1~deb12u1 amd64 NVIDIA GPU detection utility
ii nvidia-driver 525.125.06-1~deb12u1 amd64 NVIDIA metapackage
ii nvidia-driver-bin 525.125.06-1~deb12u1 amd64 NVIDIA driver support binaries
ii nvidia-driver-libs:amd64 525.125.06-1~deb12u1 amd64 NVIDIA metapackage (OpenGL/GLX/EGL/GLES libraries)
ii nvidia-egl-common 525.125.06-1~deb12u1 amd64 NVIDIA binary EGL driver - common files
ii nvidia-egl-icd:amd64 525.125.06-1~deb12u1 amd64 NVIDIA EGL installable client driver (ICD)
ii nvidia-installer-cleanup 20220217+3~deb12u1 amd64 cleanup after driver installation with the nvidia-installer
ii nvidia-kernel-common 20220217+3~deb12u1 amd64 NVIDIA binary kernel module support files
ii nvidia-kernel-dkms 525.125.06-1~deb12u1 amd64 NVIDIA binary kernel module DKMS source
ii nvidia-kernel-support 525.125.06-1~deb12u1 amd64 NVIDIA binary kernel module support files
ii nvidia-legacy-check 525.125.06-1~deb12u1 amd64 check for NVIDIA GPUs requiring a legacy driver
ii nvidia-modprobe 535.54.03-1~deb12u1 amd64 utility to load NVIDIA kernel modules and create device nodes
ii nvidia-opencl-common 525.125.06-1~deb12u1 amd64 NVIDIA OpenCL driver - common files
ii nvidia-opencl-dev:amd64 11.8.89~11.8.0-5~deb12u1 amd64 NVIDIA OpenCL development files
ii nvidia-opencl-icd:amd64 525.125.06-1~deb12u1 amd64 NVIDIA OpenCL installable client driver (ICD)
ii nvidia-openjdk-8-jre 9.+8u372-ga-1~11.8.0-5~deb12u1 amd64 Obsolete OpenJDK Java runtime, for NVIDIA applications
ii nvidia-persistenced 525.85.05-1 amd64 daemon to maintain persistent software state in the NVIDIA driver
ii nvidia-profiler 11.8.87~11.8.0-5~deb12u1 amd64 NVIDIA Profiler for CUDA and OpenCL
ii nvidia-settings 525.125.06-1~deb12u1 amd64 tool for configuring the NVIDIA graphics driver
ii nvidia-smi 525.125.06-1~deb12u1 amd64 NVIDIA System Management Interface
ii nvidia-support 20220217+3~deb12u1 amd64 NVIDIA binary graphics driver support files
ii nvidia-vdpau-driver:amd64 525.125.06-1~deb12u1 amd64 Video Decode and Presentation API for Unix - NVIDIA driver
ii nvidia-visual-profiler 11.8.87~11.8.0-5~deb12u1 amd64 NVIDIA Visual Profiler for CUDA and OpenCL
ii nvidia-vulkan-common 525.125.06-1~deb12u1 amd64 NVIDIA Vulkan driver - common files
ii nvidia-vulkan-icd:amd64 525.125.06-1~deb12u1 amd64 NVIDIA Vulkan installable client driver (ICD)
ii nvidia-xconfig 525.85.05-1 amd64 deprecated X configuration tool for non-free NVIDIA drivers
ii xserver-xorg-video-nvidia 525.125.06-1~deb12u1 amd64 NVIDIA binary Xorg driver
Yes it is exist and this is the output when i cat > libnvidia-opencl.so.1
But also in /etc/OpenCL/vendors there was another file pocl.icd
That was what i mentioned before. I changed its name and made a backupICD file and put it in there. Nvidia should be the main/applied one in the vendors right ?
But also i guess some nvidia configuration files in /etc/X11/xorg.conf directory. When i launch nvidia-xconfig its giving me some errors about cant write the file, and rewriting again. And maybe its all about like i said in first installition i purge removed nvidia, then i reinstalled the cuda.
If it will be just fine and fresh installition, i can do it. Pls just type down the correct commands to delete/remove them all with no doubt and safely. And install with the pure correction.
You should rather remove the file or uninstall the package it belongs to and not rename it in its directory.
Anything in /etc/xorg.conf is only writeable by root so the error you’re getting from nvidia-settings when run as user is expected. Furthermore, you shouldn’t mess around with that anyway, it also has zero influence on OpenCL.
I saw it in a forum before there, that was a solution for him. Like you said, i deleted the file. It was cuda’s i didnt install about it
I run sudo nvidia-xconf and it write the file but not in the /etc/xorg.conf it created /etc/X11/
And there is xorg.conf & xorg.conf.backup (nvidia-xconf created them) & xorg.conf.nvidia-xconfig-original
And also there is xorg.conf.d directory and inside there is another xorg.conf file. Maybe something is crossing.
Now im really close to the solution. My nvcc version and nvidia version is not match. Yes, that common issue. But i didnt solve it. How can i solve it ?
