Hi, first of all I was trying to connect my pc to a second screen, I saw that to do this I have to use Xorg, then next semester I have to use tensorflow for some projects.
The problems concern the installation of nvidia within my operating system
uname -a
Linux parrot 6.5.0-3parrot1-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.5.3-3parrot1 (2023-10-20) x86_64 GNU/Linux
These problems did not persist in the previous installation.
In fact I have nvidia-settings already installed but it has some problems…
In addition I post some additional information
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
┌─[✗]─[giorgiosld@parrot]─[~]
└──╼ $dpkg -l | grep nvidia
ii firmware-nvidia-gsp 525.125.06-1~deb12u1 amd64 NVIDIA GSP firmware
ii glx-alternative-nvidia 1.2.2 amd64 allows the selection of NVIDIA as GLX provider
ii libegl-nvidia0:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary EGL library
ii libgl1-nvidia-glvnd-glx:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL/GLX library (GLVND variant)
ii libgles-nvidia1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL|ES 1.x library
ii libgles-nvidia2:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL|ES 2.x library
ii libglx-nvidia0:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary GLX library
ii libnvidia-allocator1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA allocator runtime library
ii libnvidia-cfg1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-compiler:amd64 525.125.06-1~deb12u1 amd64 NVIDIA runtime compiler library
ii libnvidia-egl-wayland1:amd64 1:1.1.10-1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-eglcore:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary EGL core libraries
ii libnvidia-glcore:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary OpenGL/GLX core libraries
ii libnvidia-glvkspirv:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary Vulkan Spir-V compiler library
ii libnvidia-ml1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA Management Library (NVML) runtime library
ii libnvidia-nvvm4:amd64 525.125.06-1~deb12u1 amd64 NVIDIA NVVM Compiler library
ii libnvidia-ptxjitcompiler1:amd64 525.125.06-1~deb12u1 amd64 NVIDIA PTX JIT Compiler library
ii libnvidia-rtcore:amd64 525.125.06-1~deb12u1 amd64 NVIDIA binary Vulkan ray tracing (rtcore) library
ii mate-sensors-applet-nvidia 1.26.0-1 amd64 Display readings from hardware sensors in your MATE panel (NVIDIA sensors)
ii nvidia-alternative 525.125.06-1~deb12u1 amd64 allows the selection of NVIDIA as GLX provider
ii nvidia-cuda-gdb 12.0.140~12.0.1-3parrot1 amd64 NVIDIA CUDA Debugger (GDB)
ii nvidia-cuda-toolkit-doc 12.0.1-3parrot1 all NVIDIA CUDA and OpenCL documentation
ii nvidia-detect 525.125.06-1~deb12u1 amd64 NVIDIA GPU detection utility
iU nvidia-driver 525.125.06-1~deb12u1 amd64 NVIDIA metapackage
ii nvidia-driver-bin 525.125.06-1~deb12u1 amd64 NVIDIA driver support binaries
ii nvidia-driver-libs:amd64 525.125.06-1~deb12u1 amd64 NVIDIA metapackage (OpenGL/GLX/EGL/GLES libraries)
ii nvidia-egl-common 525.125.06-1~deb12u1 amd64 NVIDIA binary EGL driver - common files
ii nvidia-egl-icd:amd64 525.125.06-1~deb12u1 amd64 NVIDIA EGL installable client driver (ICD)
ii nvidia-installer-cleanup 20220217+3~deb12u1 amd64 cleanup after driver installation with the nvidia-installer
ii nvidia-kernel-common 20220217+3~deb12u1 amd64 NVIDIA binary kernel module support files
iF nvidia-kernel-dkms 525.125.06-1~deb12u1 amd64 NVIDIA binary kernel module DKMS source
ii nvidia-kernel-support 525.125.06-1~deb12u1 amd64 NVIDIA binary kernel module support files
ii nvidia-legacy-check 525.125.06-1~deb12u1 amd64 check for NVIDIA GPUs requiring a legacy driver
ii nvidia-modprobe 535.54.03-1~deb12u1 amd64 utility to load NVIDIA kernel modules and create device nodes
ii nvidia-opencl-common 525.125.06-1~deb12u1 amd64 NVIDIA OpenCL driver - common files
ii nvidia-persistenced 525.85.05-1 amd64 daemon to maintain persistent software state in the NVIDIA driver
ii nvidia-primus-vk-common 1.6.2-2 amd64 thin wrapper for the NVIDIA binary Vulkan ICD (common files)
ii nvidia-primus-vk-wrapper:amd64 1.6.2-2 amd64 thin wrapper for using the NVIDIA binary Vulkan ICD with bumblebee
ii nvidia-settings 525.125.06-1~deb12u1 amd64 tool for configuring the NVIDIA graphics driver
ii nvidia-smi 525.125.06-1~deb12u1 amd64 NVIDIA System Management Interface
ii nvidia-support 20220217+3~deb12u1 amd64 NVIDIA binary graphics driver support files
ii nvidia-vdpau-driver:amd64 525.125.06-1~deb12u1 amd64 Video Decode and Presentation API for Unix - NVIDIA driver
ii nvidia-vulkan-common 525.125.06-1~deb12u1 amd64 NVIDIA Vulkan driver - common files
ii nvidia-vulkan-icd:amd64 525.125.06-1~deb12u1 amd64 NVIDIA Vulkan installable client driver (ICD)
ii xserver-xorg-video-nvidia 525.125.06-1~deb12u1 amd64 NVIDIA binary Xorg driver
┌─[giorgiosld@parrot]─[~]
└──╼ $lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
neofetch
`:oho/-`
`mMMMMMMMMMMMNmmdhy- giorgiosld@parrot
dMMMMMMMMMMMMMMMMMMs` -----------------
+MMsohNMMMMMMMMMMMMMm/ OS: Parrot Security 6.0 (lorikeet) x86_64
.My .+dMMMMMMMMMMMMMh. Host: Nitro AN515-54 V1.01
+ :NMMMMMMMMMMMMNo Kernel: 6.5.0-3parrot1-amd64
`yMMMMMMMMMMMMMm: Uptime: 11 hours, 35 mins
/NMMMMMMMMMMMMMy` Packages: 2390 (dpkg)
.hMMMMMMMMMMMMMN+ Shell: bash 5.2.15
``-NMMMMMMMMMd- Resolution: 1920x1080
/MMMMMMMMMMMs` DE: MATE 1.26.0
mMMMMMMMsyNMN/ WM: Metacity (Marco)
+MMMMMMMo :sNh. Theme: ARK-Dark [GTK2/3]
`NMMMMMMm -o/ Icons: ara [GTK2/3]
oMMMMMMM. Terminal: mate-terminal
`NMMMMMM+ Terminal Font: Monospace 13
+MMd/NMh CPU: Intel i7-9750H (12) @ 4.500GHz
mMm -mN` GPU: Intel CoffeeLake-H GT2 [UHD Graphics 630]
/MM `h: GPU: NVIDIA GeForce GTX 1650 Mobile / Max-Q
dM` . Memory: 4030MiB / 15836MiB
:M-
d:
As mentioned above, my main goal is to connect a second monitor to the PC, and then in a few months I need to use tensorflow for a university project.
The command I use to download nvidia drivers is as follows
sudo apt install -t lory-backports bumblebee-nvidia primus-nvidia primus-vk-nvidia nvidia-smi nvidia-cuda-dev nvidia-cuda-toolkit
[sudo] password for giorgiosld:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
nvidia-smi is already the newest version (525.125.06-1~deb12u1).
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nvidia-cuda-dev : Depends: libcu++-dev (>= 1.9.0~) but 1.8.1-2 is to be installed
Depends: libcub-dev (>= 2.0.1~) but 1.17.2-2 is to be installed
Depends: libthrust-dev (>= 2.0.1~) but 1.17.2-2 is to be installed
Recommends: libnvcuvid1 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
which is taken from the following guide https://parrotlinux.org/docs/configuration/nvidia-drivers.
Again as mentioned before I had previously followed this guide to install the nvidia driver suite and everything worked including the hdmi connection to the second monitor, then due to a operating system update it no longer worked.
I hope I have provided all the necessary information and that someone can help me. Thank you in advance!
