Unable to access nvidia-settings or nvidia-smi driver card
Hi I have exhaustively tried to set nvidia graphic card to my ubuntu 18.04.
The output of my bug-log is below:
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 27573540
Date: So 7. Feb 02:10:27 CET 2021
uname: Linux autowareros2-Aspire-VX5-591G 5.4.0-65-generic #73~18.04.1-Ubuntu SMP Tue Jan 19 09:02:24 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
There is also another one attempt to reinstall driver, cuda, remove xorg.conf file …select-prime nvidia etc…I tried all solutions I have seen however for some reason does not work:
nvidia-bug-report.sh Version: 29404094
Date: So 7. Feb 03:37:01 CET 2021
command line flags:
output of my command lines:
$ nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
$ nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
$ cat /usr/local/cuda/version.txt
CUDA Version 10.2.89
$ dpkg -l | grep -i nvidia
ii cuda-nsight-compute-10-2 10.2.89-1 amd64 NVIDIA Nsight Compute
ii cuda-nsight-systems-10-2 10.2.89-1 amd64 NVIDIA Nsight Systems
ii cuda-nvtx-10-2 10.2.89-1 amd64 NVIDIA Tools Extension
ii libaccinj64-9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA ACCINJ Library (64-bit)
ii libcudart9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA CUDA Runtime Library
ii libcufft9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA cuFFT Library
ii libcufftw9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA cuFFTW Library
ii libcurand9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA cuRAND Library
ii libcusolver9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA cuSOLVER Library
ii libcusparse9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA cuSPARSE Library
ii libnppc9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives core runtime library
ii libnppial9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Arithmetic and Logic
ii libnppicc9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Color Conversion
ii libnppicom9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Compression
ii libnppidei9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Data Exchange and Initialization
ii libnppif9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Filters
ii libnppig9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Geometry transforms
ii libnppim9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Morphological operations
ii libnppist9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Statistics
ii libnppisu9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Support
ii libnppitc9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives lib for Image Threshold and Compare
ii libnpps9.1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Performance Primitives for signal processing runtime library
ii libnvidia-cfg1-440:amd64 440.33.01-0ubuntu1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-440 440.33.01-0ubuntu1 all Shared files used by the NVIDIA libraries
ii libnvidia-common-450 450.102.04-0ubuntu0.18.04.1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-390:amd64 390.141-0ubuntu0.18.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-390:i386 390.141-0ubuntu0.18.04.1 i386 NVIDIA libcompute package
rc libnvidia-compute-410:amd64 410.104-0ubuntu0~18.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-415:amd64 415.27-0ubuntu0~gpu18.04.2 amd64 NVIDIA libcompute package
rc libnvidia-compute-418-server:amd64 418.181.07-0ubuntu0.18.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-435:amd64 435.21-0ubuntu0.18.04.3 amd64 NVIDIA libcompute package
ii libnvidia-compute-440:amd64 440.33.01-0ubuntu1 amd64 NVIDIA libcompute package
rc libnvidia-compute-450:amd64 450.102.04-0ubuntu0.18.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-450-server:amd64 450.102.04-0ubuntu0.18.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-460:amd64 460.39-0ubuntu0.18.04.1 amd64 NVIDIA libcompute package
ii libnvidia-decode-440:amd64 440.33.01-0ubuntu1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-440:amd64 440.33.01-0ubuntu1 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-450:amd64 450.102.04-0ubuntu0.18.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-440:amd64 440.33.01-0ubuntu1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-440:amd64 440.33.01-0ubuntu1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-440:amd64 440.33.01-0ubuntu1 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvrtc9.1:amd64 9.1.85-3ubuntu1 amd64 CUDA Runtime Compilation (NVIDIA NVRTC Library)
ii libnvtoolsext1:amd64 9.1.85-3ubuntu1 amd64 NVIDIA Tools Extension Library
ii libnvvm3:amd64 9.1.85-3ubuntu1 amd64 NVIDIA NVVM Library
ii nsight-compute-2019.5.0 2019.5.0.14-1 amd64 NVIDIA Nsight Compute
ii nsight-systems-2019.5.2 2019.5.2.16-b54ef97 amd64 NVIDIA Nsight Systems is a statistical sampling profiler with tracing features.
ii nvidia-compute-utils-440 440.33.01-0ubuntu1 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-450 450.102.04-0ubuntu0.18.04.1 amd64 NVIDIA compute utilities
ii nvidia-dkms-440 440.33.01-0ubuntu1 amd64 NVIDIA DKMS package
rc nvidia-dkms-450 450.102.04-0ubuntu0.18.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-440 440.33.01-0ubuntu1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-440 440.33.01-0ubuntu1 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-450 450.102.04-0ubuntu0.18.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-440 440.33.01-0ubuntu1 amd64 NVIDIA kernel source package
ii nvidia-modprobe 440.33.01-0ubuntu1 amd64 Load the NVIDIA kernel driver and create device files
ii nvidia-prime 0.8.8 all Tools to enable NVIDIA’s Prime
ii nvidia-settings 440.33.01-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-440 440.33.01-0ubuntu1 amd64 NVIDIA driver support binaries
ii xserver-xorg-video-nvidia-440 440.33.01-0ubuntu1 amd64 NVIDIA binary Xorg driver
$ lspci -nnk | grep ‘[03’
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:591b] (rev 04)
01:00.0 3D controller [0302]: NVIDIA Corporation GP107M [GeForce GTX 1050 Ti Mobile] [10de:1c8c] (rev a1)
Well It seems that Nvidia is working along with Intel graphic card. However I do not understand why I cannot access nvidia-settings?
Can you help me please?
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
Thanks I have started from scratch and now the simulator is working
