What’s the best way to run this model across two sparks:
we would like to use expert-parallelisim
Is there an optimized flash-infer path for vLLM? How do we incorporate the latest MoE fixes for nvFP4 from nvidia? Thanks!
Such a small model is not going to make sense to split over two Sparks. The overhead of communication will be a lot.
it should be fine with expert parallelism. gpt-oss-120b does really well with 2 sparks, it’s at the top of the leaderboard.
Tensor-parallel will give better performance gains than expert parallel in a Spark cluster…
taking something that runs perfectly fine on a single node does not always give you the return on splitting it across 2 nodes, especially when that single node already excels at running in parallel.
the only way I could see this maybe working better is if you shard the experts across the nodes? But even then the work to do it vs the returns, questionable IMO
We’d prefer to test. As mentioned above, gpt-oss-120b works well on 2 sparks…
Is there an optimized docker image that we can just pull with the latest fixes for flashinfer?
We’d like to test this: https://github.com/vllm-project/vllm/pull/40082#issuecomment-4349406309
cc: @eugr
b12x backend doesn’t support all models yet, definitely not Gemma (it’s not even supported by standard Flashinfer backend, but works with vLLM CUTLASS):
./launch-cluster.sh -t vllm-node-tf5 --solo \
exec vllm serve nvidia/Gemma-4-26B-A4B-NVFP4 \
--tool-call-parser gemma4 \
--reasoning-parser gemma4 \
--enable-auto-tool-choice \
--trust-remote-code \
--port 8888 \
--load-format fastsafetensors \
--gpu-memory-utilization 0.85 \
--max-num-batched-tokens 32768 \
--enable-prefix-caching
| model | test | t/s | peak t/s | ttfr (ms) | est_ppt (ms) | e2e_ttft (ms) |
| nvidia/Gemma-4-26B-A4B-NVFP4 | pp2048 | 2723.35 ± 649.96 | 814.11 ± 221.92 | 805.02 ± 221.92 | 814.11 ± 221.92 | |
| nvidia/Gemma-4-26B-A4B-NVFP4 | tg32 | 29.40 ± 0.47 | 29.67 ± 0.47 | |||
| nvidia/Gemma-4-26B-A4B-NVFP4 | ctx_pp @ d4096 | 4489.98 ± 513.16 | 1023.63 ± 104.63 | 1014.55 ± 104.63 | 1023.63 ± 104.63 | |
| nvidia/Gemma-4-26B-A4B-NVFP4 | ctx_tg @ d4096 | 29.68 ± 1.40 | 30.23 ± 1.73 | |||
| nvidia/Gemma-4-26B-A4B-NVFP4 | pp2048 @ d4096 | 3594.97 ± 64.87 | 578.95 ± 10.30 | 569.87 ± 10.30 | 578.95 ± 10.30 | |
| nvidia/Gemma-4-26B-A4B-NVFP4 | tg32 @ d4096 | 28.65 ± 0.04 | 29.00 ± 0.00 | |||
| nvidia/Gemma-4-26B-A4B-NVFP4 | ctx_pp @ d16384 | 3819.19 ± 80.30 | 4679.28 ± 88.24 | 4670.20 ± 88.24 | 4679.28 ± 88.24 | |
| nvidia/Gemma-4-26B-A4B-NVFP4 | ctx_tg @ d16384 | 28.30 ± 0.67 | 28.67 ± 0.94 | |||
| nvidia/Gemma-4-26B-A4B-NVFP4 | pp2048 @ d16384 | 1994.97 ± 13.63 | 1035.71 ± 6.99 | 1026.63 ± 6.99 | 1035.71 ± 6.99 | |
| nvidia/Gemma-4-26B-A4B-NVFP4 | tg32 @ d16384 | 27.94 ± 0.16 | 28.67 ± 0.47 | |||
| nvidia/Gemma-4-26B-A4B-NVFP4 | ctx_pp @ d32078 | 2539.93 ± 21.07 | 13726.55 ± 116.16 | 13717.47 ± 116.16 | 13726.55 ± 116.16 | |
| nvidia/Gemma-4-26B-A4B-NVFP4 | ctx_tg @ d32078 | 28.16 ± 0.97 | 28.67 ± 0.94 | |||
| nvidia/Gemma-4-26B-A4B-NVFP4 | pp2048 @ d32078 | 1276.25 ± 13.26 | 1613.95 ± 16.68 | 1604.87 ± 16.68 | 1613.95 ± 16.68 | |
| nvidia/Gemma-4-26B-A4B-NVFP4 | tg32 @ d32078 | 27.48 ± 0.10 | 28.00 ± 0.00 | |||
| nvidia/Gemma-4-26B-A4B-NVFP4 | ctx_pp @ d65535 | 1484.13 ± 1.42 | 48078.91 ± 49.94 | 48069.83 ± 49.94 | 48078.91 ± 49.94 | |
| nvidia/Gemma-4-26B-A4B-NVFP4 | ctx_tg @ d65535 | 27.39 ± 0.73 | 28.33 ± 0.47 | |||
| nvidia/Gemma-4-26B-A4B-NVFP4 | pp2048 @ d65535 | 727.30 ± 7.54 | 2825.28 ± 29.29 | 2816.20 ± 29.29 | 2825.28 ± 29.29 | |
| nvidia/Gemma-4-26B-A4B-NVFP4 | tg32 @ d65535 | 26.97 ± 0.22 | 28.00 ± 0.00 |
llama-benchy (0.3.7)
date: 2026-05-01 13:31:39 | latency mode: api
Wasn’t able to launch this particular model in the cluster though.
thanks @eugr !
