I have tried to run the NVQual test id - 18 (NVQual SSD FIO Test) on my Grace Hopper GPU, but it is failing with the error message “ERROR OCCURED IN LAUNCH”.
Can you help me what is this error.
I have nvme drives in my DUT and fio sysstat also installed in my DUT. What may be the issue?
Command:
TERM=xterm LLVM=1 ./nvqual -t 18 -l 1 --bypass_menu --custom_config NVQUAL_vG.1.0.7_2/ssd_input.json --use_system_mods_driver
Output:
formatter - failed to create cxeyegrade_devices
formatter - failed to create tegrapcie cx7 attributes
All my other NVQual test cases are working fine in the same DUT.
