NVIDIA Isaac ROS 4.1 for Thor has arrived
NVIDIA Isaac ROS 4.1 for Thor is now live.
🚀 NVIDIA Isaac ROS 4.1 is live, giving you even more flexibility to build and deploy ROS 2 apps on Jetson AGX Thor.
  • Go Docker-optional with new Virtual Environment + Bare Metal workflows that plug right into your existing setup
  • Get sharper 3D with Isaac ROS Nvblox: better dynamics from LiDAR plus motion compensation
  • Run Visual SLAM with RGB-D cameras for richer visual mapping
  • Print a new multi-camera rig to mount RealSense cameras directly on Jetson AGX Thor, with canonical URDF poses so you can hit the ground running
  • Try the new sim-to-real gear assembly tutorial: train a reach policy in sim and deploy it to a UR10e arm
  • Move data faster by sending and receiving point clouds using the CUDA NITROS API
Stay up to date on the latest NVIDIA Robotics announcements by following us on LinkedIn, X, Instagram, Facebook, and Discord.
