what is the derating factor for CPU temperature, CPU power, soc Power in the Jetson AGX Xavier industrial module]
what is the derating factor for CPU temperature, CPU power, soc Power in the Jetson AGX Xavier industrial module for medical application?
Hello @raghumaragond.r,
you posted in the wrong category. I will happily move your posts to the correct Jetson related forum category.
At the same time I would recommend you start opening topics in that category directly, that way you will avoid any kind of delay.
Hi, generally, over temperature or over current will trigger performance throttling.
