For the Jetson AGX Xavier Industrial (JAXi) Module,
What is the Maximum and Minimum CPU Soc Power consumption??
need detailed datasheet for Power analysis.
Moving this to the Jetson forums.
There is no such simple maximum and minimum power consumption data. The real power consumption depends on specific use case. You can get the module maximum power in Jetson AGX Xavier Series Module Data Sheet which is the EDP for safety.
