Jetson allowed temperature
Hello all,
I have a question about allowed Jetson temperature.
I use the jtop tool from Raffaello Bonghi for temperature estimation.
As I see about 60 degrees (Celcius) the Jetson slows down.
I use development kit for the testing.
I have two questions:
What is the allowed temperature range of GPU/CPU?
Is it the same for development kit and production module?
Thank you all in advance!
Please refer to Can I know the temperature at which the throttling of the Jetson xavier nx 8gb, 16gb production module starts? - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums
Thank you very much, kayccc!
Is there a difference between production module to development in meaning of temperature?
For production module, you need to refer to Jetson Xavier NX Thermal Design Guide to implement in your project. Thanks
