I am working on a project with the Xavier NX system, and I would like to measure the temperature status of the CPU / GPU during the operation. Is there a way/command I could use to monitor the temperature and record the data as a reference for my development with the Xavier NX itself? As I understand, there should be a thermal sensor attached to the board for the safety control through the firmware, am I right?
Thanks a lot for your help. WIll give it a shot of testing later on.
For the sensor measurement point, is there any other measurement points on the board / SoC apart from the CPU that I can record through the sensor? If so, how can I find them out?
