Is it possible to get the CPU and GPU clock speed?
I am trying to do some benchmarking.
I can get the CPU and GPU temperature but is it possible to get the CPU and GPU clock speed of the Jetson Nano?
Kind regards,
Lolcocks.
Please try with TegraStats Utility : NVIDIA Jetson Linux Driver Package Software Features : Applications and Tools | NVIDIA Docs
That’s great but is there a way to do it via the Linux terminal so that I can log and store the frequency whenever required?
tegrastats is on the linux terminal…
Hello @lolcocks123 ,
Try installing jtop utility.
Thanks, but I wanted something like a command that I can execute to just get the CPU and GPU clock frequency.
Right now, I can do a “os.system(“cat /sys/class/thermal/thermal_zone2/temp”)” in Python to get a raw integer value for the GPU temperature.
Is there something equivalent to “cat /sys/class/thermal/thermal_zone2/temp” but to get the CPU and GPU clock speed.
I don’t want to look at tegrastats and manually do the benchmarking, I need to get these clock frequencies and store them along with other data as the test is going to be running for an extended period of time.
Kind regards,
Lolcocks.
