I’m currently developping an application where I need to monitor the temperatures on a Jetson AGX Xavier dev. kit,
so I tried to use the “sensors” command, this it the output of this command :
tpsh@tpsh-agx-1:~$ sensors
thermal-fan-est-virtual-0
Adapter: Virtual device
temp1: +46.4°C
iwlwifi-virtual-0
temp1: +56.0°C
As you can see, I only get these 2 results.
I read on the documentation that “Fan speed is controlled by the thermal-fan-est sensor, which reports the weighted average of the CPU, GPU, and AUX sensors at a 3:3:4 ratio” but I’d like to get the CPU/GPU temperatures directly, is there a way to do that ?
I want to mention that I didnt probe the I2C/SMBus adapters with the “sensors-dectect” command because it apparently can cause issues on some systems.
I also found this post : xavier fan question , and I’d like to get the same kind of output, can you help me?
