General Question: Should Models Be Structured to Fit Under Frame Budgets when running ML work on display GPU
2
157
September 13, 2026
Why were deepseek v4 pro and flash deprecated?
9
2938
August 8, 2026
GLM-5.2's instability
2
619
August 8, 2026
First sparkrun try with a recipe from spark arena won't start
6
573
July 25, 2026
cuMemSetAccess Failed to create GPU mapping
0
287
July 20, 2026
Questions for two undocumented VMM API behavior
2
325
July 17, 2026
Getting Involved for Volunteering At APAC
0
68
July 4, 2026
How much better is DS4F on 2x Sparks vs the best 1x Spark option?
7
767
July 2, 2026
Is it possible 400GbE between 2 sparks by 2 QSFP connection?
4
742
April 30, 2026
Is meta/llama-4-scout-17b-16e-instruct disabled for api?
0
151
April 6, 2026
Running MiniMax 2.5 on 2× DGX Spark (Multi-node, vLLM)
1
831
April 5, 2026
Forward packets from and to the same port using DOCA-Flow
1
173
December 11, 2025
Does audio2face use the arkit 52 blendshapes?
1
308
October 30, 2025
[Question] Missing user_additional_install.sh in /opt/nvidia/deepstream/deepstream/
2
184
October 21, 2025
Linux drivers for new GPU's?
4
750
October 9, 2025
[Question] Deepstream 7.1 Saving sample frames using nvsdanalytics in S3 with Kafka plugin
6
307
September 22, 2025
I need help setting up OpenXR
1
236
September 2, 2025
Noob question about environment variables
2
1375
August 31, 2025
When will smooth motion arrive to rtx40 series on Linux?
2
647
August 23, 2025
VDD_3V3_SYS Power Rail
1
165
June 2, 2025
Need help about camera regulators
36
1065
April 30, 2025
Bypassing Power button MCU in Orin Nano Custom Carrier Card
5
542
April 29, 2025
Questions about board design of AGX Orin Industrial
1
361
April 17, 2025
E3317_A01 RX/TX Swap Board Schematic
1
184
April 17, 2025
Customization of Jetson AGX Orin 64GB Developer Kit Board
1
212
April 16, 2025
Jetson Nano Developer Kit and RTC Circuit
2
223
April 15, 2025
AGX ORIN PCIE (C4) Lane Reverse?
3
269
April 11, 2025
Jetson Nano: HDMI TMDS LINE PULL-DOWN Resistor 499ohm, What use?
1
191
April 9, 2025
Jeston Nano: HDMI TMDS LINE Serial Resistor & Common Mode filter What Use?
1
190
April 9, 2025
Issue with VBUS detect pin on Jetson orin RX/Nano
4
326
April 8, 2025
