AGX ORIN PCIE (C4) Lane Reverse?
hello I have Some Question About AGX Orin PCIe I/F
The connected PCIE signals of M.2 KEY-M on AGX ORIN Dev Kit are connected as follows:
AGX ORIN ↔ M.2 KEY-M
  1. UPHY_TX/RX[22] ↔ M.2 TX/RX[3]
  2. UPHY_TX/RX[23] ↔ M.2 TX/RX[2]
  3. UPHY_TX/RX[10] ↔ M.2 TX/RX[1]
  4. UPHY_TX/RX[11] ↔ M.2 TX/RX[0]
As above, the lane is connected in reverse, but
I want to connect the carrier board that I am developing without reverse, as shown below.
  1. UPHY_TX/RX[22] ↔ M.2 TX/RX[0]
  2. UPHY_TX/RX[23] ↔ M.2 TX/RX[1]
  3. UPHY_TX/RX[10] ↔ M.2 TX/RX[2]
  4. UPHY_TX/RX[11] ↔ M.2 TX/RX[3]
Will it work normally automatically even if I connect it like this without reverse?
  • Is there something that needs to be processed in software? (EX: BSP)
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I have moved this post for better visibility.
Cheers,
Tom
PCIe lane reversal as you have proposed here in reverse order is supported. Expected to work as is.
Thank you Everyone!
