We want to configure x1 lane of the PCIe x4 (C4) node. When we checked demo card, we noticed that lines connected in reverse.Which lane should we connect to use as x1? Is correct lane (UPHY block 0, lane 4) or (UPHY block 0, lane 7). Can this be selected from the device-tree?
What is your suggestion for using C4 node as x1?
Please refer to Jetson AGX Orin design guide. Lane reversal and polarity inversion (P/N swapping) is supported on PCIe controller. Lane configuration x1, x2, x4 are supported in this case (C4 controller, Root Port).
There is no software to configure this part. We suggest to do the correct hardware.
PCIe lane reversal like 0,1, 2, 3 or reverse order like 3, 2,1, 0 are supported and expected to work as is.
We will connect only one lane(x1 pci) of C4 node , which lane is correct one?
UPHY_RX22/TX22(Lane 4)
or
UPHY_RX11/TX11(Lane 7)
UPHY_RX22/TX22(Lane 4) is PCIe controller #4 Lane 0 in this case.
Thank you for the reply.
