Forward packets from and to the same port using DOCA-Flow
Hi, I’m trying to forward packet from a port to the same port using DOCA-Flow.
By changing following code line to fwd.port_id = port_id; (The original code works perfectly)
However, it resulted in segfault in doca flow library. Is there any way to forward packets from and to the same port?
Hello @pusnow1 ,
Thank you for posting your query on our community.
According to the NVIDIA DOCA Flow documentation, a port cannot be paired with itself — which implies that forwarding packets from a port back to the same port is not supported.
You can find the relevant statement under the API documentation for doca_flow_port_pair.
Thanks,
Bhargavi
