I have created a project/workshop for connecting Nvidia Jetson devices to Azure IoT Central Azure IoT Central documentation | Microsoft Docs using the Azure IoT Plug and Play C SDK The Azure IoT device SDK for C | Microsoft Docs. This example allows you to command and control DeepStream workloads remotely and report object detection telemetry into a custom dashboard. It can easily be customized to use additional video sources (USB/CSI camera, RTSP streams, Local Files) and a custom inferencing model for object detection.
The full guide for reproducing this project is available @ https://github.com/toolboc/azure-iot-nvidia-jetson-deepstream-pnp
